Multiple symmetry update
 1-11  12-31  32-39
7888.12 In reply to 7888.10
@Brian - no problem!
@Tom - I think I missed a part of what you were looking for, try the attached version which first does a mirror around the world Y axis, then generates the rotated copies (the previous version also accidentally made one extra copy too).
So it will make a history setup that will work like this:
7888.13 In reply to 7888.11
Hi Tom,
> I took a look at the html file as I managed to achieve changes by
> editing the html before in the circular array html :
Oh yeah, for changing the default value of the ArrayCircular UI control that is where you want to go. Sorry I thought you were trying to do something else.
But I think the second script above should finally do the kind of symmetry that you were looking for.
(and I accidentally edited your message above when I was trying to post this one)...
7888.14 In reply to 7888.12
I noticed that there was a copy of curves and just deleted them. Perfect - it does even create symmetry automatically now?!
Have to try tHE update immediately. Thanks for the update !
If you take view Points and move points history is broken with this Script : that's normal ?
EDITED: 23 Mar 2016 by PILOU
7888.16 In reply to 7888.15
Well it depends on which particular curves you were editing. You should be editing the original curves and then all the generated ones will update. History will only be broken if you edit one of the generated curves instead of the original one, is that what you were trying?
Here is an example of editing the control points of the original curve:
Sorry I don't know what i made: all works fine now!
Maybe I have pressed the History button in false position after the MirrorRotateHistoryArray...
What about the number of copy rotation itself ?
If I modify it (with a text editor) that change the Angle, but not the apparently original 12 result !
Say I want 5 result for example???
7888.19 In reply to 7888.18
There's one line of code that controls that, on line 26:
	var numcopies = 6;
If you want to have 5 copies around the circle edit that line to say this instead:
	var numcopies = 5;
Don't modify the angle, modify the line above the angle that sets the number of copies. The angle is automatically computed based on the number of copies.
You mean 5 copies rotated around and not any mirroring? That's what the first script in this thread did, it didn't do the mirroring step, it did rotation only, so try that. It's in this same thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7888.7
If that's not what you're trying to do could you try to describe it a bit more?
7888.20 In reply to 7888.19
Perfect! (if we accept to have the Editor Text open in the same time! ;)
All that will be not necessary when Object Components System will be made! :)
I have my 5 objects!
EDITED: 24 Mar 2016 by PILOU
Infinite gothic rosace play! :)
Possibility to move the points of the first curve(s) is very practical!
7888.23 In reply to 7888.22
Pilou is the king of experimentation ! ;-)
Should be possible to use this script as a "Guilloche Generator" like this tool here :
http://2008.sub.blue/projects/guilloche.html
7888.24 In reply to 7888.23
Don't miss by the same author Tom Beddard
the incredible and very easy Fractal Lab Online!
http://hirnsohle.de/test/fractalLab/
my test ;)
7888.25 In reply to 7888.24
Beautifully amazing !
7888.26
Hi.
This nice script works with curves but not with solids generated form that curves.
Is it possible to expand the script so it will work with solids, too ?
7888.27 In reply to 7888.26
Hi Tom, it might depend on what particular command or process you use to create the solids from the curves.
Can you give some more specific workflow for how your solid is being constructed?
7888.28 In reply to 7888.27
First, I draw the curves.
Then, I create solids out of them with loft or network.
As I am designing a symmetrical object, it is much faster to use a script
than apllying the symmetry command several times.
7888.29 In reply to 7888.28
Hi Tom, can you post an example file that has one of your curves that you are replicating and then using Loft and Network on?
I just did a quick test over here, and I was able to use the symmetry script to generate curves, then did a loft through those curves and it is updating fine for me when I edit the original curve.
7888.30 In reply to 7888.29
Here an example with network (3 repetions / arrays)
The script runs with the curves but it does not multiply the network.
EDITED: 30 May 2016 by SIRTOM
7888.31 In reply to 7888.30
Hi Tom, thanks for the example, sorry I didn't quite understand what you were trying to do before.
The script will need to be modified to work on things other than curves, it currently only collects curves to replicate just because that's what you originally described as what you were trying to do.
To make it work on any kind of object, edit line 13 of the file MirrorRotateHistoryArray.js which currently has this:
	var curves = moi.geometryDatabase.getSelectedObjects().getCurves();
Change it to remove the ".getCurves()" part, so that line should look like this instead:
	var curves = moi.geometryDatabase.getSelectedObjects();
With that line changed, it should then work to replicate any kind of objects.
Show messages:  1-11  12-31  32-39
