Mighty Mechanical Death Crabs of Doom, in the Dawn of Terror
 1-15  16-27
5851.16
I AM impressed Zarkow!
I've usually not has much success with sweeping between two intertwined helixes.
5851.17 In reply to 5851.12
I like!
I see that you're making the rounded shape of the 'claw' with Blend between two surface edges acting as a profile... the end caps with a Blend too.
Quite a unique shape.
The really tricky part has to be all those little intersecting line to make those channels.
5851.18 In reply to 5851.15
You say that Union boolean works for these complex shapes only exporting as Sat format from Moi then importing in Moi ?
5851.19 In reply to 5851.18
Yes, and seems to be only SAT (no: 3dm, Step and Iges) only Sat and Sometime Fillets work better too. I don“t know why, but I think the patch geometrie change a little bit. In the tutorial you can see at step (Trim-Isocurve part) on spiral (rings), next step(Union Boole part) the rings are spit.
5851.20 In reply to 5851.19
When you export to SAT format it splits any closed edges or surfaces in half, so for example if you have a cylinder and export it to SAT when you reimport it you'll see it's in 2 halves instead of just one closed surface.
Also during SAT export it does a "ShrinkTrimmedSrf" to shrink down underlying surfaces down to their active trimming boundary area.
When the split happens it means that there is no longer any "seam" edges in the model, probably whatever problem you were running into involved something about seam edges. Or possibly if there were some self-intersecting bunched areas outside of the active trim boundary areas the ShrinkTrimmedSrf part can throw those pieces out.
EDITED: 24 Apr 2013 by MICHAEL GIBSON
5851.21
I think that you're my new hero!
5851.22
5851.23
Garden flowers have nowhere to hide!
Zarkow, you're going to work in the movie industry someday!
Stunning!
5851.24 In reply to 5851.22
Awesome stuff ... :)
Well done Zarkow
5851.25 In reply to 5851.22
mmm.....I like crustaceans, however these look a little dangerous and chewy :)
Nice modelling and rendering zarkow, very dramatic.
Thanks for sharing.
5851.26 In reply to 5851.17
I'm loving this model, but coming from a poly-modeling background, I'm not wrapping my head around extruding the curves, and then blending to get the initial cylindrical shape. Could someone elaborate please?
SPH
5851.27 In reply to 5851.15
hi,
i dont get the "flow" here ???
cheers
t.
Show messages:  1-15  16-27
