surface through the points at different heights
All  1-6  7-10
4735.7 In reply to 4735.6
This is a sample file
My intent was to create a surface by selecting all the points simultaneously
4735.8 In reply to 4735.7
Hi Tony,
See if this gives you any results.. I opened your file and ran the "ConnectPoints" script on it.. Then I ran rebuild by points with a value that smoothed the curve a bit (The more points, the more it is like the polyline). Then I lofted the curves for this surface.
4735.9 In reply to 4735.8
Thanks BurrMan :)
4735.10 In reply to 4735.9
Obviously not as good as having the surface from points command, but maybe a make due for now..
Show messages: All  1-6  7-10
