No random color
All  1-2  3-19
4517.3 In reply to 4517.2
More precision :)
100 existing objects = selection
Style 1 to style 100 are a gradient that we can easy manage if
we can make something like this
of course increment can be anything, and start color anything following wish of the artist :)
pseudo code
/start colors
red=12
green=15
blue=20
for i= 1 to 100
Style i = red, green, blue
object i =Style i
/increment
red=red+2
green=green+3
blue=blue+7
end i
of course if 255 is the max for each Red, Green, Blue we take another increments and/or start colors :)
EDITED: 17 Sep 2011 by PILOU
About the palette
something from a 2d prog like toshop who gives a palette of 100 colors (if 100 colors are needing)
If there are more objects than the palette colors
these are using the palette in cyclic mode (so no random mode)
4517.6 In reply to 4517.3
re: pseudo code - that translated to actual code is like this:
script: /* Make gradient styles */ var red = 12, green = 15, blue = 20; for ( var i = 1; i <= 100; ++i ) { var style = moi.geometryDatabase.addStyle(); style.name = 'Gradient ' + i; style.color = ((red%256)<<16) | ((green%256)<<8) | (blue%256); red += 2; green += 3; blue += 7; }
If you run that script it will create 100 styles that are assigned a gradient by the same increments as your pseudo code.
If you want to vary it, change the start values where it says:
or change the increment part at the end where it says:
In this one when a value is incremented more than a value of 255 it will "wrap around" back to 0 and continue from there.
Note that this one creates 100 styles as part of the process, don't create 100 blank styles before running it unless you want to have 200 styles total.
4517.7 In reply to 4517.4
> About the palette
Unfortunately that takes quite a bit of work to produce a UI for that kind of full Photoshop color palette management.
That's beyond what I can do in a few minutes with a script, you would need to develop something of that level of complexity on your own - I could try to help you out in some particular spots if you want to undertake it.
4517.8 In reply to 4517.6
Haaaaahahahaaa... That is cool!
Michael you rock again! Bravo!
I suppose there is no problem to give a negative increment
red - = 4 (if it's the syntax and take care of a last result less 0 :)
No problem about the toshop palette with your script i can yet make some crazzy gradients!
And how apply these new gradients styles to the selection of Objects ? :)
I know for apply them as random mode but with these new gradients in normal mode?
(by Michael)
script: /* Assign random styles to solids */ var styles = moi.geometryDatabase.getObjectStyles(); var breps = moi.geometryDatabase.getObjects().getBReps(); for ( var i = 0; i < breps.length; ++i ) { var brep = breps.item(i); var style_index = Math.floor(Math.random() * styles.length); brep.styleIndex = style_index; }
Surely trivial but...
works only if number of objects <= numbers of styles
how make if numbers of object are bigger than the gradients and wanted cyclic result?
(of course i can reselect the no color objects and relaunch the script but... :)
something like this ? modification of the script above :)
script: /* Assign styles to solids */ var styles = moi.geometryDatabase.getObjectStyles(); var breps = moi.geometryDatabase.getObjects().getBReps(); for ( var i = 0; i < breps.length; ++i ) { var brep = breps.item(i); var style_index = i; brep.styleIndex = style_index; }
here nice result for the gradients'style!
EDITED: 18 Sep 2011 by PILOU
4517.11 In reply to 4517.9
Hmmm, I don't think that script was expecting for the numbers to become negative. You may need to add in an additional Math.abs( ); call to take the absolute value for that case, something like:
script: /* Make gradient styles */ var red = 12, green = 15, blue = 20; for ( var i = 1; i <= 100; ++i ) { var style = moi.geometryDatabase.addStyle(); style.name = 'Gradient ' + i; style.color = (Math.abs(red%256)<<16) | (Math.abs(green%256)<<8) | Math.abs(blue%256); red += 2; green += 3; blue -= 7; }
4517.12 In reply to 4517.11
Sorry for the complexification but now that is total control for generate gradient by hand ;)
4517.13 In reply to 4517.10
Yup, it looks like that works, except the only problem would be if you had more than 100 objects the ones that were above the last style index will end up with the default first style applied to them instead, since that would be trying to assign them a style that does not exist.
So maybe you would want to wrap around to avoid that, something like:
script: /* Assign styles to solids */ var styles = moi.geometryDatabase.getObjectStyles(); var breps = moi.geometryDatabase.getObjects().getBReps(); var style_index = 0; for ( var i = 0; i < breps.length; ++i, ++style_index ) { if ( style_index == styles.length ) { style_index = 0; } var brep = breps.item(i); brep.styleIndex = style_index; }
This one when it reaches the last style it will start over at 0 for the next style after that.
4517.14 In reply to 4517.13
Works like a charm!
Total success!
Bravo!
here test with the default Styles modified the black one in yellow ;)
The 2 orange red on the bottom left side are just the new beginning as 100 is not dividing by 7 :)
4517.15 In reply to 4517.14
Now you can create many candy models! :)
Hello Michael
does your plug accept value like this red -=5.7 ? or it's truncated to 5 or 6 ?
EDITED: 19 Sep 2011 by PILOU
4517.17 In reply to 4517.16
Neat spiral thing, Pilou... makes me hungry for gummmmy worms. :-)
4517.18 In reply to 4517.16
I think that should work - the actual color value used will automatically get truncated to an integer value. Let me know if it doesn't seem to work right.
4517.19 In reply to 4517.18
All works fine when we enter decimal value so we have not to think when we make divide rgb color by number of styles :)
It's not very ergononomic but very efficient! :)
I have made a little tut ;)
Show messages: All  1-2  3-19
