Array Circular view 3D
All  1  2-8
4268.2
don´t know if there is a solution, but what do you have against the Cplane. In TC, which I use very often, all 2D operations can only be made on a defined Cplane.
Rudl
4268.3 In reply to 4268.1
> Maybe something like
> Center + 3 points
Hi Pilou, you can get that exact same result by setting the CPlane to those 3 points.
Once your CPlane is set that will control the orientation that the circular array will use.
See this recent post for a description and animation for how to align the cplane to 3 points:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4239.6
Let me know if you are having some difficulty placing the cplane how you need it and I can show you how to do it - it would help if you would post a 3DM file so I could see what situation you are having difficulty with.
It's normal that for some kinds of less frequently used situations that you may need to use the cplane tool in combination with another tool in order to get what you need. It would not really be a good approach to have a special extra icon for doing this with circular array since you can already get what you need using the cplane and adding in too many icons to the UI makes the UI become cluttered and more complex and difficult to use.
For a while earlier in v2 betas I did have the circular array tool automatically orient itself to the object the center point was clicked on like how the draw tools work, but that caused some problems because it was a bit too easy for the orientation to be surprising when snapping on to something like the corner of a box. That works better with the draw tools because with the draw tools there is another point picked after the center point and so the orientation can update when you rotate around to look at different faces of the box (the orientation of the box face pointing most towards you will be used). That did not work so well with array circular since it only uses a single point pick in it. Here is the discussion thread about this:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3022.1
No I have no difficulty with the CPlan :)
It's just that I was in the array circular in the 3D view and was surprise that there is not a 3 points snap + helper lines for orient the process :)
You must go out for take the CPlan and come back to the array circular :)
When you have seen fluent functions in another parts you will the same anywhere :)
4268.5
Hi Micheal,
this is the right moment to say something about the Cplane.
Ok, I come from TC. There I only need to choose three points to define the Cplane. The first is the origin, the second x-axis, and the third y-axis. That´s it.
In MoI I must define a rotation axis for the third point, to define it. I can handle it, but this is a little bit more complicated then in TC.
I know, this princible is also used in the orient tool, and there it is usefull.
Rudl
4268.6 In reply to 4268.4
You mean the same kind of orientation picker that the cplane is set with?
If Array Circular used that as part of its regular operation, that would have a kind of bad side effect of making it more complex to just do simple 2D circular arrays because placing that orientation widget is a somewhat more complex process than placing just a single origin point like how Array Circular works currently.
So it helps to keep Array Circular simple in operation for regular 2D uses by relying on setting the CPlane if you need to control it to a custom orientation.
Once you understand that you need to set the CPlane first, you can go there first instead of trying to start up the array circular command first. Then you don't need to "come back" to Array Circular, just go to Array Circular once after you set the cplane...
Yes, but unfortunately making Array Circular default to using the orientation picker as its first step would actually make it less fluent for simple 2D use cases, since placing a single origin point is easier for those cases than placing the orientation picker.
The orientation picker being a somewhat more complex kind of interaction is more reserved for commands that are focused on orientation, like the Orient command itself, or the cplane tool.
4268.7 In reply to 4268.5
Hi Rudl,
No, you only need to place 3 points in MoI to define it - the first point is placed at the origin and then the 3 axis picker will show up.
Then you can drag the x axis to the 2nd point, and then placing the y axis to the 3rd point completes the process and it is fully oriented with those 3 picks.
See here for an example:
However, if you place the origin point snapped on to an object, it will start out with the z axis already aligned perpendicular to that object, like aligned to the surface normal if you snapped a point on to a surface. If that z axis perpendicular is what you wanted then you can adjust the rotation around it by dragging either the x or y axis to finish the orientation. If you did not want to have the z axis aligned perpendicular to the object the origin is snapped on to, there is a checkbox option that you can uncheck to stop that from happening:
Maybe that automatic z-axis alignment is causing some confusion - if that's the case then uncheck that "Align to objects" box to prevent it.
If you're still having some difficulty placing the cplane could you please post an example file that shows what you are trying to align it to? Then I can give you a demo on your particular file to help illustrate it.
4268.8 In reply to 4268.5
Hi Rudl, here's a quick example of a situation where it is more convenient to define the orientation by placing the origin point with the z-axis perpendicular to the object:
So notice there how easily the cplane is set perpendicular to that curve in that situation - it gets placed in a good location with just the first origin pick and then you can right-click to accept the default orientation and you're done. Placing it perpendicular to a surface works in the same kind of way, it gets aligned to the surface normal with the first pick.
These kinds of situations where you're mostly concerned about how the z axis of the cplane is positioned are pretty clumsy and awkward to do with the "3 points" method where you have to focus on placing the x and y axis locations and having the z axis that you are primarily concerned about only get set as a kind of side effect of those other picks.
But in other kinds of situations it can be good to do the 3 points method as well - so that's supported in MoI as well by turning off that "Align to objects" checkbox. Then the process becomes - place the origin point, drag the x axis to the second point, and drag the y axis to the third point, so that's how the orientation picker supports that kind of 3 point operation as well.
Having these different methods available helps to make the orientation picker flexible and able to work in a couple of different ways.
Show messages: All  1  2-8
