Maintain height - sweep param
All  1-4  5-9
314.5
Thank you all, I understood what this command is about, I just wanted to see a nice example (Thanks Michael).
However, this cannot be pre-calculated, I mean the scale...
314.6 In reply to 314.5
The scale is determined by the spacing between matching points on the rails. It's not just one scale factor value, it is continuously changing as you move along the rails and they come closer or farther apart from each other.
I'm not sure if I understood this question...
314.7
Michael, Nice whoopie cushion !!!! :)
JTB, i think if you want the ability to control the scaling it would require a network surface command so you could use additional rail curves to define the profile...
314.8 In reply to 314.5
After the sweep
Select the original curve (not the rail)
Show points
Move points
With that you will obtain the height and scale that you want ;)
EDITED: 16 Jan 2007 by PILOU
314.9
You can also control the shape of the sweep by using more than one object as the profile...
Show messages: All  1-4  5-9
