Lock Shortcut ?
All  1  2-6
2837.2 In reply to 2837.1
script:moi.geometryDatabase; gd.lock();
2837.3 In reply to 2837.2
Hi Burr, yup that will work since back some time ago I added "gd" as a global available to scripts that is the same as moi.geometryDatabase
So it can just be:
script:gd.lock();
I generally try not to make scripts that use that though, because they are not compatible with version 1 that does not have "gd" set up as a predefined global variable.
However in this case it's not compatible with v1 anyway since lock is only available in v2.
The "regular" full way would be this:
script:moi.geometryDatabase.lock();
2837.4 In reply to 2837.3
I basically went to the sidepane.htm and started from there as I am not a javascript guy. Started removing things until I got rid of the error. I figured it could be refined more though to do all the if/then stuff that is included in the actual button for proper functionality. couldnt figure that out though. :O
2837.5 In reply to 2837.4
Hi Burr, yup that is the way to track it down.
The way the button works is it does some different functions if you do Ctrl+click on it (unlock subset) or if you right-click on it (isolate lock - locks everything else than the selection).
You can't really "right-click" on a keyboard shortcut, so probably if you wanted to set those up for keyboard shortcuts they would be separate shortcuts, like one for "L", one for "Ctrl+L", one for "Shift+L", etc...
2837.6
Thanks a lot guys :)
Show messages: All  1  2-6
