Close curves?
All  1-2  3-9
2752.3 In reply to 2752.2
Thx!
Be useful in some cases!
Works like a charm! And first time I use the line command :)
Tested on the Angelo beast :)
@Michael
A little question :)
When I change the names of the commands files CloseCurve.htm and CloseCurve.js for put a French name like FermeCourbe.htm and FermeCourbe.js seems that is not working with key Tab (not try with shortcut)
Is that normal?
2752.6 In reply to 2752.5
Hi Pilou - the name of the command comes from the name of the file. So if you change the file name, then the command name will change as well and you would put in FermeCourbe as the command name in the keyboard shortcut rather than CloseCurve.
2752.7 In reply to 2752.6
Curiously when I restart the prog, that's working!!!
So very cool :)
2752.8 In reply to 2752.7
You must have typed the other name in once before you had copied the file over.
When you launch a command, MoI caches the result into memory so that it does not have to access the disk anymore to run that command after that. That includes remembering if there was no command matching that name.
2752.9
Thanks, this will be a useful tool!
Marc
Show messages: All  1-2  3-9
