Illustrator feature request
All  1-6  7-16
2732.7 In reply to 2732.4
> I just did a test with export to ai and hid a few curves and exported only the visible ones and it worked. Does this not work for you?
I'm sure it would, but the problem I am talking about are the hidden lines that appear on a solid. That is, the lines of the solid that are not visible to the viewer from their point of view. Inside MoI itself, these lines normally appear as faint dashed lines (unless you've turned them off completely), but in the Illustrator output they appear just like any of the normal, visible lines do. Sounds like Michael is going to address this in version 3.0 though...
- Dave Morrill
2732.8 In reply to 2732.7
OIC. Thanks.
2732.9 In reply to 2732.6
Hi Dave, the scripting docs sound cool! That sounds like a good system for me to be able to look over it and add in comments and stuff like that.
re: 2D illustration - yup with some additional flushing out in this area I think that MoI will be a pretty nice fit as a 3D tool for 2D illustrators. The general mechanism of how NURBS modeling works is pretty friendly for 2D illustrators since a lot of it is based off of drawing 2D profile curves as part of the construction.
Poly/sub-d type 3D modeling tends to be less similar in general behavior from 2D illustration.
2732.10 In reply to 2732.9
That's one of the main reasons I did it this way...to make the best use of your time when you have a few minutes to devote it it ;-)
I also had a major breakthrough today:
Things should go faster now because I can "peek inside" and interactively try things out in Javascript within MoI to see exactly how something works.
- Dave Morrill
2732.11 In reply to 2732.10
Seems "test" icon too big ;)
2732.12 In reply to 2732.11
MoI automatically scales it to the correct size. I think it seems big just because it goes to the edges of the image, while the other MoI icons don't. In any case, it's just for my own use while I come to grips with the MoI internals. Clicking the icon launches my "Test" window, which I use to explore how MoI works...
- Dave Morrill
2732.13
Oh yeah!! Can't wait to see 2d projection tools in Moi3d!!
One of the strong point of using Nurbs for this purpose is getting very clean vector lines from 3d viewpoint of a model, polygons just cannot compare for this purpose.
This is indeed a very good asset in an illustrator's toolbox.
Marc
2732.14 In reply to 2732.13
Hello,
I will be sticking around for MoI 3 exactly for this illustration functionality. I currently go through a few gyrations to get the 2D where it needs to be. but if the functional pedigree of MoI 2 is any indication it will shave hours off my prep time.
2732.15 In reply to 2732.5
that's great news,
could you also consider supporting PDF Publishing 2D/3D Output ?
2732.16 In reply to 2732.15
Hi neo,
Yes, that's also on my list to add at some point in the future.
Show messages: All  1-6  7-16
