Hi Petr,
> Generally speaking, why windowing cannot deselect a selected object(?) When
> I pick the selected object it gets unselected. So why couldn't dragging selection
> window (both solid and dashed area selection box) deselect previously selected objects?
It's because of targeting multiple objects - sometimes when you do a window, you may want to do several overlapping windows to help you build up your final selection.
If previously selected objects inside the window became unselected, it would interfere with this - objects in the areas intersected by multiple windows would keep flipping their selection state instead of all staying selected.
> ..or....might it be possible to script an additional type of windowing and users could
> choose their own shortcut to initiate windowing which would work like - select
> unselected, deselect selected objects?
This is probably not too hard, I can give it a try when I get back.
