Basic driving instruction that appear to be completely skipped in the tutorial videos and help pages.
All  1-8  9-15
11721.9 In reply to 11721.3
“”””””””” So, if I have something that isn't a basic solid, but a complex solid and I need to apply a draught angle for mould release, I have to throws away everything and start from scratch to do so?”””””””””
In MoI, if i wanted a cube with a draft angle, i wouldn't “draw a cube and then edit the draft by dragging/moving edges”. I would draw a square and then extrude it using the draft/angle option.
So Michael answered he has plans to add in some direct modeling!!!
For now, you must model it in.
11721.10 In reply to 11721.3
Hi Buk,
There's no quick and easy command to add draft. One way to do it is by replacing the extruded faces with a sweep of a line that's tilted at the draft angle. Gets into surface modelling territory though.
To do it with solid modelling the best route is probably Construct > Extrude > Tapered and then Boolean > Diff/Union
- Peer
EDITED: 25 Apr 2025 by PEER
11721.11 In reply to 11721.8
I am doing something wrong.
I drew a plane.
I drew another plane at right angles to the first.
I clicked Boolean Intersect.
Nothing happened - no solid appeared where the two planes would intersect, if projected.
What have I overlooked?
Frederick
11721.12 In reply to 11721.11
Hi Frederick,
Try drawing a rectangle curve instead of a plane surface.
Planar curves are automatically extruded into solids with booleans, planar surfaces like you constructed are not.
11721.13 In reply to 11721.12
Pilou referenced "planes" and I took that literally.
It works just fine now.
I had no idea MoI could do that - it could be wonderfully useful.
Frederick
11721.14 In reply to 11721.13
Don't undertstand your problem...
EDITED: 25 Apr 2025 by PILOU
11721.15 In reply to 11721.14
HI Pilou,
Michael got me sorted out.
I was using planes, not planar curves, as you were using.
All is good.
Frederick
Show messages: All  1-8  9-15
