Basic driving instruction that appear to be completely skipped in the tutorial videos and help pages.
All  1-9  10-15
11721.10 In reply to 11721.3
Hi Buk,
There's no quick and easy command to add draft. One way to do it is by replacing the extruded faces with a sweep of a line that's tilted at the draft angle. Gets into surface modelling territory though.
To do it with solid modelling the best route is probably Construct > Extrude > Tapered and then Boolean > Diff/Union
- Peer
EDITED: 25 Apr 2025 by PEER
11721.11 In reply to 11721.8
I am doing something wrong.
I drew a plane.
I drew another plane at right angles to the first.
I clicked Boolean Intersect.
Nothing happened - no solid appeared where the two planes would intersect, if projected.
What have I overlooked?
Frederick
11721.12 In reply to 11721.11
Hi Frederick,
Try drawing a rectangle curve instead of a plane surface.
Planar curves are automatically extruded into solids with booleans, planar surfaces like you constructed are not.
11721.13 In reply to 11721.12
Pilou referenced "planes" and I took that literally.
It works just fine now.
I had no idea MoI could do that - it could be wonderfully useful.
Frederick
11721.14 In reply to 11721.13
Don't undertstand your problem...
EDITED: 25 Apr 2025 by PILOU
11721.15 In reply to 11721.14
HI Pilou,
Michael got me sorted out.
I was using planes, not planar curves, as you were using.
All is good.
Frederick
Show messages: All  1-9  10-15
