NodeEditor Plus [Unofficial]
1-13
94-113
114-133
134-141
Frenchy Pilou (PILOU)
28 Sep (134 of 141)
11614.134
In reply to
11614.133
I will test in 10 minutes !: )
What is the use of the "I" up side right up page ?
My Moi French Site
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
MO (MO_TE)
28 Sep (135 of 141)
11614.135
In reply to
11614.134
It's the "Properties panel" or "
I
nfo panel" toggle to turn the panel on or off.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
28 Sep (136 of 141)
11614.136
In reply to
11614.135
OK!
Ai don't succes to use .nod to manage some numerical numbers inside yet existing scripts!
Whitout a big transformation of the script itself! :)
So I will stay in pure nod (without draw nodes) for some cool other things :)
EDITED: 28 Sep by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
30 Sep (137 of 141)
11614.137
Next will be a pure geometric drawing! :)
My Moi French Site
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
1 Oct (138 of 141)
11614.138
So...
You can select anything! And multiple! :) Lines, curves, surfaces, volumes...
Always no drawing nodes! :)
https://moiscript.weebly.com/elephantia.html
@ MO_TE - A little request : make the possibility to have a "step" inside sliders ? (maybe yet existing...)
EDITED: 2 Oct by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
MO (MO_TE)
2 Oct (139 of 141)
11614.139
In reply to
11614.138
Hi PILOU,
Here are the "Knob" and "Slider" nodes with step property added.
Please check the attached file. Put it under "moi\NodeEditorPlus\nodes" folder and replace it with the older file.
I'll add it to the next release if everything works well.
interface.js
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
2 Oct (140 of 141)
11614.140
In reply to
11614.139
@ Mo_TE
Perfect il will try that as soon possible!
My Moi French Site
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
3 Oct (141 of 141)
11614.141
In reply to
11614.139
@ MO_TE
Seems excellent! Bravo!
EDITED: 3 Oct by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
74-93
94-113
114-133
134-141
