Removing duplicate lines
All  1-4  5-7
11111.5 In reply to 11111.4
Hi Matadem,
> Question...is there a reason removeduplicate does not seem to work here.?
It's because the pieces are not full duplicates of each other. The extra pieces there are duplicates only of some smaller portion of the largest curve, not duplicates of the entire curve.
To process this file to remove duplicates, start by a "select all", then do Edit > Separate to break apart long curves into individual small segments. Then select all and run RemoveDuplicates, then Join.
Message 11111.6 deleted 28 May 2023 by PHIRO
11111.7 In reply to 11111.5
Thank you!
Show messages: All  1-4  5-7
