groups in v5beta
 1-12  13-32  33-36
Just a little thing...
When 2 objects (in the same group with or not the same type) have the same name only one object appears in the list of the group!
Does it make sens to permit or forbid this? ( put something like 2 cube or never same name ...)
Permit seems very cool!
Say you have a group a 100 cubes (each cube is named box) maybe 100 box will be cool to have in the vertical list ?
Useful when you copy something for example! ;)
You are directly informed that there are 24 glasses named crystal on the table! ;)
EDITED: 18 Aug 2022 by PILOU
10815.14 In reply to 10815.12
Hi Michael.
And why groups should follow 2D programs in 3D program?
Problems with understanding this concept seen here don't confirm that's the best way.
But, I assume that's for sake the majority of users used to groups in those 2D applications.
Marek
10815.15 In reply to 10815.9
Michael,
Direct selection with ctrl+click sounds handy.
Swiping is great on a graphics tablet!
Thank you for the bug fixes and generally being so responsive to criticism and questions.
- Peer
A small question.
In the V5b, when I try scripts where the script crawls the objets like opencurves or SeparateObjectName with a moi.geometryDatabase.getObjects() or moi.geometryDatabase.getObjects().getCurves()
The grouped objects are not crawled, I think.
For exemple, SeparateObjectName verifies if objects have same name and then rename duplicate names with a "_NN" suffix.
I seems for V5b groups are objects and objects included in groups are not crawled as objects.
When I have two groups with same name, the two groups are renamed but objects in the groups with same names are not renamed.
For Opencurves, the scripts is now useless because with v5b we have the Menu Types/Curves/open
Have those scripts to be modified to scan objets in groups ?
10815.17 In reply to 10815.13
HI Pilou,
Yes, that's intentional. It's been a longstanding feature in MoI that you can give multiple objects the same name and then control them all as a set using the same label in the scene browser.
So named objects inside a group will have just one label inside that group, same behavior as named objects that are not inside of a group.
If you want to control them individually inside the scene browser you need to give them unique names.
You are already informed of that currently in the properties panel:
If those 24 glasses would have 24 individual name labels inside of the scene browser, that would not help to determine the number.
10815.18 In reply to 10815.14
Hi Marek,
Because those 2D programs have had a feature called "Groups" for probably the longest time of any software and as a class of software they have the greatest consistency between them for how groups function.
It's incorrect to jump to that conclusion. The main response from people who understand it fine is just silence.
Yes that's correct.
10815.19 In reply to 10815.16
Hi Phiro,
In the current (May-22-2022) v5 beta they are crawled by moi.geometryDatabase.getSelectedObjects() but not by
This has been updated for the next v5 beta so that they will be crawled by getObjects() too.
getSelectedObjects() (and getObjects() in the next v5 beta) can also take an optional true/false parameter for whether
to return objects inside groups or not. By default they will and will have both groups and all the objects inside
the groups within the returned list to help with compatibility with scripts.
So hopefully those scripts should be working ok after the next beta without the scripts needing
any adjustments for group handling.
The main kind of script that the "group crawling" causes problems with is ones that transform objects because
they try to transform the group and also additionally the group's contained objects. So that particular kind
of script needs an adjustment to get only the groups and no crawling which can be done by the true/false
parameter for .getSelectedObjects() and .getObjects() or by calling .excludeGroupChildren() or
.excludeGroupChildrenInPlace() on the object list which will remove objects in an object list that are contained
inside of any group also in the list.
10815.20 In reply to 10815.17
<< You are already informed of that currently in the properties panel:
Yes you right but it's some limited! ;)
Seems this is more informative! You see in a glance composition of any group!
10815.21 In reply to 10815.20
That is true. But what is it that you are gaining from knowing that information?
10815.22 In reply to 10815.18
- I'm sorry, Michael for that, my bad.
I tried a little to understand the groups in Mol and it wasn't that hard at all, I have to admit that once it's caught it is not that complicated and it really has logic and consistency which makes it very useful on a daily basis.
I will never again doubt your talent and passion to make MoI such wonderful tool for us.
Marek
10815.23 In reply to 10815.22
Thanks Marek!
10815.24 In reply to 10815.21
<< what is it that you are gaining from knowing that information?
A total speedy knowledge of any grouped piece(s)!
Number (& composition) of screws, bolts, bricks, gears, beams, truss ...anything...
Very useful for estimate cost, surface, volume, weight ...etc...of somethings
Seems very useful for a minimum place on the screen for a maximum info!
etc...
10815.25 In reply to 10815.24
> Very useful for estimate cost, surface, volume ...etc...of something
> Seems very useful for a minimum place on the screen...
These types of uses can be handled fine by something like generating a report with that information in it. In general it's not good to display too much information all at once on the screen all the time because it contributes to making a noisy and busy UI.
Really that type of thing is better handled by a more developed instancing mechanism though and not just by having a name property that is the same on each object. It's too easy for there to be 2 different objects that have the same name and would be mistakenly counted as the same object when they are not. Instancing would ensure they are copies of a common base template.
So maybe something like that could be appropriate in the instancing UI, we'll see.
10815.26 In reply to 10815.25
New Instancing in the V5 ?
<< It's too easy for there to be 2 different objects that have the same name and would be mistakenly counted as the same object when they are not.
so forbid a same name for a strict politic of structured data ?
10815.27 In reply to 10815.26
I don't know when instancing will be ready, I think I'll probably be shooting for groups and folders in v5 and instancing probably won't be in the v5 timeframe.
10815.28 In reply to 10815.26
MoI has supported having the same name on multiple objects as a simple way to make a type of one level group for a long time now, so no forbidding that would not fit in very well for MoI.
Instancing would be the way to make that type of structured data.
10815.29 In reply to 10815.28
OK thx for the infos!
Thanks for your Answers
P.
10815.31 In reply to 10815.28
Michael,
I’ll describe my experience with naming and groups in v5, especially what happened before I had any understanding of groups. I was working on a model consisting of multiple objects and clicked on the name of a first object in the Objects section of the scene browser. Poof: a second object vanished from the browser. My immediate panicked reaction was that I had triggered some bug that caused part of my model to be deleted. I now understand that the first object, being selected, was simply assigned the name of the second object, but it took some experimenting to figure that out.
Why did I click the name of an object in the browser? Because that’s how I edit object names in Illustrator and Corel: double click the name to make it editable. I also make this mistake in v4, but there it’s benign because clicking an object name doesn’t do anything. Since I switch back and forth between MoI, Illustrator, and Corel multiple times a day, breaking my habit of clicking object names to rename them will be difficult. But, now I know what’s going on in MoI v5 and simply hit undo.
I think I’ll come to like clicking on a group name to add a selected item to that group. In Illustrator and Corel I often have problems dragging an item through a long list in the Layers Palette so that I can drop it on another item for the purpose of grouping. Click to group avoids that problem.
What I don’t think I’ll like is clicking on an object name to assign that name to another, selected, object. I don’t expect coming to like this because of the vanishing object problem described above.
One solution I see is to deprecate object naming as a means of grouping. I understand that this has been part of MoI for a long time, but now that you’ve come out with hierarchical groups, what is the value of name grouping? In addition to the disappearing object problem that new users like me may stumble over, it creates an inconsistency when coexisting with groups: I can give 2 groups the same name, but that doesn’t cause them to combine. I can even give 2 objects the same name, but not have them be grouped if they are at different levels in the group hierarchy:
However, if I Ungroup the 2nd "foo" the 2 objects named "sphere" get combined into a name group, which might not be what I intended:
An additional benefit of doing away with grouping objects by name involves "Unnamed". Now, every object that I make goes into the name group called Unnamed unless I take the trouble to give it a unique name. I can only easily assign it a name if the operation that created the object left the object selected. Many operations don't do that, so then I have to run a script to select the last created objects, or I have to visually find the object that I wish to rename in one of the viewports, select it, and then go over to the properties panel to rename it. Unnamed acts like a junk drawer that's not only disorganized, but locked. If a junk drawer is necessary, a group called something like "Unnamed" might be better. Or, newly created objects could just be thrown into the top level of the group hierarchy as is done in Illustrator and Corel. I'm not sure which is better.
Newly created objects that have not yet been renamed by the user could even get descriptive default names based on the operation that created them such as "Plane", "Loft", or "Name of Script".
I'm sure that deprecating grouping by name would have consequences that I don't understand. Using v4 to open the 3dm file associated with the screenshots above has both objects named "sphere" get combined into a name group, so killing name grouping in v5 seems like it would be tolerated by v4. Opening a v4 file with v5 would require that a name group be converted to a hierarchical group which is not a function that exists now. Another immediate consequence that comes to mind would be the question of what scripts containing moi.geometryDatabase.selectNamed(‘name’) should do. I imagine this method would need to be changed so that it accepts group names if there are scripts in the wild using this method.
Are there severe insurmountable problems that will arise if grouping by name is deprecated? Will there be ongoing value from keeping the group by name mechanism?
- Peer
Seems for have no troubles best is all name with different name! ;)
Show messages:  1-12  13-32  33-36
