Dark Neutral Grey UI Complete with Instructions
 1-4  5-24  25-44  45-54
10465.25 In reply to 10465.24
Hi folks, I am new to this forum and have discovered the great Moi 3D program, many thanks to Michael.
I also beautified the Moi surface, many thanks to Tod.
However, I get an error message:
[url = https: //postimg.cc/347f40Y8] [img] https://i.postimg.cc/pT5wSKSF/Ohne-Titel.png [/ img] [/ url]
I also don't see the Reverse.png icon (in the Moi interface) I followed the instructions exactly.
Maybe I'll make a mistake, I would be very grateful for any help.
I have an iMAC 3.8 GHz with Big Sur, I know whether the uploading of the picture worked, otherwise please provide instructions on how to upload pictures in the forum.
I apologize for my english, i use google to translate.
Warm greetings
Pit
10465.26 In reply to 10465.25
Hi Pieter, to insert an image put it in like this:
<img src="http://url_goes_here">
10465.27 In reply to 10465.25
So for your image set it in your forum message like this:
<img src="https://i.postimg.cc/pT5wSKSF/Ohne-Titel.png">
For the error message, have you possibly removed the scene browser with some of your changes?
If so then you'll need to modify DeathPane.js and remove the piece of it where it is trying to access the scene browser and expand the sections during program startup.
That would be the part that goes like this:
var items = moi.ui.sceneBrowser.rootItems;
for ( var i = 0; i < items.length; ++i )
    items[i].expanded = true;
10465.28 In reply to 10465.27
No I have not removed anything when I read the lines:
delete the error message is gone. Thanks.
How do I get the Reverse.png icon into my Moi interface?
LG Pit
10465.29 In reply to 10465.28
That answer is in the instructions...
Under: C) UNRAR THE UI
5.) copy the "Reverse.png" image from the new "C:\Users\YOUR WINDOWS USERNAME\AppData\Roaming\MoI\ui"
to the:
"C:\Program Files\Moi 4.0\ui" directory
10465.30 In reply to 10465.29
that's exactly what I did. But that doesn't work on the Mac!
"/Users/pit/Library/Application Support/Moi/ui"
"/Users/pit/Programme/Moi 4.0/ui"
I did that.
EDITED: 14 Nov 2021 by PIETER
10465.31 In reply to 10465.30
I don't know Macs, this was made for windows...
I assume the:
/Users/Pit/Programme/Moi 4.0/ui
is the actual folder where the MoI program resides on a Mac? If not, it needs to go to the actual Moi installation folder, NOT the user's folder.
Maybe somebody here with a Mac has an answer?
10465.32 In reply to 10465.30
On Mac, right-click on the .app and on the menu that pops up choose "Show package contents". Then there is a "ui" symlink there that will take you to the ui folder which is located inside the app folder under Contents/Resources/ui .
The direct path if you have installed MoI v4.app inside of the /Applications folder is:
/Applications/MoI v4.app/Contents/Resources/ui
Note that on a Mac an .app is actually a folder but when you double click on an app it launches the app and doesn't open up the folder as normally happens with other folders. But to open up an app as a folder you can right click on it and choose "Show package contents".
10465.33 In reply to 10465.17
@thejinx:
Regarding the easier install:
After having checked out a few installers available the last few days, I have come to the conclusion that it would be easier to write one myself.
I can now be found in a separate thread this one is getting too crowded...
The thread is:
Easy Installer Dark Neutral Grey UI Complete with Instructions
http://moi3d.com/forum/messages.php?webtag=MOI&msg=10509.1
It creates everything automatically.
EDITED: 14 Nov 2021 by DEATH
10465.34 In reply to 10465.32
Thanks Michael but I've already tried that, unfortunately without success.
10465.35 In reply to 10465.34
Hi Pieter,
Can you show a screenshot of where you have placed it?
10465.36 In reply to 10465.35
Hallo Michael kann es sein das ich noch die 90 Tage Test Version benutze?
10465.37 In reply to 10465.36
Hi Pieter, it should work the same with the trial version.
10465.38 In reply to 10465.37
Hello Michael, here is the screenshot (hopefully the screenshot will also work).
-Pieter
10465.39 In reply to 10465.38
Hi Pieter, I'm able to see your screenshot if I navigate directly to the image URL. I think that service isn't allowing images to be hotlinked from another web site.
So anyway yes that looks like you've got it in the correct place.
What does the place where it is supposed to show up look like? Is there a placeholder icon there? If not then there is probably another file that also needs to be updated to set up the button that then wants to use the image.
10465.40 In reply to 10465.38
Hi Pieter, I think the file that uses the image is ViewControls.htm , so update that file as well, in the same folder.
10465.41 In reply to 10465.40
it worked now my moi is complete, you are my hero many thanks for your effort and patience !!!
Many greetings
Pieter
10465.42 In reply to 10465.20
what do you mean when the Moi v 5 is to be bought?
-Pieter
10465.43 In reply to 10465.42
HI Pieter, sorry I don't have any idea yet when v5 will be released. The beta test period hasn't even started yet but that should get going pretty soon.
10465.44 In reply to 10465.33
I tried the installer and it worked.
But there are number of things I need to bring over from the existing MOI setup.
So for now I renamed the MOI AppData folders and my MOI was back EXCEPT it was still a dark scheme while mine was light.
What controls that?
Thanks much. Great work.
Frederick
Show messages:  1-4  5-24  25-44  45-54
