Dark Neutral Grey UI Complete with Instructions
 1  2-21  22-41  42-54
10465.2 In reply to 10465.1
OP == MVP of the Universe; this is pure gold, it's appreciated!!!!
10465.3
One question, I'm not seeing the deathUI.rar file nor .css file, what did I miss?
https://imgur.com/E5HCOnl
10465.4 In reply to 10465.3
Sorry, I renamed it, it's all good now....
It's at the bottom of the message, below the pics.
The CSS is in the ui directoy after the unrar. See step D.
10465.5
Thanks for the nice theme - i really like it.
But i'm missing the reverse button in the viewports and all scripts in the extra folder are not found. Everything else works like charme.
10465.6 In reply to 10465.5
Hi binfordboy,
Your problem with Extra directory is a parameter to modify in the moi.ini file in the Commands section.
Set with your own windows user_login to fix the problem
[Commands]
AdditionalCommandsDirs=C:\Users\***USER_LOGIN***\AppData\Roaming\MoI\extras
10465.7 In reply to 10465.6
Thank you, that fixed it.
10465.8 In reply to 10465.7
Read Step 4 and 5 under section C (UNRAR THE UI) above, they are new and fix the issues.
I also update the download file to include the extra instructions, so everything is up to date, you might want to re-download the "Death UI.rar" again to have the latest version; in case you ever want to modd your UI from scratch again. That way the instructions included are also corrected.
10465.9 In reply to 10465.8
Death,
Very nice job !
Thanks a lot.
10465.10 In reply to 10465.9
You're welcome, just trying to give back to the wonderful people here!
10465.11
ohayo !
how did u manage to have several folders with kitbash ?
- Tudor -
10465.12 In reply to 10465.11
Read the "Death UI Modding.txt" file, it's all explained in there (step by step on how to do your own library folders)
It is included in the "Death UI.rar" you can download at the bottom of the first post.
Have fun!
10465.13 In reply to 10465.12
Hi. when for Mac?
10465.14 In reply to 10465.13
Hi mercar,
> Hi. when for Mac?
It should probably work on the Mac version. The appdata folder on Mac is at ~/Library/Application Support/Moi .
10465.15
Thanks for this :)
10465.16
Shortcut Keys descriptions for those who don't want to download the .RAR file again...
View Keys
Home: Resets 3D view to normal view (like the reset button)
Shift+Home: Resets the 3D view to normal, including the orientation
Alt+Home: Isometric 3D View
Ctrl+Home: Perspective 3D View (to get back from Isometric to normal view)
Numpad+: Zoom in 3D View
Numpad-: Zoom out 3D View
Space: Toggles betwen views. I.e.: If mouse is in top view space switches to 1 view only (the top), hit space again, it goes back to split view. works on all views that way. Convenient way to select a "big screen work view" then back to normal.
End: Toggles hidden line display.
V: Switches between saved 3D views
Shift+V: Save snapshot of current 3D view
Alt+V: Clear ALL the saved views
(Extremely useful! Press shift V to save the 3D view, go to other side of model, save that view, now you have 2 work views to toggle between every time you hit V.
You are not limited to 2 views either. Save 1, save 10 or whatever.)
Arrow and Page keys:
LeftArrow: Nudge Left
Ctrl+LeftArrow: Nudge Left Small increment
Alt+LeftArrow: Nudge Left Large increment
RightArrow: Nudge Right
Ctrl+RightArrow: Nudge Right Small
Alt+RightArrow: Nudge Right Large
UpArrow: Nudge Up
Ctrl+UpArrow: Nudge Up Small
Alt+UpArrow: Nudge Up Large
DownArrow: Nudge Down
Ctrl+DownArrow: Nudge Down Small
Alt+DownArrow: Nudge Down Large
PageDown: Nudge ZDown
Ctrl+PageDown: Nudge ZDown Small
Alt+PageDown: Nudge ZDown Large
PageUp: Nudge ZUp
Ctrl+PageUp: Nudge ZUp Small
Alt+PageUp: Nudge ZUp Large
Other Keys
Delete: Delete
A: Align
N: Highlight naked edges
S: Cycle selected by their type. (Select an edge, face, object, curve etc., then pressing S cycles to the next one of the selected kind)
Alt+Q: Screen capture 1280 x 800 to clipboard, with white background
Ctrl+Q: Screen capture1280 x 800 to clipboard, normal viewport
The Usual:
F1: Help
Ctrl+N: New
Ctrl+O: Open
Ctrl+S: Save
Ctrl+A: Select ALL
Ctrl+C: CopyClipboard
Ctrl+V: Paste
Ctrl+Shift+C: CopyClipboardWithOrigin
Ctrl+Shift+V: PastePart and orient Origin
Ctrl+X: Cut
Ctrl+Y: Redo
Ctrl+Z: Undo
10465.17 In reply to 10465.16
Hi Jack, thanks so much for putting all of this together, it's super useful and has saved me tons of time!
Just wondered if a small niggle I'm experiencing with the theme is to be expected or not...
The command panels (Draw/Edit, Construct/Transform) are all open at once, which is fantastic and exactly what I am after, which looks just like this:
When I choose a command though, all panels except the one containing the selected command collapse, and I have to re-open the panels again.
E.g. If I create a primitive by clicking Box within Draw/Edit, this happens:
And when nothing is selected after the command has completed, the panels remain closed, needing to be manually re-opened (Draw/Edit collapsed):
Is there anything I can do to keep those panels open at all times, or at least to expand when I don't already have an active tool selection?
For bonus points, is it also possible to collapse the void at the top of the panel when the information/inspector panel isn't present, like this?:
Also, I had a thought when doing the install of your excellent ui; would an installation helper be of any use? A batch or exe file which could perform the various backups and drop the files into their relevant locations without needing further user input?
Seems like a weakness of how modifications work in general and might bring things like your UI to more people?
Anyways, thanks so much in advance!
Option / General / UI Size is the parameter you searched.
with 9.5 or less, you'll have no problem.
10465.19 In reply to 10465.17
Like Phiro said.
That is also in the instructions...
Under NECESSARY CHANGES:
3. Scroll the UI slider to 9.5
Anyway, they collapse because your screen space is limited and new panel areas opening claim it.
Making an installer was on my mind,but then I thought about all the stuff that can happen if the user doesn't have administrator privileges. The clean up of the mess would be more work than doing it as is.
If I closed the top gap (used by filename, entry panels etc.) the the ui would jump about every time you use a command with input and the vertical position of the commands would change all the time, not nice behavior.
(BTW, the dimensions panel and its options is also always open. You might want to download the .rar file again and extract the SidePane.htm file and replace the one in your c:\user\YOURUSERNAME\appdata\roaming\moi\ui directory.)
I'll do some research on installers and if it pans out automate the whole process...
EDITED: 6 Nov 2021 by DEATH
10465.20 In reply to 10465.19
There will be a new UI theming mechanism for v5. The way it works is there is a new "themes" folder inside the Moi appdata folder. Themes are created as a sub-directory under there.
A theme contains a defines.inc text file which sets up symbol definitions for things like:
TEXT_COLOR #ABFF5D
The UI has been updated to use those symbols, like moi.css will have color:$$TEXT_COLOR$$; in it.
When moi.css or any .htm file is loaded it will be scanned for $$symbols$$ and have the value from the theme's defines.inc expanded in place of the symbol.
The theme folder can also have its own moi.css file which will get appended to the end of the regular moi.css file when the theme is active, and any images in the themes folder will be used in place of the standard image.
There will be 2 themes built in to the standard install, "Default" (similar to the current standard UI) and "Dark".
There will be a theme manager UI where you can make a new theme (which will create a new theme folder in appdata) and adjust color values:
EDITED: 6 Nov 2021 by MICHAEL GIBSON
10465.21 In reply to 10465.20
Very, very, very cool!
That's what I always wanted.
Thanks!
Show messages:  1  2-21  22-41  42-54
