V5 Wish List
 1-17  …  598-617  618-637  638-656
10114.638
Hey Michael,
Any chance to get depth/height map output?
Also, hoping to get "Save custom CPlane(s)"
http://moi3d.com/forum/index.php?webtag=MOI&msg=10744.3
This would be great because I was trying to model an articulation along the array with RotateArray; items on & along a conveyor being the example.
If a "Plane Object" could be part of a group, for instance, and RotateArray could accept it as an argument, then it could be repositioned with an initial call and subsequent RotateArray calls could pick-up the cause.
Additionally, it would indeed be wonderful if RotateArray could also work with circular arrays.
Truly LOVE your software!
Many thanks,
Moi Bueno
MindSet
EDITED: 18 Oct 2024 by IGNITER
10114.639 In reply to 10114.638
Hi MindSet,
That's usually a rendering type function but currently MoI doesn't try to do rendering.
> It would indeed be wonderful if RotateArray could also work with circular arrays.
It should be working with circular arrays. It needs a point object to be included with the array, are you possibly missing that?
Here's what I tried - Circular array:
With RotateArray applied:
10114.640
Tab or some other key code to skip through items under the cursor to select elements that are in the same plane or under each other...I got rid of horrible horrible Revit years ago but still miss this feature!
// Rich
10114.641
My personal wish list contribution is for the SVG export feature to have an option for users to choose whether they want the exported item to be outlined, solid, or both, with "outline + solid" being the default.
Just a suggestion.
EDIT FOR EXPLANATION: As SVG files are comprised of markup code, I have a feeling it'll be as easy as changing a few lines to reflect whether the shape is outlined, solid, or solid with an outline. Granted, straight-line shapes - and open curves in general - might have to be outline only so that they show up in a software program.
EDITED: 15 Jun 2025 by SIERRA-D421
My personnal request for the roadmap.
Have options for import obj files (SubD/Create/From file).
- rebuild the surfaces (yes/no)
- Apply a Subd (yes/no)
I know the fonctionnality is in subd but it is an import Obj feature too.
This is why I think applying subd could be an option.
Best regards
10114.643
On-screen manipulators would be interesting for non-technical creation in MoI.
-Manipulator for fillet diameters.
-Manipulators for blend in 2D or 3D, intersecting points, and bulge.
Scrubbers next to numerical input would work, but on-screen would be more hands-on.
Keep up the amazing work !
Marc
10114.644 In reply to 10114.643
Hi Marc,
An on-screen manipulator for fillet diameter already exists. Click once in a viewport and then move the mouse. The fillet radius will continuously update to match the distance between the point and the mouse.
- Peer
10114.645 In reply to 10114.644
Hi Peer,
You are referring to entering the distance by clicking two points ?
It's indeed a very useful method for the radius.
I was thinking about a more direct manipulation, a bit like extrude where the object updates automatically as you move the mouse.
It could provide a fast visual feedback when in the design stage or research.
I remember in Rhino there was a gizmo that you can pull on to adjust the radius.
This ?
My Moi French Site
10114.647
Exactement Pilou,
Is this in the beta version?
I have V4 and it does not appear to work.
On another note, I saw this in a comic recently, odd name for a ship!
10114.648 In reply to 10114.647
@Marc,
Yes it's new in v5.
10114.649 In reply to 10114.647
Yes phonetic like Pilou but it's not the true Pilou! :D
Moebius ?
10114.650
Oh, I didn't saw this new feature.
Most excellent !
Pilou : Indeed Moebius :)
10114.651
Would be so good for documentation / trouble shooting...
https://www.youtube.com/watch?v=0v_2DGGsPJY
// Rich
10114.652
Geometry Constrain
Message 10114.653 deleted 13 Oct 2025 by -RB-
10114.654 In reply to 10114.642
@phiro
'My personnal request for the roadmap.
This is why I think applying subd could be an option.'
Yes this would be a good workflow time saver I agree! The current finding-a-separate-app-on-site and saving out a separate 3dm is a bit perplexing, I don't even know if some current users know it can be done
// Rich
10114.655
Hello Michael,
The ability to lock-down portions of curve when editing by control-points would be wonderful.
Could fit/position one portion of the curve and then set to have that portion resist any change while adjusting its adjoining portion.
The Lock Command doesn't seem to work on control points. Maybe some other function might be required.
Hope this can work.
Thanks for all that you do!
10114.656 In reply to 10114.655
Hi Mindset,
Yes, control points don't have the full set of object properties like name, hidden, locked, styleindex, etc...
It's problematic to have those because it's not unusual for surfaces to have several thousand control points and having a full set of object properties for each one could potentially increase memory consumption by a large amount.
It could also cause a lot more calculation to happen for the scene browser.
Show messages:  1-17  …  578-597  598-617  618-637  638-656
