V5 Wish List
 1-3  …  544-563  564-583  584-603  604-623  624-643  644-656
10114.584 In reply to 10114.582
Hi Phiro,
> We can clearly see that the number of points created are very different but are there methods to avoid
> and/or others which will be more desirable.
Usually it would be best to use edge filleting for this, rather than manual construction.
10114.585 In reply to 10114.583
another one
Chri
Size: 149.6 KB, Downloaded: 163 times, Dimensions: 1100x685px
10114.586 In reply to 10114.585
@Chri
Seems very similar to my method above! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=10114.583
PS But careful : verify that volume resulting is a solid...it's more frequently a "linked surfaces"!
10114.587
感谢各位,看到各位的回复。
的确,这样做是可行的。我在v4时期就是这样修补圆角的https://www.bilibili.com/video/BV1Zq4y197ii?p=5
我所表达意思是NSIDED产生面的效果不够好,例图:
(Thank you all for your responses.
Indeed, this is feasible. This is how I repaired the rounded corners during the v4 era ,What I mean is that the effect of the NSIDED generated surface is not good enough, as shown in the example image:)
可以看到,使用NSIDED产生曲面的部分,曲面被分成多块,并且衔接处过渡不够光顺。
至于圆角的例子是因为原本我想做球化圆角(如CATIA那样的熔接面)而恰好NSIDED对这种情况效果不佳。我知道用Network等方式能达到更理想的效果,但这与展现的效果有差距。(http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=10714.1)
(As can be seen, the part of the surface generated using NSIDED is divided into multiple blocks, and the transitions at the junctions are not smooth enough.
As for the example of rounded corners, it was because I originally wanted to do spheroidized fillets (such as CATIA fusion surfaces), but NSIDED happened to have a poor effect on this situation. I know that using methods such as Network can achieve more ideal results, but there is a gap between this and the displayed effect.)
10114.588 In reply to 10114.587
Hi SUIYAN, you might want to check out using sub-d modeling for making a shape like that.
It can be easier to generate a shape that is smooth all over in sub-d rather than trying to build it in a "fill in patch by patch" type of process.
10114.589 In reply to 10114.588
GOOD DAY Michael
期待SUB-D工具,其实Nside的效果是不错的,我做了一个球化圆角(Looking forward to the SUB-D tool, in fact, the effect of Nside is good. I made a spherical rounded corner)
我希望Nside产生的面是一个完整的面,而不是缝合的。我知道对于尖角和转折,问题难以解决。使用三角面拼接能够填充尖角和转折这是一个好方法,但仍希望能够融合成一个面。
(I hope that the surface generated by Nside is a complete surface, not a stitched one. I know that for sharp corners and turning points, the problem is difficult to solve. Using triangular stitching to fill sharp corners and bends is a good method, but we still hope to merge them into one face.)
我使用直角选项时,我想如果三个尖角能够扩大一点弧长并且位置分别向外指向外侧的三条边的方向,这就是一个球化圆角了。(When I use the right angle option, I think if the three sharp corners can have a vertical radius and their positions point outward in the direction of the three outer edges, it is a spherical rounded corner.)
另外,期待network能增加连续性功能选项,这其他人提过了(Additionally, we look forward to the addition of continuity functionality options in the network, as mentioned by others)
10114.590 In reply to 10114.589
Hi SUIYAN, unfortunately these areas you are asking about are quite difficult and will require a lot of work. So they are not likely to happen anytime soon.
10114.591 In reply to 10114.590
Hi Michael
>我希望Nside产生的面是一个完整的面,而不是缝合的。(I hope that the surface generated by Nside is a complete surface, not join)
突然想到,Nside问题不需要直接形成完整曲面而是通过合并布尔。还记得这个讨论吗?Suddenly, it occurred to me that the problem with Nside does not require directly forming a complete surface, but rather through Boolean Union. Do you still remember this discussion?
(http://moi3d.com/forum/messages.php?webtag=MOI&msg=11426.1)
You Said> in the future I would like to enable more cases where surfaces can get merged with Boolean Union. Currently it's only supported for 2 coplanar planes or when the 2 surfaces are trimmed pieces of the same larger underlying surface.
我想完成这些,就可以通过布尔形成完整的曲面了。(I want to complete these so that I can form a complete surface through Boolean.)
10114.592 In reply to 10114.591
Hi SUIYAN,
Right, that will be for things like the 2 surfaces are pieces of some larger surface like 2 pieces of a sphere with the same center and radius, or 2 extrusions from the same base curve and direction.
The surfaces from NSided are not like that.
10114.593
A few UI enhancements for improving the already very good default experience:
- Have the Objects/Type/Styles sections already open at startup (or remember their state across starts)
- Option to separate the Construct/Transform sections: I personally find myself switching between the two frequently and for 27" or larger screens there is enough vertical space to make both directly accessible
- Configure some default keyboard shortcuts for various frequently used tools: This greatly increases the efficiency and it's kind of hard to find out the right commands for configuring those manually
Since the added grouping support in V5 allows to construct more complex designs, it would be nice to have a variation on the orbit mechanics that rotates around the first point of contact below the mouse cursor. Same goes for zoom and pan for scaling the speed/step size. This would allow comfortably working on details in parts of the model that are further from the origin.
10114.594 In reply to 10114.593
Why don't use this sort of floating window ?
https://moi3d.com/forum/index.php?webtag=MOI&msg=9758.1
But you must see all the thread if you want some more refinements! ;)
EDITED: 20 Jun 2024 by PILOU
Seems the floating window still works on V4 ! :)
but not on Beta V5! :(
My Shortcut seems good!
I have only this ! (no error message)
When I right Click on it (red x) : i have only Move & Size clickable
Move is Ok
Size don't works! :(
10114.596 In reply to 10114.593
Hi Sönke,
Re:
That exists now with the Area widget:
The first step in Area is picking a 3D point. That becomes the new pivot point for orbiting.
Another way set the pivot point is with Reset. The new pivot point is the center of the selection that exists when Reset is clicked.
- Peer
10114.597 In reply to 10114.594
That might be an alternative, although it makes sense to use the space that is already available in the side bar. But, although I know that you can customize a lot, I think it would be nice to have a few basic things available by default, as my guess (could be wrong of course) is that most users don't even go as far as using a pre-made script.
10114.598 In reply to 10114.596
Thanks, I didn't realize that, good to know! This definitely has its advantages over the proposed orbit mode. On the other hand, a navigation mode like that would be more dynamic (less clicks/mode switches) and is very popular in all kinds of 3D software, so IMO it would still make sense - especially considering that there are already multiple alternative modes and it wouldn't really add complexity to the UI.
10114.599 In reply to 10114.593
Hi Sönke, thanks for this feedback.
See here for how to set that up:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9157.2
For separating all of them, see here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9439.3
For separating just Construct/Transform here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.487
> those manually
There is a list of command names here:
https://moi3d.com/4.0/docs/moi_command_reference11.htm#shortcutkeys
The design for shortcut keys in MoI is that only a basic set common to all apps like copy/paste are defined by default. Other shortcuts can be defined by the user according to their preferences.
MoI was actually designed initially to be able to function without needing the keyboard at all.
10114.600 In reply to 10114.595
HI Pilou
可能你需要覆盖一下SidePane1.htm文件到D:\Program Files\MoI 5.0\ui
(Perhaps you need to overwrite the SidePane1.htm file to D: \ Program Files \ MoI 5.0 \ ui)
并重新设置快捷键(And reset the shortcut keys):script: var panel = null; try { panel = moi.ui.getUIPanel( 'moi://ui/SidePane1.htm' ); } catch(e){} if ( panel ) { panel.moiWindow.close(); } else { moi.ui.createDialog( 'SidePane1.htm' ); }
有时可能需要重新设置以能够正确调用(Sometimes it may be necessary to reset to be able to call correctly)
也可能只是你的快捷键设置的问题,我遇到过这样的问题,请先重新设置快捷键,而不要冒然替换SidePane1.htm以避免出现新的问题(有时两个值都能完成调用,但只要一个值能够保证不失效。你需要这个值。)
(It may also be just a problem with your shortcut key settings. I have encountered such a problem before. Please reset the shortcut key first, and do not replace SidePane1.htm recklessly to avoid new problems (sometimes both values can be called, but only one value can be guaranteed to not be invalid. You need this value.)
EDITED: 20 Jun 2024 by SUIYAN
10114.601 In reply to 10114.600
In fact seems i had an old version of the SidePane1.htm !
But thx for the infos!
10114.602
I'd love to see one thing in particular...
Open/Save as 3DM Version 7. Currently, I'm having to use converters to open V7 3DMs converted to V5, and they don't always work well. Having this ability natively would be a huge boon.
10114.603
I just started using the property preset in the dimensions setting. It is actually a very useful feature!
Would it be possible to apply the preset to existing dimensions? Currently, if a select one and then click on details to show the object properties, there is no option to apply a preset.
That would make possible to quickly update different dimensions at the same time.
Salvatore
Show messages:  1-3  …  524-543  544-563  564-583  584-603  604-623  624-643  644-656
