V5 Wish List
 1-7  …  408-427  428-447  448-467  468-487  488-507  …  648-656
10114.448 In reply to 10114.447
> Hi Larry, re: object dump method - if you could give a more complete spec of exactly what output you would want that would help.
Not knowing what’s inside "the box" makes it challenging to provide a more complete spec, hence my explanation of how I’d make use of whatever info could reasonably be provided. So, guessing at the box’s contents, perhaps something along the lines of:
object type: MoI object class/subclass name, e.g. ObjectList or curve
    object properties:
        name: value (perhaps RO, or RW)
    object methods: (this is maybe too much to suggest)
        name: brief parameter description
I’m thinking that this sort of information would be used in the context of moi.ui.alert() or moi.log() and would be intended to help someone writing a script diagnose issues while debugging. I think this helps to address a class of mistakes that arise from a misunderstanding of the object model. Perhaps there are other attributes that might make sense in this context.
As an example of where a dump tool might help: I kept getting “calculation failed” from my attempts to use the offset factory and after a bunch of flailing about the lightbulb finally came on: I was passing in a drawing object as input 0 when offset expects an ObjectList. I had been convinced (and thus focused on) that I was not passing input 2 (the offset point) properly instead of realizing that I’d provided the wrong object type. Having (and using!) a dump tool would have exposed my mistake.
Perhaps such an effort is a step toward some future enhanced scripting environment; my intention is to suggest work that ideally benefits your future aims while providing value for users who are trying to write and debug their scripts. Maybe V5 provides some beneficial low hanging fruit, but V6 expands upon it as you see fit; the output of the dump would grow and change as MoI evolves.
--Larry
EDITED: 7 Dec 2022 by FAHNOE
10114.449 In reply to 10114.448
Hi Larry, I've updated a couple of scripting things for the next v5 beta to help with that.
The first thing is that all MoI script objects implement a .toString() function that will return the specific object name rather than a generic "MoiObj" name which used to be returned for every object previously.
So for example this:
var obj = moi.geometryDatabase.createObjectList();
var text = obj.toString();
will now generate [object ObjectList] instead of [object MoiObj].
Then the other thing is that property enumeration using the "for...in" syntax will now work on MoI script objects which wasn't implemented previously. Methods will also show up in the enumeration as properties that have a value of '[object Function]'.
So that should enable making a dump function like you're asking about, something like:
function dump( obj )
    for ( propname in obj )
        text += '\n' + propname + '=' + obj[propname].toString();
    return text;
10114.450 In reply to 10114.449
Wow, thanks Santa!! :-)
That will be quite nice as it is a bit frustrating to see [object MoiObj] when what I really wanted to see was *which* MoI object it was.
I think this along with your example dump() will go a long way towards helping script developers have some better insight into the objects
being used. Maybe someday the methods could be fleshed out with their parameters which then makes them somewhat self-documenting.
I'd vote to see dump() show up as dump.js in MoI so that other scripts could simply #include and use it, along with mentions in the release
notes or command reference of course. :-)
Many thanks for such a quick solution!!
--Larry
10114.451 In reply to 10114.450
Thanks Michael and Larry! Sounds like some handy new functionality.
- Peer
10114.452
Good day.
This probably was requested at some time....
Ussually I work in Moi3d and then import in Vectric.
The request would be distort and or the ability to group items and then distort.
Hope this can make it in future version.
Thank you!
Size: 43.5 KB, Downloaded: 171 times, Dimensions: 717x436px
10114.453 In reply to 10114.452
Hi Matadem,
You can do that in the current version using the Transform > Deform > Flow command.
Set up one plane underneath your curves, copy the plane and edit its points to distort it and then use Transform > Deform > Flow to map from the base plane to the distorted one. Note - make sure you edit the points on the distorted one, don't form a trimmed surface using Construct > Planar because that has a non-distorted plane as its underlying surface:
10114.454
Thank you for the reply.
Maybe I should have used the word warp.
I just found out yesterday that new affinity designer v2 have warp and dxf import not export.
This is wat I refer to https://www.youtube.com/watch?v=xGZqXYd1czw
If something like this could make it into Moi3d ...warp your designs, your 3d model or warp your design than extrude it would be great.(cnc cutters, vinyl cutters and laser cutters :D ).
Thank you!
Message 10114.455 deleted 9 Dec 2022 by BEMFARMER
10114.456 In reply to 10114.454
Hi Matadem,
Yes, there is a "Flow" function already in Moi under Transform > Deform > Flow that can be used for doing similar things now:
https://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
To use it you set up 2 surfaces, one is a rectangle surface under your base objects and the second one is a deformed target surface.
Here's an example in MoI:
10114.457
Hello Michael,
Is it possible to have the following ability (or do we have it currently) :
To be able to have control points of a curve duplicated by holding Ctrl/Command key. (If I want to elaborate on it better I would say please take a look at the attached image. in the image you can see a circle with half of its control points selected I would like to be able to duplicate those selected control points and adjust the shape of the curve by moving selected control points to the right side getting the second curve u see below the circle) (I imagine this could be helpful because it works even faster in some cases) (and it is just a thought)
10114.458 In reply to 10114.457
Maybe Flow function can do that again... ?
EDITED: 11 Dec 2022 by PILOU
10114.459 In reply to 10114.457
Extrude with Set Path looks promising, with a semicircle as initial curve.
A few additional steps would be needed...
Maybe a short script could be done...
10114.460 In reply to 10114.457
Hi Psygorn,
Currently if you hold down the Ctrl key when you drag on an object it will drag a copy of the object, including if you drag control points.
10114.461 In reply to 10114.460
Yes I just thought out loud ( just thought this could open a fast way to manipulate curve shapes for example turning a circle into a pill shape ) Just a thought!
and maybe my explanation was not good I meant I just want control points to be copied. Currently when we Ctrl+drag the control points the curve is also copied with them.
It was just a thought dear Michael. I apologize if it sounds absurd! sorry.
10114.462 In reply to 10114.459
Hi bemfarmer,
I meant I wish I could only duplicate control points when holding Ctrl+drag on them. and I thought maybe with this ability (being able to copy only control points then we could be able to manipulate curves shapes with more speed.
For example imagine u could create pillshape just by selecting half of the control points of a circle and drag them to another side. It was just a thought!
10114.463 In reply to 10114.461
Hi Psygorn,
Hmmm, well looking more closely at your example it looks like only 2 of the points out of the ones you selected are copied:
Then there are 4 completely new points inserted that do not correspond to any previous point, so those are not really "copies":
I'm sorry but it would be pretty strange to have a dedicated keyboard shortcut that would copy only some of the current selected points, not all of them, and then additionally insert new points that work just for this one very specific case of making a pill shape.
In the future I do want to add some symmetry editing tools, maybe those would help with this particular case as well.
10114.464 In reply to 10114.463
Ah ok, Tanx :)
Edit: Dear Michael, I did the following to make pill shape -> Trimmed a Circle put a distance between the produced semi circles and then connected them with two lines and joined them I guess that is why there are more points. However, while I was doing it I thought if we could just select half of the control points and then drag them to another side while holding down control and ending up with the pill shape we could have a faster work fellow. I thought this Idea is aligned with the philosophy behind MOI3D which is "Speed". But now I think I need to apologize maybe my idea is not a good one! sorry! and thank you for your time. :-)
EDITED: 11 Dec 2022 by DRILLBIT
10114.465 In reply to 10114.464
Hi Psygorn, no problem. But yes the trim does end up inserting some key points to make a result that keeps the circular shape intact.
If you just tried to move control points alone it's not going to be very feasible to get a result that has shaping of exact circular arcs connected by straight lines.
Instead of straight lines it's going to be kind of smoothed out something like this:
It's true that is an important thing. But another part to the philosophy behind MOI3D is to try and keep things streamlined and simple to use and avoid "bloat".
Too many special functions that are used just in really specific cases can end up crowding the UI so much that it becomes more difficult to use overall.
So it would help if there were other kinds of situations where something like that would be useful.
If it's only useful for making pills then the anti-bloat philosophy means that it's preferable to use a combination of existing general purpose tools to make it just like you did use.
10114.466
A Christmas puzzle for Michael?
What about a “nearest neighbor" GeomObject method: given a vector for direction and an optional distance limit, the method would return the next GeomObject along the vector within the limit.
An example use case would be a script modifying a stack of objects where it is inconvenient to select the objects in advance but the user could supply a distance tolerance. The objects may be immediately adjacent to one another or there may be gaps and this would be left to the calling script to control.
An alternative process, using existing capabilities is to use a line and intersect, but that has challenges and limitations. A nearest neighbor method would create possibilities for scripts to examine the model environment. I have no idea of the effort required to implement such a method, but offer it as an idea for your consideration.
Merry Christmas and THANK YOU for MoI, it is a delightful tool!
--Larry
10114.467 In reply to 10114.466
Hi Larry,
Could you describe what the challenges and limitations would be?
Show messages:  1-7  …  388-407  408-427  428-447  448-467  468-487  488-507  508-527  …  648-656
