V5 Wish List
 1-5  …  386-405  406-425  426-445  446-465  466-485  …  646-656
10114.426 In reply to 10114.425
Looking forward to v5, such a great tool for a technical illustrator! :-)
Something like ViewManager would indeed be nice. Perhaps together with a posibility to numerically change the view. I like the control in Teamcenter visualisation.
In snapshot, it’d be cool to have an indication of what slot is in use? And maybe possibility to name them, name showing up like a tooltip or somthing. Also is it doable to have it remember what objects are visible and hidden?
Regards,
- Bengt
10114.427 In reply to 10114.426
Hi Bengt,
There are currently some numeric controls for view angles under Options > View > 3D View angles.
That snapshot function isn't a regular part of MoI, it's from Max Smirnov's CustomUI mod. I don't think he's developing it any further though.
In the future I do want to work on some kind of save/restore state mechanism though.
10114.428 In reply to 10114.420
Michael,
I have two scripting requests:
1) A way to get the point at the center of an object. That is, the point that's shown when Object Snap > Center is on. In other words, something along the lines of propertiesPanel.radius. This is for changing the UV directions of a spherical face for hatching.
2) Harmonize the 5 bounding box methods by adding an optional coordinate frame parameter that defaults to the active cplane. Now, the properties panel bounding boxes are aligned with the cplane, but the others are aligned with world coordinates:
GeomObject.getBoundingBox()
ObjectList.getBoundingBox()
ObjectList.getHighAccuracyBoundingBox()
- Peer
10114.429 In reply to 10114.428
Hi Peer,
There isn't an object snap for the center of a face that is a sphere surface. The one that you get on a regular sphere comes from the center point of its arc edge curve.
I'll see about adding in some script access for conic sections on faces similar to what there is for curves though, and about adding in a coordinate frame optional parameter for bounding boxes.
10114.430 In reply to 10114.429
Michael,
I noticed center snapping on a full sphere, 1/4, and 1/8, and that propertiesPanel.hasRadius seems to be true for any fragment of a sphere, but I guess those are special cases. Thanks for explaining that the center snap point is coming from trim curves.
I don't understand what this means. To me a conic section means a curve.
The problem I'm trying to solve is getting the UV directions on a spherical face to go in the directions that I want. My plan was select the face, get the radius and center, cache the trim curves of the original face, generate a sphere with the same radius and center but with seam orientation picked with something like an orientation picker, remove the original face, trim this new sphere with the cached trim curves, and then join.
I guess I could draw 2 pointObjects snapped to the surface of the face, dropPoint to get uv coordinate points, evaluate normal at each of the uv points, extend a line along each normal, and find the intersection = center. Is that the best way?
10114.431 In reply to 10114.430
Hi Peer,
Do you have an example .3dm of the surface?
There is a shortcut to mark the center point of a curve.
Conics include circle, ellipse, parabola, hyperbola, and line?
10114.432 In reply to 10114.431
Brian,
See attached. The surface is spherical. I want to get the point that's marked with a pointObject. In other words, the center of curvature.
- Peer
10114.433 In reply to 10114.432
For a Spherical cap:
https://en.wikipedia.org/wiki/Spherical_cap
Let d = (r-h)
d = sqrt(r*r - a*a)
r = (a*a + h*h) / 2*h
theta = arcsin(a/r)
Hasty trig math, check for errors:-)
10114.434 In reply to 10114.430
Hi Peer,
Yes you're correct, sorry I used the wrong term there.
Yes, intersecting 2 surface normals would be a way to get the center currently.
You can get 2 UV coordinates using the domain boundaries instead of dropping points.
var minpt = face.domainMin; // 2d point for UV domain min corner.
var maxpt = face.domainMax; // 2d point for UV domain max corner.
Just don't use the min and the max both directly because those will be at each pole and those normals will be colinear.
So maybe something like 1/3 between them for one point and 2/3 between for the other one.
10114.435 In reply to 10114.434
Thanks Michael. domainMin/Max sound very promising. I'll give that approach a try.
- Peer
A way to get two points on the surface:
Select the edge of the cap.
Run MarkCurveEnd for point 1
Run MarkCurveMidpoint for point 2
Run some script to get the two normals, and intersect.
The two normals can be manually found.
So is a utility script to be created for the 2 UV coordinates method?
Array endpoint of edge to edge curve, with 4 points.
This establishes two perpendicular lines, and a plane.
The normal to the two lines, through the Center point of line through endpoint and midpoint, passes through the apex of the cap, and the centerpoint of the sphere, and allows calculation of "h", "a", and "r".
https://web.ma.utexas.edu/users/m408m/Display12-5-4.shtml#:~:text=The%20normal%20to%20the%20plane,%C3%97(s%E2%88%92b).
Enough math for tonight.
10114.438 In reply to 10114.436
Something like this:
var face;
<... get face object ...>
var uv_min = face.domainMin;
var uv_max = face.domainMax;
function Lerp( t, low, high )
    return low + ((high - low) * t);
function LerpUVPoint( t, ptA, ptB )
    return { x : Lerp( t, ptA.x, ptB.x), y : Lerp( t, ptA.y, ptB.y ) }
var uv_a = LerpUVPoint( 0.3, uv_min, uv_max );
var uv_b = LerpUVPoint( 0.6, uv_min, uv_max );
var factory = moi.command.createFactory( 'point' );
factory.setInput( 0, face.evaluatePoint( uv_a ) );
factory.commit();
10114.439 In reply to 10114.438
Thank you Michael
The _ChangeHole script has Face selection code...
I might play with it after work...
10114.440
Hello, Michael.
Would you kindly include SPIRO PATH to Moi v5's Draw Curve > Spiro Path? It is similar to the one in InkScape. Since it guarantees the formation of lovely curves, I think it would greatly strengthen Moi.
I ask because I frequently utilize Moi to "trace" bitmap images, notably logos, into vectors, which are then transformed into 3D logos.
Thank you very much.
10114.441 In reply to 10114.440
Hi Elang, previously due to licensing and patents it was only possible to include Spiro in open source programs, not in commercial programs like MoI.
I think the licensing has changed though and it may be possible to use it outside of open source now.
I'll put it on my list to investigate, it might not make it in for the v5 release though.
10114.442 In reply to 10114.440
There is a Clothoid script.
For "tracing", the Clothoid script can be used.
But using a pair of tangents, and the Blend command works very well, perhaps better than the Clothoid method, IMHO.
(repeat Blend with multiple tangent pairs.) The History effect on Blend is also handy.
https://raphlinus.github.io/curves/2019/05/10/spline-licensing-update.html
The Raph Levien spiro patent was placed in public domain ~ 2019, per above link. Legalities?
There was talk on the forum many years ago...
https://graphicdesign.stackexchange.com/questions/76007/what-is-the-math-governing-the-shape-of-inkscapes-spiro-paths
As I recall, the Clothoid script was based upon a Paper, and used advanced math and programming, even calculus programming...
EDITED: 18 Nov 2022 by BEMFARMER
10114.443
If we're talking wish list items, I would love expanded formatting distance display. I use Moi for woodworking, and it's easiest when working with tape measures and other woodworking rulers to stay in inches, with fractions.
It'd be great to have the formatting distance displace to have Decimal, Feet & Inches and Inches. Or "Decimal with Fractions".
10114.444
Hi, maybe u can add to moi opportunity to drag points of solids like in rhinoceros?
10114.445 In reply to 10114.444
Hi blackboard,
It usually doesn't work very well to try and do this with solids made up of trimmed NURBS surfaces. There are lots of problems with this feature area in Rhino where it generates messy results in many cases.
If you want to model by dragging around surface points it's better to do sub-d modeling for that rather than CAD modeling.
Show messages:  1-5  …  366-385  386-405  406-425  426-445  446-465  466-485  486-505  …  646-656
