V5 Wish List
 1  …  362-381  382-401  402-421  422-441  442-461  …  642-656
10114.402 In reply to 10114.401
OK Micheal, thanks, I've already done a command with moi like what you suggested, but there is a way to make only one file with these alias without making many separated files?
Greetings
10114.403 In reply to 10114.402
Hi pafurijaz,
No currently you would need to make a separate file for each alias.
10114.404 In reply to 10114.401
I'm glad to see that my request is going through! (shortcuts with two letters)
http://moi3d.com/forum/index.php?webtag=MOI&msg=10114.81
-Zooen
EDITED: 1 Jun 2022 by ZOOEN
10114.405
Hi Micheal, for now I think is also great the option to have the possibility to use two consecutive keys, this can give us a lot of possibility.
Greetings
10114.406
I hope your are doing well :-)
I've got a quick question for you, is there a way to have filled 2D shapes as a PDF when one saves as PDF? I mean I want to have filled 2D shapes on my PDF file and not just outlines.
Or Moi 3D already has this ability and I am not aware of?
Best,
Psygorn
10114.407 In reply to 10114.406
Hi Psygorn, some of the parts of dimensions like arrowheads and text will be filled shapes in the exported PDF file but there isn't currently a way set up for a regular drawn curve to be filled. If you make a surface out of a closed curve, it will have a background image underneath though.
10114.408 In reply to 10114.407
Can I make a wish for such ability :-) ?
Best,
Psygorn
10114.409 In reply to 10114.408
Hi Psygorn,
Certainly, but it probably isn't going to happen in the near time frame.
10114.410
I need a simple 2D kinematic simulator to determine the interference of a moving parts to be machined from aluminum. Moi had a tutorial, a simulation of car following a path that seems more complex than a 2D simulator.
Here is a link, similar to what I have in mind: https://oluchukwu96.github.io/Kinematic-Simulator/. This is not meant to be plagerized.
Tgoy99
10114.411 In reply to 10114.410
Hi Tgoy99,
re: 2D kinematic simulator - you might take a look at Working Model: http://www.design-simulation.com/wm2d/
Also I think Blender has some physics simulation but it's more oriented for games.
Maybe Fusion360.
10114.412 In reply to 10114.410
https://github.com/Oluchukwu96/Kinematic-Simulator
The downloadable code is nearly all Javascript. Basic and very pretty javascript code running on a Canvas. Did not see much physics.
Did not see any licensing information.
PhET has simulation software, but only for Teachers. Seems to be free, with many packages. Hard to tell what it could be used for.
Saw their statement that for $100,000 they will work on a new package.
Working Model 2D looked professional, and pricey, with annual fees.
And while doing other searches, encountered some malware of some short. Seem to be pushing antivirus with popups. Hard to tell these days.
@ Tgoy
A very fun & easy 2D free simulator (a true gem) : Algodoo ;) But you must all build! ;)
http://www.algodoo.com
I can answer to some questions about it! :) (only direct first level - not scripts! ;)
Look the videos of this guy following! ;) https://www.youtube.com/channel/UClUIgNQOH-8WRms_awU-47A/videos
EDITED: 30 Jul 2022 by PILOU
10114.414 In reply to 10114.410
Size: 638.4 KB, Downloaded: 224 times, Dimensions: 401x452px
Geogebra has some simulation:
https://www.geogebra.org/m/BWmpFD2P
10114.416
Hi Micheal,
I didn't see this so hope it isn't a repeat.
I would like to see shortcuts tool tip on hover over tools, sometimes I forget them and also to check that the shortcut isn't in use, I am daft enough set one twice.
Not sure how practicle it would be but it would be cool, for new users in particular.
Thanks!
3D Hard Surface
mbt3d.com Artstation
10114.417 In reply to 10114.416
Hi Mark, the way MoI is set up there are very few shortcuts defined by default, just very standard ones for stuff like New, Open, Save, Delete, Undo/Redo.
Then you can set ones you want for things that you use frequently. If you're not using it frequently enough to remember it then probably you don't need to have that shortcut and should just use the button instead.
10114.418 In reply to 10114.417
Thanks Michael,
Yes I understand that.
I set a lot of the them and remember most, but swapping between apps and not using Moi for a while seems to be the thing for me.
Anyway just a suggestion, all the best with the new beta.
3D Hard Surface
10114.419
Michael,
Is there a reason that View > Image > Add places the image on the active cplane, but make2D and File > Import place on the x-y plane of world coordinates regardless of the active cplane?
- Peer
10114.420 In reply to 10114.419
Hi Peer,
> the active cplane?
I guess the main reason is that View > Image > Add is an interactive drawing command where you pick inside a specific viewport with the mouse and so at that point it picks up not just the active cplane but also a particular view.
Neither Make2D nor File > Import involve picking a point so the difference stems primarily from that.
For import if you right click on the File > Import button it will launch the "ImportPart" command instead of regular Import and ImportPart lets you pick a placement and orientation of the imported object so that will adapt to the current cplane.
10114.421 In reply to 10114.420
Thanks Michael! ImportPart will save me time. By the way, I love how View > Image > Align works.
- Peer
Show messages:  1  …  342-361  362-381  382-401  402-421  422-441  442-461  462-481  …  642-656
