V5 Wish List
 1-18  …  359-378  379-398  399-418  419-438  439-458  …  639-656
10114.399 In reply to 10114.398
"Probably the next area of work for keyboard shortcuts will be to do multi key sequences."
What you mean?
Maybe the possibility to crate shortcuts commands like in Autocad or Rhinoceros?
e.g.
OF --> space bar = offset
BEV --> space bar = Bevel
BOO --> space bar = boolean
BOU --> space bar = boolean union
BOD --> space bar = boolean difference
In Autocad you can use space-bar or enter key to execute the command
I hope you can add that type of shortcuts commands.
10114.400 In reply to 10114.399
How is made the difference when you press the Space Bar ?
or you write first BEV then Press the Space Bar ?
or you Press the Space Bar then write BEV ?
or...
10114.401 In reply to 10114.399
Hi pafurijaz,
> e.g.
The method that I was referring to was about using multiple keys in sequence without needing to push Enter or Space, like:
BD = Boolean difference
BU = Boolean union
The way you're talking about isn't so much a keyboard shortcut, it's a "command alias". You can make those
right now in MoI if you want, in moi.ini set:
[UI]
CommandLineTypeTextEntry=y
TreatSpaceAsEnter=y
The first one will make your keystrokes go into the XYZ input without needing to push Tab first and the second one
makes the space work the same as Enter.
Then create a script file of your alias name like if you want OF + space bar = offset to work, make a file named
of.js inside the MoI appdata commands folder and put this inside it:
moi.command.execCommand( 'offset' );
With that in place then you can type of + space bar to run the offset command just as you are describing.
10114.402 In reply to 10114.401
OK Micheal, thanks, I've already done a command with moi like what you suggested, but there is a way to make only one file with these alias without making many separated files?
Greetings
10114.403 In reply to 10114.402
Hi pafurijaz,
No currently you would need to make a separate file for each alias.
10114.404 In reply to 10114.401
I'm glad to see that my request is going through! (shortcuts with two letters)
http://moi3d.com/forum/index.php?webtag=MOI&msg=10114.81
-Zooen
EDITED: 1 Jun 2022 by ZOOEN
10114.405
Hi Micheal, for now I think is also great the option to have the possibility to use two consecutive keys, this can give us a lot of possibility.
Greetings
10114.406
I hope your are doing well :-)
I've got a quick question for you, is there a way to have filled 2D shapes as a PDF when one saves as PDF? I mean I want to have filled 2D shapes on my PDF file and not just outlines.
Or Moi 3D already has this ability and I am not aware of?
Best,
Psygorn
10114.407 In reply to 10114.406
Hi Psygorn, some of the parts of dimensions like arrowheads and text will be filled shapes in the exported PDF file but there isn't currently a way set up for a regular drawn curve to be filled. If you make a surface out of a closed curve, it will have a background image underneath though.
10114.408 In reply to 10114.407
Can I make a wish for such ability :-) ?
Best,
Psygorn
10114.409 In reply to 10114.408
Hi Psygorn,
Certainly, but it probably isn't going to happen in the near time frame.
10114.410
I need a simple 2D kinematic simulator to determine the interference of a moving parts to be machined from aluminum. Moi had a tutorial, a simulation of car following a path that seems more complex than a 2D simulator.
Here is a link, similar to what I have in mind: https://oluchukwu96.github.io/Kinematic-Simulator/. This is not meant to be plagerized.
Tgoy99
10114.411 In reply to 10114.410
Hi Tgoy99,
re: 2D kinematic simulator - you might take a look at Working Model: http://www.design-simulation.com/wm2d/
Also I think Blender has some physics simulation but it's more oriented for games.
Maybe Fusion360.
10114.412 In reply to 10114.410
https://github.com/Oluchukwu96/Kinematic-Simulator
The downloadable code is nearly all Javascript. Basic and very pretty javascript code running on a Canvas. Did not see much physics.
Did not see any licensing information.
PhET has simulation software, but only for Teachers. Seems to be free, with many packages. Hard to tell what it could be used for.
Saw their statement that for $100,000 they will work on a new package.
Working Model 2D looked professional, and pricey, with annual fees.
And while doing other searches, encountered some malware of some short. Seem to be pushing antivirus with popups. Hard to tell these days.
@ Tgoy
A very fun & easy 2D free simulator (a true gem) : Algodoo ;) But you must all build! ;)
http://www.algodoo.com
I can answer to some questions about it! :) (only direct first level - not scripts! ;)
Look the videos of this guy following! ;) https://www.youtube.com/channel/UClUIgNQOH-8WRms_awU-47A/videos
EDITED: 30 Jul 2022 by PILOU
10114.414 In reply to 10114.410
Size: 638.4 KB, Downloaded: 224 times, Dimensions: 401x452px
Geogebra has some simulation:
https://www.geogebra.org/m/BWmpFD2P
10114.416
Hi Micheal,
I didn't see this so hope it isn't a repeat.
I would like to see shortcuts tool tip on hover over tools, sometimes I forget them and also to check that the shortcut isn't in use, I am daft enough set one twice.
Not sure how practicle it would be but it would be cool, for new users in particular.
Thanks!
3D Hard Surface
mbt3d.com Artstation
10114.417 In reply to 10114.416
Hi Mark, the way MoI is set up there are very few shortcuts defined by default, just very standard ones for stuff like New, Open, Save, Delete, Undo/Redo.
Then you can set ones you want for things that you use frequently. If you're not using it frequently enough to remember it then probably you don't need to have that shortcut and should just use the button instead.
10114.418 In reply to 10114.417
Thanks Michael,
Yes I understand that.
I set a lot of the them and remember most, but swapping between apps and not using Moi for a while seems to be the thing for me.
Anyway just a suggestion, all the best with the new beta.
3D Hard Surface
Show messages:  1-18  …  339-358  359-378  379-398  399-418  419-438  439-458  459-478  …  639-656
