V5 Wish List
 1-18  19-38  39-58  59-78  79-98  …  639-656
10114.39 In reply to 10114.37
Hi Phiro,
I'm aware of the naming / layer selection feature, but it's quite different than a grouping (or combiner) system that "lock" a collection of objects into a single item ... and behave as a single object in the viewport when it comes to selection and manipulation.
If I build a restaurant scene, with 20 tables, I don't want to manually duplicate and rename table01, table02 so I can easily re-select them individually later using a scene browsing tree . I would rather combine the table elements into a group, and duplicate (instance ?) and transform that 'table' group.
Maybe it's out of the scope of MoI and scene assembly should be done in an other software. I'm fine with that too.
10114.40
I believe line attributes (patterns, weights) have been discussed before, but that is an area that I would appreciate native support for (vs. a script solution).
--Larry
10114.41
I'd just like to add my voice to those calling for a better 'organisational / grouping / layering system'. Yes, I'm deliberately being rather vague with the terms there : ) Given it's now 64 bit status MOI is much more capable of managing larger datasets - and those bigger models and assemblies require more powerful organisation tools. As a relatively new user, but a long time 3D generalist, I feel 'object management' is one of the areas I'd really like to see improved.
10114.42
Texture mapping like Solidworks and Rhino have.
10114.43
Hello all, I hope you are doing fine :-)
Is it possible to select similar lines, surfaces, etc. in Moi3D? If not I would like to make a wish for it!
Making Moi3D to be able to select similar features such as similar lines, faces, etc.
For example if you take a look at below picture you would see that I had selected similar edges so, I could apply fillet on them! Is there a way to select similar edges, surfaces, etc in Moi3D? If not I would like to make a wish for it! :-)
EDITED: 29 Jan 2021 by DRILLBIT
10114.44 In reply to 10114.43
Hi Psygorn, to insert an image use:
<img src="https://url_to_image_here">
10114.45 In reply to 10114.44
Ok, I got it! but sometimes I forget the command!
10114.46
I don't know how it got so far as V4, but the views are wrong. In many cases, right and left, front and rear are arbitrary. But in cases of cars, boats (most anyway), etc., there is only one way. If I orient a model so that the front and rear agree with "Front" view and "Rear" view, then "Right" and "Left" are wrong. If I orient right and left correctly, then "Front" and "Rear" are wrong. It's simple to remember that "Front" is rear, or "Right" is left, but why should this be necessary?
10114.47 In reply to 10114.46
Hi Tim, the MoI views follow the standard view names used for engineering drawings for the past hundred years or so.
The names come from the viewer's location. Imagine that you are sitting at a square table with an object on it. If you move your chair to the next side of the table towards your right hand direction that will be the view from the right. If you move your chair towards your left to the next table side then what you see will be the view from the left.
This is used in a generic way for all objects, it's not something that makes sense to change just because the object happens to be a car or a boat.
Here's an illustration from "Essentials of Drafting", Carl Lars Svensen, first published1918, third edition 1945, page 73:
EDITED: 31 Jan 2021 by MICHAEL GIBSON
10114.48 In reply to 10114.47
Big thanks, Michael !
The 1919 edition is freely available from this source, also as pdf file:
https://archive.org/details/essentialsdraft00svengoog
Openlibrary_edition
OL20611713M
Openlibrary_work
OL13149754W
Pages
239
Possible copyright status
NOT_IN_COPYRIGHT "
10114.49 In reply to 10114.48
Hi Ken, thanks that's really cool to have that PDF version!
I found mine at an antique store in Wiscasset, Maine, with "Property of U.S. NAVY" stamped on the inside.
Another cool old one I've got is "A Manual of Engineering Drawing for Students and Draftsmen", Thomas E. French 1918. Looks like that's available at archive.org too!
I've also got:
That's even there too search for "Practical geometry LE CLERC" !
10114.50 In reply to 10114.49
YES: here you go:::
A Manual of Engineering Drawing for Students and Draftsmen:
https://archive.org/details/amanualengineer01frengoog
and new finding:
Practical Geometry, Or, A New and Easy Method of Treating that Art ...
- Sébastien Le Clerc - dated 1727 -
- also as pdf...!
https://openlibrary.org/books/OL20545882M/Practical_Geometry_Or_A_New_and_Easy_Method_of_Treating_that_Art_...
EDITED: 31 Jan 2021 by OKURO
10114.51 In reply to 10114.47
Yes, I'm an engineer and I had many years of mechanical drawing. But when "standards" violate 'reality', which is 'right'? I'm not looking to argue this point. If there are two contradicting ways of doing something, maybe we could have a choice, that is we could select the view names that we like. BTW, as I'm sure you know, there are two different methods of projection, the American way and the European way. Trying to go back and forth between them is very confusing. And it isn't that one is 'right' and the other is 'wrong'; they both make sense when you understand the 'logic' behind them. Well, I wanted to point out a contradiction, and we can leave it at that. BTW, I'm very happy with V4!
10114.52 In reply to 10114.51
Hi Tim, I'm not necessarily against making it an option. There are some potential complications though since scripts can refer to viewports by name as well and I'm uncertain what the side effects could potentially be if the script API didn't have uniform behavior.
A thin layer that only changed the labels in the UI and not anything else would not be too complicated though.
Hello Michael.
What about my request for V5?
"For V5 (or I hope in the next builds of the current V4) I have this request:
A TRUE OBJECTS "INSTANCING AND GROUPING/PARENTING"
That's will be a HUGE leap forward!
Thanks."
Are you planning these long awaited things?
Thanks and have a nice day.
10114.54 In reply to 10114.53
Hi Marco, I don't have any fixed plans yet, so I can't comment on whether a particular feature will definitely be in v5 or not.
That's an area that I would like to work on, but it is unknown how much work it will take. I will need to do some exploratory work before I will know more about it.
10114.55 In reply to 10114.54
Ok Michael and always thanks for your frankness.
But, and I hope not to sound too complaining...
Could you tell me, in broad terms, which new (really new) feature are you developing/planning for the next releases of V4/V5
And if you have a rough roadmap.
I ask you these things because, even if the new V4 major release is a great product and compatible with 64 bit, it's been years that Moi3D doesn't get any real new modelling feature.
I hope you understand my point of view...
Have a nice day.
10114.56 In reply to 10114.55
Hi Marco,
I'm sorry Marco, like I wrote previously I don't have any fixed plans or any roadmap set yet. So I do not have any of this information to give you right now.
MoI v4 did introduce SubD model conversion which enables new modeling workflows, I would think that should be considered a modeling feature.
10114.57 In reply to 10114.56
OK, Michael.
"I'm sorry Marco, like I wrote previously I don't have any fixed plans or any roadmap set yet. So I do not have any of this information to give you right now."
Really, I don't know what to say...
I'm really sorry to hear that.
10114.58 In reply to 10114.57
Sorry Marco, unfortunately it's quite difficult for me to know in advance exactly how long any particular feature area will take to implement. I need to do some exploratory work before getting a better understanding of it.
Until I'm able to do some of that I just can't make any promises for exactly what will be in v5.
Show messages:  1-18  19-38  39-58  59-78  79-98  99-118  …  639-656
