V5 Wish List
 1-19  …  320-339  340-359  360-379  380-399  400-419  …  640-656
10114.360 In reply to 10114.359
Hi Psygorn,
> However I meant an ability to extract some arbitrary lines or closed loops over a selected curved surface/s
> (and I am not talking about Iso) I just think that could be useful :)
Can you show an example of what you're trying to make?
10114.361 In reply to 10114.360
Yes of course, the example attached, I wanted to be able to draw a curve like the red one u see over that object. Somehow I thought maybe there that way I could have a better control of the curve.
Note: I put more thought into it and I think with the current features of Moi achieving things like what I wanted is pretty much possible. and I am willing to take back my request :)
( I mean when I considered how much work it may require to make Moi gain the ability to directly draw on the curved surfaces; I think it may not worth it!)
_Psygorn
10114.362 In reply to 10114.361
Hi Psygorn,
It's better to draw planar curves and use projection to get that result.
It's most likely that trying to draw a curve like that directly on the surface would
actually be less controllable. Part of the problem with it is that there isn't just one
single way to do it.
Something like drawing a curve in the surface's UV parameter space can tend to have
distortions especially with things like you have here where the surface is compressing
down to a point on one end.
10114.363 In reply to 10114.362
Thank you for your explanation .
_ Psygorn
10114.364
* Small wish: an address bar in the File explorer while saving / opening files. A section to save Favorite locations for Quick Acess would be great.
* Medium(ish?) Wish: A faster and more interactive way to access / Modify Styles. like having a color cube with a hue slider on the side bar. The color cube toggles between changing the color of selected objects/faces, the background, or modifying the active style. the yellow color indicating selections would temporarily be disabled while changing styles to allow for interactively seeing the new style. Such interactivity would help with design, and open up the doors for MoI to be used for more purposes.
* Huge, huge Wish: that big fillets thingy. and all its children (I presume) like "tweak face" and "delete fillets". that would definitely make MoI the ultimate CAD software. If it's possible to implement once the license is bought, maybe crowdfunding to buy it would work? maybe there's a whale hobbyist somehere who would do it for the whole world? One can only dream.
10114.365 In reply to 10114.364
Hi Flowgun,
MoI uses the standard file dialog which is provided by the operating system. It's up to the OS
to provide something like this in the file dialog UI.
It would take quite a lot of work to make a complete custom replacement file dialog instead
of using the system one. So that's not really feasible.
What operating system are you running on? There might be some kind of utility software
available that could customize the system file dialog.
10114.366
Hello Michael,
Is it possible to extrude a point (vertex) in Moi? ( I know I can drag the vertex at the end of a line/curve however, I think the ability of having it extruded could be useful! )
Also is it possible to have Planar command working on not closed loop of edges?
_Psygorn
10114.367 In reply to 10114.366
Hi Psygorn,
Sorry no not currently.
No, it needs to have a closed planar loop of edges to form a proper trim boundary.
10114.368 In reply to 10114.367
Ok :-)
10114.369 In reply to 10114.367
Michael,
I note that you provided a more detailed response to a similarly posed question from a few years ago.
quote:
The geometry library that MoI uses for these functions does not currently have an implementation of handling points like this. It could be possible in the future for me to add it but it will require adding a custom function for each of these cases.
Is it just wishful thinking, or does the brevity of your more recent answer hint at the possibility that this is something that you given some thought to enacting?
Rereading that earlier post, ( http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=6925.454 ) I was reminded that back then we also discussed making control points addressable. Although I can't find the specific post, I recall (correct me if I'm wrong) that you would be investigating point indexing for a future release. Is this part of the road map for V5?
I fully trust your stewardship of MoI3d, so even if these will not be available in the near future, I am nevertheless still enthusiastic to see what is.
10114.370 In reply to 10114.369
Hi James,
It hasn't really been on my radar. I took a quick look and I got a little discouraged that the selection
prompt for Extrude says "Select curves, edges, or faces to extrude" and then adding in points means
I have to either make that prompt kind of excessively verbose, or I guess shorten it down to say "Select
objects to extrude" I guess.
There is a first level of this implemented in the first v5 beta currently, check near the end of the release notes:
"Edit points scripting - Add scripting interface on objects for:"
http://moi3d.com/forum/index.php?webtag=MOI&msg=10652.1
10114.371 In reply to 10114.365
My bad. the System File Dialog works great in Moi V4 (on windows 10).
tbh, I still use MoI v3 mostly since I encounter performance problems with v4. It's most likely because of my system though. I believe it's something that has to do with Javascript crashing. I also have a very old CPU that I bought for around 15 bucks (i7 3770).
I should be more careful before posting on the forum. I don't want to waste anybody's time, so my apologies.
PS: I keep on noticing these seemingly "Under the hood" improvements between v3 and v4, like support for 7100 FBX, the improvement in File Dialog, and so on. This makes me more excited for v5, as I'm starting to rely more and more on MoI in my workflow. Best of Luck with it!
- Flowgun
10114.372 In reply to 10114.371
Hi Flowgun, no problem. Yes MoI v3 used an older interface for the file open dialog on Windows. MoI v4 was updated to use the latest.
Do you still see the performance problems with v5?
There is also a setting in v5 to make it use the same Direct3D9 system graphics library that v3 did, you can set that in moi.ini under:
[View]
GraphicsAPI=Direct3D9
If you have a pretty old flaky video driver that worked better with MoI v3 that could make v5 behave more like v3 on your system possibly.
10114.373
When saving as a PDF, I wonder how hard it would be to offer the option to append a new page if the PDF already exists? For me the use case would be the many times that I'm appending the PDFs of different views of something to produce a document to share. If it is not too difficult, I would find this quite handy!
I realize that PDFs are complex, so if it would make such a feature simpler to implement, maybe the option is only offered if the existing PDF is "easy" to work with, for example created by MOI?
--Larry
10114.374 In reply to 10114.373
Hi Larry,
For this use it seems like it might work better if you could generate the multi-page PDF all in one go from some kind of list of saved views.
I think it might be possible to make a script that would do a "save to PDF append page" if I can set up a helper utility program for it to call to do the merge. The PoDoFo library that MoI uses for PDF handling has a utility like that in it so I'll give it a try.
10114.375 In reply to 10114.374
Assembling the individual PDFs into a multi-page document isn't a problem for me (just a small hassle),
but the thought occurred that if it was relatively easy to append to an existing PDF it would be quite
handy. I'll look forward to whatever you come up with & appreciate as always your willingness to help!
--Larry
"Wish" list....
Continuity controls added to sweep curves and rails.
Sortof the same work as 4 sided continuity added to network and nsided.
10114.377 In reply to 10114.374
Michael
I know it is very early days yet with development of V5, and I'm unaware the your plans for GUI improvements. Although the view window buttons on the bottom nav bar function well, I wonder if there is a more elegant solution that doesn't hog so much screen realestate.
Although the colours are a bit garish, I think the navigation cube in this online SD modeller could serve as an example:
https://stephaneginier.com/archive/nomad_demo/
The navCube is immediately comprehensible on initial encounter with the interface and the labelling of faces greatly assists with orientation.
It also includes screen reset facility: clicking a second time on the cube face selection zooms to selected object extents.
Now, I know that there is no option for split screen, but perhaps a small adjacent 4 pane window icon could solve this requirement.
Please disregard this suggestion if it does not meld with your vision of Moi3d
10114.378 In reply to 10114.377
Hi James,
> elegant solution that doesn't hog so much screen realestate. Although the colours are a bit garish,
It looks like it performs a somewhat different function than the Split / 3D / Top / Front / Right view tabs in MoI.
When you click on Top on that view cube, it's navigating a perspective view camera position. When you click on
the Top view tab in MoI it switches the orthographic 2D Top viewport to be maximized.
The 2D ortho views in MoI help to give more of a 2D drawing workflow when you're working in them, it would
be a problem to eliminate them and only navigate the 3D perspective view like the view cube navigation
is doing.
10114.379 In reply to 10114.378
Michael
is doing.
Of course, I wasn't advocating abandoning 2D orthographic projections, but rather suggesting the possibility of adapting this type of navigational device to operate within MoI3d similarly to how the button row works now (perhaps with animated transitions).
And as for the 4up split view, this could be handled by additional adjacent icon.
Anyway it was only a thought, not even a request.
Have a great weekend,
EDITED: 30 Apr 2022 by JFH
Show messages:  1-19  …  300-319  320-339  340-359  360-379  380-399  400-419  420-439  …  640-656
