V5 Wish List
 1-12  …  293-312  313-332  333-352  353-372  373-392  …  653-656
10114.333 In reply to 10114.332
Here is the demonstration that it does not support trimmed surfaces, I have tried many times and it does not support any trimmed surfaces.
10114.334 In reply to 10114.324
Thanks Ed, this script will be very useful to me. Thanks Pilou for the translation.
The little extra would have been to be able to automatically put the object in a perfectly vertical position from the front, or perfectly horizontal from above, in the 3D view, before launching "AutoRotate2" or in the script itself.
EDITED: 21 Dec 2021 by ZOOEN
10114.335 In reply to 10114.333
Sorry i am not sure to understand the problem of the trimmed surfaces ? :(
Have you the Moi file ?
In fact i see what do you speak about! :)
I will explore because as you can see there is the trimming curve on the hull!
So must find the trick inside this labyrintical prog :D
Small advance but...:)
Seems it doesn't like intersections of surface!
It's a pity because all is done...
Seems a very powerful program but with an no ergonomic and fluid Interface! :)
And some tenebrous functions to blend between them! :)
EDITED: 22 Dec 2021 by PILOU
10114.336
I have a question; is it possible to control the pointiness of a generated mesh using the sweep command?
10114.337 In reply to 10114.336
Hi Psygorn,
Well if you use the "Pointy ends" option in Sweep it will transition from a profile curve to a point at the tip. You can get some control over how long the pointy part will be by putting in additional profile curves.
If you want to control the "side profile" of the point you might be better off generating a straight pointy object using Revolve and then apply it to the curved path using Transform > Deform > Flow rather than using the Sweep command.
If you need more help I may need some kind of sketch or example of what you're trying to do.
10114.338 In reply to 10114.337
Hello Dear Michael,
This is not a V5 wish however, I thought I have to post it here!
Why I cannot Extrude to point the red curves into the green point?
When I try to Extrude the red profile toward the green point it goes on a direction which is not my desired direction.
The final mesh's singularity point is a bit offset.
I hope I described the problem well.
10114.339 In reply to 10114.338
Hi Psygorn,
It would be good to start a separate topic for it if it is not related to this thread's subject.
You can, there is an "Unlock direction" option you can click if you want to freely place the point somewhere not on the initial default tracking line:
Your point though is on a different z level than the curve, you probably need to position it at the right level before extruding to it.
Message 10114.340 deleted 28 Dec 2021 by BEMFARMER
10114.341 In reply to 10114.339
Thank you Michael,
it is funny but I did not even see the "Unlock Direction" button!
Thank you for guiding me.
10114.342
Hello Michael,
I hope you are doing well, and happy new year in advance.
I just wanted to ask a question -out of curiosity- and others might have asked it before. however, I just thought to ask it here real quick.
Should we expect non-destructive modeling approach in MOI3D?
I know that one way of having non-destructive modeling is to use Nodeeditor (elephant) but I wanted to know if we could expect it inside of MOI3D itself.
Best and happy new year,
Psygorn (Drillbit)
10114.343 In reply to 10114.342
Hi Psygorn,
I hope that eventually yes MoI would have that but there will be a lot of work to get there and so I don't know when it will happen.
It also has not been a high priority for MoI because there are many other already existing CAD programs that are already heavily focused on it.
If it's an important function for you I would recommend to use one of those CAD programs that are based on it, like SolidWorks, Alibre, OnShape, etc... alongside MoI instead of only MoI all by itself.
10114.344 In reply to 10114.343
Oh well that is great news.
My question was out of pure curiosity. :-)
Happy new year in advance :-)
10114.345
A quick question, could we have PCB circuit design features in MoI?
(I think that would boost up hobbyists capabilities by unimaginable folds! )
10114.346 In reply to 10114.345
Hi Psygorn,
Sorry no I don't expect for MoI to become a tool for that area of work. I don't have any experience in that field.
Some SUbD native functions ? (we have yet few ones by Max Smirnov and native SUD Import but...
EDITED: 4 Feb 2022 by PILOU
10114.348 In reply to 10114.347
Hi Pilou, I would like to add some relatively basic SubD tools. That's why there's a SubD tab on the side pane that can hold more stuff.
But I'm not sure when I will be able to focus on that, probably it won't be in v5.
It's not a top priority because there are a variety of sub-d modeling programs out there that you can already use to do that and use the converter to bring it over into MoI.
10114.349
Michael, I would absolutely LOVE to have some way to track what fonts were used in a drawing. I don't even care if it is simply a list with no reference to the actual text used. I sometimes need to go back and update a file I created months or years ago, and I'm left wondering "what the hell font did I use???".
A simple list of font calls for a particular drawing is my only request. Oh, and a better fillet engine as many have already stated. I'm tired of having to use Inventor to add fillets to a design I created in Moi.
Cheers,
Chris
10114.350 In reply to 10114.349
Hi Chris, you can see what font is being used by a particular dimension by selecting it and clicking on the "Details..." button to bring up the detailed object properties dialog:
The font name will be shown here:
10114.351 In reply to 10114.350
Hi Michael. I meant when I use a font to create some "design" text in a drawing, not the dimension text. Sorry if I wasn't clear.
Cheers,
Chris
Size: 287.1 KB, Downloaded: 158 times, Dimensions: 1600x900px
10114.352 In reply to 10114.351
Hi Chris,
Currently that isn't easily accessible like it is for dimension text. At some point I hope to store a deeper history that records everything you did to construct the current model and this should then be available in there.
Show messages:  1-12  …  273-292  293-312  313-332  333-352  353-372  373-392  393-412  …  653-656
