V5 Wish List
 1-16  …  257-276  277-296  297-316  317-336  337-356  …  637-656
10114.297 In reply to 10114.296
esc works ))) first tap deselects, second exits editing ))))
10114.298
I am not sure if this has been requested, but it would be nice if Moi allowed for a user scripts directory that lives outside of the program files install path of Moi.
Currently the user is required to have admin rights in order to write to the Moi/commands folder, which for the home user is no big deal. However here at my workplace, due to client requested IT audits, admin rights aren't allowed for the digital artists, so every time we want to add a script to the commands folder, we have to have our IT admin add the script for us.
It would be nice if there was a option for an additional user defined script location that could be used that doesn't require administrator rights to modify or add new scripts.
I know this could be circumvented by making Moi portable, but there are some work places where, due to security reasons, the usb ports have been disabled to prevent IP theft.
10114.299 In reply to 10114.298
Hi KanakaRed,
This is implemented currently in MoI v4. Starting with v4 MoI will also look for commands in the appdata commands folder, not just in the install commands folder.
Some more details in the FAQ question #1 here: http://moi3d.com/FAQ
You can also make MoI look through any specific folder of your choosing by editing moi.ini :
[Commands]
AdditionalCommandsDirs=
10114.300 In reply to 10114.299
Thanks, Michael. I don't know how I overlooked this.
10114.301
I don't know if it's been broached before but some sort of visibility control would be amazing, I like everyone else probably spends a lot of time turning on/off objects/mats and this could be a big time saver
https://www.youtube.com/watch?v=-kWaV1cqB-k (for example)
- Rich x
10114.302
Seeing your mention of a new theme infrastructure component for V5 (https://moi3d.com/forum/index.php?webtag=MOI&msg=10465.20) which offers some extensibility makes me wonder if this general idea might also be applied to the concept of a title block? There has been the occasional discussion of title blocks (like for 2D drawings) & I've pondered how one might script such a thing but it currently seems problematic to do so. If the theme idea could be morphed into providing the basic structure and allow for some customization, that would be a really neat addition to MoI.
Wishing you a happy Thanksgiving & looking forward to the V5 beta cycle!
--Larry
10114.303 In reply to 10114.302
Hi Larry,
Sort of in the sense that it needs some kind of templating mechanism. There's some previous discussion here, does the idea mentioned there seem like it would work ok?
http://moi3d.com/forum/index.php?webtag=MOI&msg=10011.63
10114.304 In reply to 10114.303
Yes, that's the conversation I was recalling & merging a template during PDF export seems like a very nice solution. I don't have any thoughts on the specific fields to be maintained in the title block & would imagine that would be an area that would be nice to allow some customization of. If the field values could be stored in the model's 3DM file, that would of course be even nicer.
--Larry
10114.305 In reply to 10114.304
Dear Micheal,
Could you please incorporate into your software 3DMoi the printing function because for me is very important asset to have it to my works if I want to print.
Another thing that I like to see in the next new update of V5 is to see the custom UI environment that include the object Library and the Pull down scripts so they're inserting into the browser pane instead of into the command bar
when you need them to modify our designs because I so other users use them and it' very cool indeed.
I like to see more different choices in the lighting option styles.
Hope you can incorporate the GUMBALL system into your 3DMoi like the one using in Rhino 7 because the one we have in the software was not familiarize with me, I prefer the Gumball because it makes things perfectly when you need them to be.
Thank you for your support that you always gave us.
RC
10114.306 In reply to 10114.305
Hi RC, currently a good way to print is to save to a PDF file and then you can print the PDF file. Adobe Reader has a lot of options for printing including things like tiled posters.
It would take a lot of effort to get a print function directly from MoI that had the same level of functionality in it.
So because it would take a lot of effort and would give only very minimal improvement (if any) it's not really a good target feature for MoI at least currently.
What would be the advantage to having a scripts menu in the browser pane instead of the command bar?
The browser pane is generally meant to hold stuff related to the model structure. A list of plug-in scripts doesn't match with that so it would seem a little weird to me to put it in there.
10114.307
I've got a new proposal: New projection view option "Current view" in the AI and PDF export options (only in single viewport mode obviously).
10114.308 In reply to 10114.307
Hi 3image,
What would it do when you're not in single viewport mode?
10114.309 In reply to 10114.308
Easy, the option is not shown then. ;-)
10114.310 In reply to 10114.309
Hi 3image,
The regular behavior of these controls is that they get initialized to the last value that was used.
That doesn't fit well with a dropdown value that can disappear like that.
The problem would be if you do an export where you have a view maximized and use this option, but then later on do a second export while in Split view mode. The dialog would want to initialize the control to a value that is not being shown.
It's not problematic to have an entire control be hidden but hiding just some values in a dropdown list is different.
10114.311
Maybe it's because of my lunatic workflow but I often export the wrong view.
I would be in favour of an indicator of some kind !
Concerning fullscreen, perhaps the flyout could be set on the maximized view.
Small detail though.
Can't wait to see the work on groups !
Marc
EDITED: 16 Dec 2021 by TELLIER
Size: 166.1 KB, Downloaded: 232 times, Dimensions: 1600x1270px
10114.312 In reply to 10114.311
Hi Marc,
Probably the real way to solve this would be to show a preview of the 2D page that is going to be written so you can see what you're going to get and change settings as needed.
Unfortunately it's going to take quite a lot of work to make that, the amount of work is high in proportion to the amount of benefit gained so it's not easy to dedicate time to that.
10114.313
Hi Micheal,
Yeah, If it's a lot of trouble it's not really with it.
Marc
10114.314
Greetings to all : )
Suggestion: auto swap of template images for ortho views - top/bottom, left/right, front/back.
I'm currently working on a model for which I have 2D drawings. I have image planes set up for top, left/right, front/back.
It would be super helpful if, when switching ortho views - left/right or front/back - the relevant image plane was shown and the 'reverse view' image plane was hidden.
Currently the same image just gets automatically reversed in direction ('auto-flipped'). That's pretty confusing and an invitation to make mistakes when your object is not symmetric.
The current set up makes working round this problem equally confusing, because if you set up drawings for left/right, front/back you have to reverse one of them because of the 'auto-flip'.
It's a flippin' nuisance : )
Thanks for any consideration this may get : )
Mike A.
EDITED: 17 Dec 2021 by VIEWBYTE
10114.315 In reply to 10114.314
Hi Mike,
Sounds like something that a script could address. Can you please post an example model with the images set up so I can experiment with making a script?
10114.316 In reply to 10114.315
Michael,
That would be great. Unfortunately I can't send the drawings I'm actually using due to NDA, but I'm sure I can put together a super simple demo that will suffice.
It might be a few days as I'm under a heavy deadline at the moment - but I will add it to my to-do list!
Many thanks!
Mike
Show messages:  1-16  …  237-256  257-276  277-296  297-316  317-336  337-356  357-376  …  637-656
