V5 Wish List
 1-19  …  240-259  260-279  280-299  300-319  320-339  …  640-656
10114.280 In reply to 10114.279
I generally think of myself as a reasonable adult, but in this instance I feel like a complete dolt.
Sorry to have taken your time Michael.
As always, you are super helpful.
Cheers,
Mindset
10114.281 In reply to 10114.280
Hi Mindset, no problem! :) And if you still can't get it to work as you need please let me know.
Also I do want to add an option for projecting points when picking in the 3D viewport as well. But right now if you go to a 2D view that will do it when you pick in there.
10114.282
Hi, I would really like to see a baseline "utility" lighting implementation with shadows, not so much for presentation, I found it a really helpful modeling tool to see how the form is working under various lighting, i thought Sketchup did a decent job of this. This is example how i was using sketchup light to arrange the scene to paint over later https://www.artstation.com/artwork/q4dWy
In MOI i would be using this to track the form more than cast shadow in an interior but hopefully it gets the idea across.
Thank you!
EDITED: 2 Sep 2021 by TENG1
10114.283 In reply to 10114.275
*What is the shortcut script for the CPlane tool? I feel like this sort of thing could be a bit easier...
- Rich
10114.284 In reply to 10114.283
Hi Rich, use this for a shortcut for setting the CPlane:
script: moi.view.setCPlaneInteractive();
For resetting it use this:
script: moi.view.resetCPlane();
Yes, definitely it could be improved. It hasn't been prioritized because it's the kind of thing that you don't go into very often.
I did get the part of setting up the key improved a lot in MoI v4 so that you press the key combo you want instead of typing in the text description of it.
10114.285 In reply to 10114.284
Great thanks Michael....Yeah I think it's not a nightmare pasting in the script or anything, but it would be great to have the script info logged somewhere, not for all commands obviously but at least the first port of call UI buttons? Even a text file would do probably!
- Rich
10114.286 In reply to 10114.285
HI Rich, there's an attempt at that in the help file Shortcut Keys section:
https://moi3d.com/4.0/docs/moi_command_reference11.htm#shortcutkeys
I happened to miss CPlane there though, I've made a note to update it next pass through docs.
10114.287 In reply to 10114.286
Great...Would it be as simple as next to the 'Add' 'Delete' buttons on the shortcut interface there's a hyperlink to that reference or something? Too messy? I guess the thing is - the jump between being inside the program / finding your way to that info?
10114.288
Michael,
Is there any chance to see this stereographic projection implemented as an option in a future release?
https://moi3d.com/forum/messages.php?webtag=MOI&msg=8976.1&highlight=yes
I think it would be terrific at giving more realistic proportional feedback while designing in MoI. I was sad that this "hack" wasn't workable with the Macintosh version of V.3...
Mark G.
10114.289 In reply to 10114.288
Hi Mark,
It's only been very rarely discussed or requested so sorry it's not too likely to be an area that I'll be able to dedicate time to working on.
10114.290
Support of the .webp format.
10114.291 In reply to 10114.290
3dm and Rhinoceros files support groups and blocks this would be a really great feature if implemented in the next Moi3D release
Maybe that was already asked by others but is hard read everything in this long list.
10114.292 In reply to 10114.291
Hi pafurijaz, both groups and blocks are poorly implemented in Rhino with a lot of problem areas. So even when these are implemented in MoI it's pretty likely that they will be custom implemented for MoI and won't be stored in the .3dm file's regular structure.
With groups the problem is that it's just a kind of tag assigned to objects and groups aren't structured in a parent/child relationship.
With blocks the problem is it's a clone of an antique AutoCAD system that has weird rules about how layers work in combination with the blocks.
It might be that I can shoehorn MoI instances into a compatible system with blocks, I'm not sure about that yet. I'm pretty far along with groups though and I'm pretty sure that groups will not be stored as .3dm groups though since there isn't any way to represent a parent/child nesting with them.
10114.293 In reply to 10114.292
Hi Micheal, thanks for the clarification, I know well how the Blocks for Autocad work, in reality it is very simple, the Autocad blocks have the characteristic that all the objects or lines on layer 0 can receive the characteristics of the layer where they are inserted and all the other levels can be customized with unique colors and properties of the block, however I hope that we can also introduce only a hierarchical level tree with sub-levels that include others already this would be fantastic, even groups could be a valid solution.
I hope this can be evaluated for the next update because when you have over 2000 objects, it is useful to organize the elements as assemblies such as staircases or other with different colors and materials.
 I
Greetings
10114.294 In reply to 10114.292
Tears of joy over here reading this Micheal, tears of joy I can't wait to see how you implement it
10114.295
if it's possible to add quick edit points mode - holding a button to enter and move points
i'll expain behind the scene: ex chamfer - and move a point, actions will be enter edit mode, select points, move, exit edit mode(show points) -> 4 actions per 1 operation
holding the same button ~ tobe quick move point action
- Tudor -
10114.296 In reply to 10114.295
Hi Tudor,
If you want to move just one point you don't need to select it and then move it in separate steps you can just click and drag on the point.
You can also turn off points by hitting the Esc key instead of clicking on Edit > Show pts.
I experimented with making a script that would turn on points for a single selected object, let you drag a point and then turn off points automatically. I wasn't able to make it for v4 because edit points aren't accessible by scripts but I have added that in for v5 so a script for doing this will be possible in v5.
10114.297 In reply to 10114.296
esc works ))) first tap deselects, second exits editing ))))
10114.298
I am not sure if this has been requested, but it would be nice if Moi allowed for a user scripts directory that lives outside of the program files install path of Moi.
Currently the user is required to have admin rights in order to write to the Moi/commands folder, which for the home user is no big deal. However here at my workplace, due to client requested IT audits, admin rights aren't allowed for the digital artists, so every time we want to add a script to the commands folder, we have to have our IT admin add the script for us.
It would be nice if there was a option for an additional user defined script location that could be used that doesn't require administrator rights to modify or add new scripts.
I know this could be circumvented by making Moi portable, but there are some work places where, due to security reasons, the usb ports have been disabled to prevent IP theft.
10114.299 In reply to 10114.298
Hi KanakaRed,
This is implemented currently in MoI v4. Starting with v4 MoI will also look for commands in the appdata commands folder, not just in the install commands folder.
Some more details in the FAQ question #1 here: http://moi3d.com/FAQ
You can also make MoI look through any specific folder of your choosing by editing moi.ini :
[Commands]
AdditionalCommandsDirs=
Show messages:  1-19  …  220-239  240-259  260-279  280-299  300-319  320-339  340-359  …  640-656
