V5 Wish List
 1-11  …  232-251  252-271  272-291  292-311  312-331  …  652-656
10114.272 In reply to 10114.271
Thanks for the reply. I wasn't aware of the difficulty as Rhino3D and Form Z both import skp files (or at least they claim to as I do not have either app to claim otherwise).
10114.273 In reply to 10114.272
Hi Kenmo, both Rhino and FormZ are multi-purpose/"hybrid" type modeling apps which have support for modeling using either polygon mesh objects or NURBS objects. But these different object types have pretty distinct toolsets and so having this adds a considerable amount of complexity and weight to the program UI. They have a whole lot of different stuff all mashed together into one app.
One of the things that MoI is focused on is being streamlined with a lightweight easier to use UI. So MoI is not set up like that.
If working on imported SKP polygon data is an important function for you, then Rhino or FormZ could probably fit your needs better than MoI.
10114.274 In reply to 10114.273
No thanks. I played with a trial version of Rhino and hated it's ui. I have the free version of Form Z and it's not to my liking.
I much prefer MOI 3D over any of of the NURBs or CAD alternatives.
10114.275
I'd chip in for a slightly easier to use Shortcut Key system...For instance I've been using the CPlane function more and more, but have to dig to find out how to add manually...I think even a drop-down list of some of the commands after you've selected a key combination would be useful? Adding scripts I get but the process is a bit cumbersome for some things for sure (PS what is the shortcut command haha!)
- Rich
10114.276
Hello to All,
I'd like to see some way to numerically adjust the position of an item.
Is that already an existing feature and I'm missing it? (We have it for an object's size.)
At minimum, maybe the ability to do so for point objects.
Plausible, Logical ?
Mindset
10114.277 In reply to 10114.276
Hi Mindset,
You can do this currently with the Transform > Move command.
Select the object you want to reposition, then run the Transform > Move command. At the first prompt to pick the base point, pick the point on the object that you want to position numerically. You can click the "Bounding box center" button if you want to position that spot of the object.
Then on the last prompt to pick the target point you can type in the x,y,z coordinates for where you want it to go.
10114.278
Thank you Michael for your previous response; spot-on as always.
This is a proposed enhancement for the Scale 2D command.
The situation was such that the target object set needed to be adjusted to match the size of a relative item, which was disposed at some vertical distance. I picked two points on the target set, but when I pick the second reference point from the relative item, the resulting scaling factor seemingly vectored the vertical distance, making it difficult to match the two sets with respect to the 2D (horizontal) plane.
Suggestions?
Should this command form offer an option to ignore non-coplanar coordinates?
Many thanks,
Mindset
PS … I realize now that the first reference point (on the target) was also not coplanar with the base point.
Perhaps all input points should be 2D for this command... ?
EDITED: 26 Aug 2021 by IGNITER
10114.279 In reply to 10114.278
Hi Mindset,
> Suggestions?
It should work like that currently if you are picking the points in an ortho viewport like the Top/Front/Right views.
Could you post a .3dm file with the objects you were trying to scale?
10114.280 In reply to 10114.279
I generally think of myself as a reasonable adult, but in this instance I feel like a complete dolt.
Sorry to have taken your time Michael.
As always, you are super helpful.
Cheers,
Mindset
10114.281 In reply to 10114.280
Hi Mindset, no problem! :) And if you still can't get it to work as you need please let me know.
Also I do want to add an option for projecting points when picking in the 3D viewport as well. But right now if you go to a 2D view that will do it when you pick in there.
10114.282
Hi, I would really like to see a baseline "utility" lighting implementation with shadows, not so much for presentation, I found it a really helpful modeling tool to see how the form is working under various lighting, i thought Sketchup did a decent job of this. This is example how i was using sketchup light to arrange the scene to paint over later https://www.artstation.com/artwork/q4dWy
In MOI i would be using this to track the form more than cast shadow in an interior but hopefully it gets the idea across.
Thank you!
EDITED: 2 Sep 2021 by TENG1
10114.283 In reply to 10114.275
*What is the shortcut script for the CPlane tool? I feel like this sort of thing could be a bit easier...
- Rich
10114.284 In reply to 10114.283
Hi Rich, use this for a shortcut for setting the CPlane:
script: moi.view.setCPlaneInteractive();
For resetting it use this:
script: moi.view.resetCPlane();
Yes, definitely it could be improved. It hasn't been prioritized because it's the kind of thing that you don't go into very often.
I did get the part of setting up the key improved a lot in MoI v4 so that you press the key combo you want instead of typing in the text description of it.
10114.285 In reply to 10114.284
Great thanks Michael....Yeah I think it's not a nightmare pasting in the script or anything, but it would be great to have the script info logged somewhere, not for all commands obviously but at least the first port of call UI buttons? Even a text file would do probably!
- Rich
10114.286 In reply to 10114.285
HI Rich, there's an attempt at that in the help file Shortcut Keys section:
https://moi3d.com/4.0/docs/moi_command_reference11.htm#shortcutkeys
I happened to miss CPlane there though, I've made a note to update it next pass through docs.
10114.287 In reply to 10114.286
Great...Would it be as simple as next to the 'Add' 'Delete' buttons on the shortcut interface there's a hyperlink to that reference or something? Too messy? I guess the thing is - the jump between being inside the program / finding your way to that info?
10114.288
Michael,
Is there any chance to see this stereographic projection implemented as an option in a future release?
https://moi3d.com/forum/messages.php?webtag=MOI&msg=8976.1&highlight=yes
I think it would be terrific at giving more realistic proportional feedback while designing in MoI. I was sad that this "hack" wasn't workable with the Macintosh version of V.3...
Mark G.
10114.289 In reply to 10114.288
Hi Mark,
It's only been very rarely discussed or requested so sorry it's not too likely to be an area that I'll be able to dedicate time to working on.
10114.290
Support of the .webp format.
10114.291 In reply to 10114.290
3dm and Rhinoceros files support groups and blocks this would be a really great feature if implemented in the next Moi3D release
Maybe that was already asked by others but is hard read everything in this long list.
Show messages:  1-11  …  212-231  232-251  252-271  272-291  292-311  312-331  332-351  …  652-656
