V5 Wish List
 1-19  …  200-219  220-239  240-259  260-279  280-299  …  640-656
10114.240 In reply to 10114.239
Hnmm yeah just doing some tests, perhaps it was nested blocks inside the groups that were giving errors - I'll wait for a test case! Usually given mega files that have been passed down through many hands so hard to work out what might be causing issues - great to know groups are just passed over...Thanks for "ExplodeBlock" also will go into the arsenal...
- Rich
10114.241
Probably a low priority:
How about a "make copy(s)" option on the Align tool?
MindSet
10114.242 In reply to 10114.20
I hope V5 has the function of material mapping. In addition, objects can display ground shadows
10114.243
It would be useful and presumably straightforward to provide the full filename to the clipboard.
It would also be useful to provide the recent file list to a popup.
Mindset
10114.244 In reply to 10114.243
Hi Mindset,
If you hover your mouse over the filename at the top of the side pane, it will show a tooltip with the full path.
The file menu is a popup that uses the recent file list, so you can look at FileMenu.htm for an example of this.
10114.245 In reply to 10114.244
Thank you Michael,
Great, I'll see if I can conjure up a popup from that example.
If successful, I'll post the results here to share.
Such a recent file list popup will be useful for import.
Additionally, I would be nice to have the option of importing only visible objects from a source file.
Any hints on doing that, or about how to remove hidden objects added by an import?
Separately, I'll try to get the current file-path by using the Save command as an example.
Mindset
EDITED: 23 Jul 2021 by IGNITER
10114.246 In reply to 10114.234
Sorry if it will be an unrealistic wish.
I would like to have the ability to put there some global variables which would be put together into one chart where I could change f.e. change hole size globally. This should work globally for every element and allow change parameter of that element (in some cases it is length in some cases radius or overall dimensions). This variable could be assigned same as name and colour (assigned name could be the binder of those properties). This could be limited to dimensions of a whole solids if the internal lines and circles would be too hard.
I would like also to have a dynamic copy of a whole solid body (instance), dynamic array (array of instances) and dynamic mirror (mirrored and copied instance).
This should be done in a minimalistic way with easiness of use (like rest of GUI). It could be done also very limited to work only on most used cases.
That is my dream about MoI 5 :)
EDITED: 23 Jul 2021 by MDESIGN
10114.247 In reply to 10114.245
Hi Mindset,
For removing hidden objects that were just imported earlier in the same command, try this (warning untested code):
var objs = moi.geometryDatabase.getObjects();
for ( var i = 0; i < objs.length; ++i )
    var obj = objs.item(i);
    if ( obj.hidden && obj.databaseRevision > moi.command.lastCommandRevisionEnd )
        moi.geometryDatabase.removeObject( obj );
You can use moi.geometryDatabase.currentFileName to get the full path of the current file , and if you want to copy it to the clipboard pass it to moi.copyTextToClipboard();
10114.248 In reply to 10114.246
Hi mdesign,
There are other programs called "parametric CAD" that are very focused on this type of work. If this is an important feature for you, i would strongly recommend using one of those programs for this work rather than MoI.
SolidWorks would be a good one to check out, I think they have a way to link a parametric variable to Excel.
The focus on MoI is on making things quick and fluid to draw. It's not focused on this kind of process control that you need.
10114.249 In reply to 10114.248
Hi mDesign,
A hobbyist level CAD option might be Alibre Atom3D.
It has the parametric feature, so you might want to check it out.
Just FYI,
Mindset
10114.250
I might have missed your reply to this request, but just to be sure you didn't miss it... :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=10114.223
Thanks!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
10114.251 In reply to 10114.246
Hi mdesign, maybe you could use Node-editor for some of the effects you are looking for. :-)
10114.252 In reply to 10114.250
Hi Metin,
Sorry I didn't know you were wanting a reply to that. One of the initial focus areas for MoI was to make it possible to use without touching a keyboard at all, so something like that very focused on typed in input is not going to be a high priority, sorry. But it's here on the list for future reference.
For the general area of keyboard input, enabling multiple shortcut keys in sequence is currently a higher priority than auto-complete for typed in command names.
10114.253 In reply to 10114.252
Thanks Michael!
I understand, although I hope the auto-complete feature will be added in the near future. :)
An alternative might be a drag and drop option to easily add custom commands to the MoI UI, with automatic button and text label creation.
─ Metin
10114.254
Hi, I would have a request for the next version and it is the possibility of also being able to measure the radius of beziér or cubic curves, not generated by a circle, since the representation of the circles with nurbs is always an approximation, as can be done with other programs CAD where the detected dimension is dynamic and changes with curvature and also the detected center moves dynamically.
10114.255 In reply to 10114.253
Hi Metin,
There is quite a lot of work involved in either of these so sorry don't expect it in the near future.
10114.256 In reply to 10114.254
Hi pafurijaz,
> to measure the radius of beziér or cubic curves, not generated by a circle, <...>
Moi's radius dimension is designed not to do that because it can be dangerous. It's too easy for someone to mistakenly think that a curve that looks similar to a circle is actually an exact circle and then put a dimension on it not knowing that the radius is not constant across the entire length of the curve.
This is not correct, a NURBS curve can exactly represent a circle without approximation, that's why it has "weight" values as part of it's formulation. The weights (which give the "R" part of NURBS for "Rational") give NURBS curves the ability to exactly represent conic sections.
Is there any CAD program other than Rhino that behaves that way? I just tested with ViaCAD for example and it does not put a radius dimension on a general spline curve.
I would think that's probably an unusual function specific to Rhino because normally a radial/diametric dimension should indicate an arc or circle curve and not a general spline curve that only happens to have the indicated value just at that point location.
10114.257 In reply to 10114.256
About the approximation I have read this here on wikipedia. but maybe I've haven't read all the paragraph, only the first part. https://en.wikipedia.org/wiki/Non-uniform_rational_B-spline#Example:_a_circle.
About the program can do that, If I remember well Solidedge I'm sure NX and the others and can insert a dynamic radius on a curve and also FreeCad, and I'm pretty sure Autocad but I don't remember well if was it or an other at my previous job
These image attached is a SubD cylinder with imported in Moi and then exported in FreeCAD and I was warned about the curve isn't circle and the measure can be irregular
And this image is on FreeCad and show the curvature normal on B-spline and is possible to get the visualization of this on Moi3d maybe with a script?
10114.258 In reply to 10114.257
Hi pafurijaz,
Right, it says this:
quote:
"Non-rational splines or Bézier curves may approximate a circle, but they cannot represent it exactly. Rational splines can represent any conic section, including the circle, exactly."
Non-rational splines, meaning a spline type without weight values in addition to x,y,z values for every control point, can only approximate a circle. That's why a NURBS curve is not a non-rational spline, the R in NURBS is for Rational.
As it says in the 2nd sentence, Rational splines (which includes NURBS) can represent circles exactly.
The Bezier curves in 2D illustration programs like Adobe Illustrator are non-rational cubics and can only approximate circles, unlike NURBS which can represent circles exactly.
re: AutoCAD radius dimension on spline
I don't have a running copy here at the moment but no I don't think that is correct:
https://forums.autodesk.com/t5/autocad-2000-2000i-2002-archive/radius-dimension-of-a-spline/td-p/1773056
https://www.cadforum.cz/en/how-to-dimension-radius-and-center-of-a-spline-in-a-given-point-tip12282
Sorry no MoI doesn't currently have a function for visualizing the curvature graph. It is possible for scripts to evaluate curvature properties of curves now so a script could be possible but I don't know if there is one.
10114.259 In reply to 10114.257
Hi pafurijaz, here's a script that might help with putting radius dims onto non-circular curves. It generates a circle for the curvature at a point on a curve, so then you can probably use the circle to apply a dimension.
Show messages:  1-19  …  180-199  200-219  220-239  240-259  260-279  280-299  300-319  …  640-656
