V5 Wish List
 1-7  …  168-187  188-207  208-227  228-247  248-267  …  648-656
10114.208 In reply to 10114.207
Hi Marc,
> Also, a function to directly cut a line at a certain point, in one click would be nice.
Try this plugin.
10114.209 In reply to 10114.208
Cool ! No need to select a curve!!!
French version :)
https://moiscript.weebly.com/pts-dune-courbe.html
EDITED: 3 Jun 2021 by PILOU
Seems SplitAtPoint don't work with Circle, closed curves etc...
10114.211 In reply to 10114.208
That's perfect .
And congrats on the new hockey team, lets see what those Krakens can do!
Marc
10114.212 In reply to 10114.210
Yes that's correct, it can only split an open curve. To split a closed curve use the regular Edit > Trim command instead of this special version.
10114.213
Or the "AddPt" command with the "Make corner point" setting, which puts an opposite point on a closed curve by itself, dividing the curve into two parts.
Size: 158.8 KB, Downloaded: 162 times, Dimensions: 1365x924px
10114.214 In reply to 10114.213
Hi, i would like to have groups of styles. I often come up with a lot of styles, and some objects with a lot of styles . Grouping should be convenient. The possibility of masking some styles inside the group, off course, and a way of quickly viewing only the group i want. Also some mechanism to select in a list when naming an object. I know there is a script to do that, but some kind of automatism should be easier.
I'd like to see a visual difference between a corner point and a smooth point. Both have very different attributes, but they look the same.
Maybe an option to set corner points to a square, or a different color, or some type of indication without opening a panel or running a script.
Examples:
Corner points in construction curves can cause unwanted behavior in Lofts and Fillets. I try to construct curves in the simplest way possible and only use corner points when needed. But they can appear when making a Mirror, and it would help a lot to see them at a glance.
Sometimes I want a corner point in the middle of a curve so a seam gets created. This allows me to assign two colors to the same curved object. Again, I can't just look at a curve and see the difference.
A bonus would be to have the ability to switch from one type to another by double-clicking on the point.
Function
Falling vertically an object to the next touching one...
10114.217
I have a licensed program that only allows as many instances running on my network as I have licenses.
When I try to start another instance on another computer and I have no unused licenses it lists the computers running the program and asks if I would like to kill one and free up the license.
I would like to see that approach available with MOI - it would suit my working environment.
Frederick
10114.218
Hello Michael,
I have got a question is it possible to create a closed circular object using patterns/curves distributed radially around a point/axis ?
10114.219 In reply to 10114.218
Hi Psygorn, by "closed circular object" do you mean a sphere or a torus or something else?
10114.220 In reply to 10114.219
Hi Michael I meant Torus!
Dear Michael please take a look at the attached file.
Also I have got another question for you! is it possible to rotate a desired curve along an axis while Array circular is used? I think with this we can create many interesting shapes :-) ! ( However I have to say I don't know if this type of effect is achievable by node-editor or not)
Edit: if you take a look at the attached file you will see a bunch of curves if you select them all and perform loft on them it MOI gives you an interesting shaped object! but unfortunately it is not closed! I wanted to know if there is a method to have the object just by using loft! ( I think it is possible to get the object by chopping some sections of it and then sawing those sections into the desired shape, I just wanted to know if it is possible by using loft command)
One more thing, I tried swipe and it gives me a closed object but there is a nasty twist at the end! How could I fix that?
EDITED: 5 Jul 2021 by DRILLBIT
10114.221 In reply to 10114.220
Hi Psygorn,
There isn't any option directly in the array circular command to perform an additional rotation on top of the one that it is already doing. But you could try using a combination of commands to get that effect, I'd probably try Array circular with the center point for the array at the center of the object with a vertical step applied. That will make a vertical stack of rotated objects and you can then arrange that onto a circle using Transform > Deform > Flow.
Another way you could do it is to make a vertical stack of unrotated copies and then apply the twist command on that.
There's a "Closed" checkbox option in the Loft command for doing that:
You'll need to drag the seam point for each section to control how they are matching up with each other. It might be easier for something like this to make a straight version of it and then use Flow to apply it onto a circle.
10114.222 In reply to 10114.220
Hi Psygorn, so I think the twisting effect at the close point of the loft is caused from your rotation pattern not ending at a full 360 degree rotation at the end. I think your rotations add up to a final 180 degree rotation at the end so the end does not return to by synched up with the start.
I count 20 stations, and you have a rotation of 45 degrees for each station.
45 x 20 = 900 degrees.
900 degrees / 360 = 2.5
So the problem there is that it's spinning 2 and a half full rotations from the start to the end. The half part is what is the problem, you need the full rotation to be some even multiple of 360 degrees for it to make a non twisted result where the start and end meet up.
10114.223
I don't know if this has been asked before, but I would really welcome an auto-complete function for the command input field after pressing Tab.
It would save a lot of assigning and remembering of keyboard shortcuts if you could just press Tab, then start typing "r" and immediately get a little pop-up list with "Rotate", "Revolve", "Rectangle", "Rebuild" etcetera.
Then if you continue typing, "re" would cause only "Revolve", "Rectangle", "Rebuild" and other commands starting with "Re" to remain present in the list, and so on.
The pop-up list would preferably be ordered by command usage frequency (maybe with an alphabetical list sorting option in the Options).
It would also be great if the list would be conditional, meaning that if you start typing in the command input field when no object is selected, commands that operate on a selection would be excluded from the list.
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
EDITED: 7 Jul 2021 by METIN_SEVEN
10114.224 In reply to 10114.222
Aha! Thank you Michael! :-)
Didn't know that!
10114.225
In your long list of wishes would be be feasible for MOI to handle direct printing from within the app - I use output to PDF which works a treat especially with templates but a direct to printer would take it to the next level.
Just a thought in case Santa was listening.
Alex.
10114.226 In reply to 10114.225
Hi Alex, re:printing - maybe at some point but there's a lot of potential stuff for handling printing well especially cross platform. I am pretty happy handing that job off to a PDF reader currently.
Stuff like that where it will take a lot of work and the benefit is not all that much tends to lose out in priority weighing.
10114.227
Figured that could be the case PDF it is!
thanks again
Alex.
Show messages:  1-7  …  148-167  168-187  188-207  208-227  228-247  248-267  268-287  …  648-656
