V5 Wish List
 1-20  …  161-180  181-200  201-220  221-240  241-260  …  641-656
10114.201 In reply to 10114.199
Dan & Michael - That's exactly what I was thinking. Just a little dot to indicated you're in Centered mode for those instances when you select an object, quickly zoom in, then think, "What mode am I in?"
10114.202 In reply to 10114.199
Hi Dan, I'm not sure about that, the dot doesn't really indicate "centering" very much. Maybe though.
10114.203 In reply to 10114.202
Something like this? But without the text.
10114.204 In reply to 10114.203
A take on Ed's suggestion
MindSet
EDITED: 29 May 2021 by IGNITER
10114.205 In reply to 10114.203
I've tried to let these sink in for a bit but they're still seeming kind of weird.
10114.206 In reply to 10114.205
EDITED: 2 Jun 2021 by SBEECH
Size: 53.8 KB, Downloaded: 130 times, Dimensions: 679x547px
10114.207
It would be nice to have 2d blend that would work on any part of the curve instead of just the endpoints.
An option to trim at that point would be interesting also.
Also, a function to directly cut a line at a certain point, in one click would be nice.
Marc
10114.208 In reply to 10114.207
Hi Marc,
Try this plugin.
10114.209 In reply to 10114.208
Cool ! No need to select a curve!!!
French version :)
https://moiscript.weebly.com/pts-dune-courbe.html
EDITED: 3 Jun 2021 by PILOU
Seems SplitAtPoint don't work with Circle, closed curves etc...
10114.211 In reply to 10114.208
That's perfect .
And congrats on the new hockey team, lets see what those Krakens can do!
Marc
10114.212 In reply to 10114.210
Yes that's correct, it can only split an open curve. To split a closed curve use the regular Edit > Trim command instead of this special version.
10114.213
Or the "AddPt" command with the "Make corner point" setting, which puts an opposite point on a closed curve by itself, dividing the curve into two parts.
Size: 158.8 KB, Downloaded: 162 times, Dimensions: 1365x924px
10114.214 In reply to 10114.213
Hi, i would like to have groups of styles. I often come up with a lot of styles, and some objects with a lot of styles . Grouping should be convenient. The possibility of masking some styles inside the group, off course, and a way of quickly viewing only the group i want. Also some mechanism to select in a list when naming an object. I know there is a script to do that, but some kind of automatism should be easier.
I'd like to see a visual difference between a corner point and a smooth point. Both have very different attributes, but they look the same.
Maybe an option to set corner points to a square, or a different color, or some type of indication without opening a panel or running a script.
Examples:
Corner points in construction curves can cause unwanted behavior in Lofts and Fillets. I try to construct curves in the simplest way possible and only use corner points when needed. But they can appear when making a Mirror, and it would help a lot to see them at a glance.
Sometimes I want a corner point in the middle of a curve so a seam gets created. This allows me to assign two colors to the same curved object. Again, I can't just look at a curve and see the difference.
A bonus would be to have the ability to switch from one type to another by double-clicking on the point.
Function
Falling vertically an object to the next touching one...
10114.217
I have a licensed program that only allows as many instances running on my network as I have licenses.
When I try to start another instance on another computer and I have no unused licenses it lists the computers running the program and asks if I would like to kill one and free up the license.
I would like to see that approach available with MOI - it would suit my working environment.
Frederick
10114.218
Hello Michael,
I have got a question is it possible to create a closed circular object using patterns/curves distributed radially around a point/axis ?
10114.219 In reply to 10114.218
Hi Psygorn, by "closed circular object" do you mean a sphere or a torus or something else?
10114.220 In reply to 10114.219
Hi Michael I meant Torus!
Dear Michael please take a look at the attached file.
Also I have got another question for you! is it possible to rotate a desired curve along an axis while Array circular is used? I think with this we can create many interesting shapes :-) ! ( However I have to say I don't know if this type of effect is achievable by node-editor or not)
Edit: if you take a look at the attached file you will see a bunch of curves if you select them all and perform loft on them it MOI gives you an interesting shaped object! but unfortunately it is not closed! I wanted to know if there is a method to have the object just by using loft! ( I think it is possible to get the object by chopping some sections of it and then sawing those sections into the desired shape, I just wanted to know if it is possible by using loft command)
One more thing, I tried swipe and it gives me a closed object but there is a nasty twist at the end! How could I fix that?
EDITED: 5 Jul 2021 by DRILLBIT
Show messages:  1-20  …  141-160  161-180  181-200  201-220  221-240  241-260  261-280  …  641-656
