V5 Wish List
 1-13  …  154-173  174-193  194-213  214-233  234-253  …  654-656
10114.194
Hello all, I would like to know your opinion.
Would it be a good idea to have such a thing in MOI?
Edit: I think this way users could save short keys and they could have access to a wider range of commands/scripts/plugins.
10114.195 In reply to 10114.194
Hi Psygorn, I think that's probably something that I can set up as part of making multiple shortcut keys in sequence work in the future.
10114.196 In reply to 10114.195
Tanx Michael.
Edit Frame behavior request:
Clicking on an Edit Frame handle toggles the round marker to let me know if I'm about to scale from the object's center, or from one side.
To get accurate mouse movements and see the object close up, I often zoom in to a level where the marker is off screen. I know I should look first to see what mode I'm in, but forget most the time.
Is it possible to add some kind of handle indicator, or handle color change, or handle line thickness change to show if I'm about to scale from the side rather than the center when zoomed in?
10114.198 In reply to 10114.197
Hi Ed,
> when zoomed in?
Nothing really pops into mind for a color or thickness that would convey a meaning of "scale from center" vs "scale from corner".
Do you have any ideas on what that might look like?
10114.199 In reply to 10114.198
Maybe if it's set to center....
The rotation tool of the Edit Frame is not very visible in numerous situations!
10114.201 In reply to 10114.199
Dan & Michael - That's exactly what I was thinking. Just a little dot to indicated you're in Centered mode for those instances when you select an object, quickly zoom in, then think, "What mode am I in?"
10114.202 In reply to 10114.199
Hi Dan, I'm not sure about that, the dot doesn't really indicate "centering" very much. Maybe though.
10114.203 In reply to 10114.202
Something like this? But without the text.
10114.204 In reply to 10114.203
A take on Ed's suggestion
MindSet
EDITED: 29 May 2021 by IGNITER
10114.205 In reply to 10114.203
I've tried to let these sink in for a bit but they're still seeming kind of weird.
10114.206 In reply to 10114.205
EDITED: 2 Jun 2021 by SBEECH
Size: 53.8 KB, Downloaded: 130 times, Dimensions: 679x547px
10114.207
It would be nice to have 2d blend that would work on any part of the curve instead of just the endpoints.
An option to trim at that point would be interesting also.
Also, a function to directly cut a line at a certain point, in one click would be nice.
Marc
10114.208 In reply to 10114.207
Hi Marc,
Try this plugin.
10114.209 In reply to 10114.208
Cool ! No need to select a curve!!!
French version :)
https://moiscript.weebly.com/pts-dune-courbe.html
EDITED: 3 Jun 2021 by PILOU
Seems SplitAtPoint don't work with Circle, closed curves etc...
10114.211 In reply to 10114.208
That's perfect .
And congrats on the new hockey team, lets see what those Krakens can do!
Marc
10114.212 In reply to 10114.210
Yes that's correct, it can only split an open curve. To split a closed curve use the regular Edit > Trim command instead of this special version.
10114.213
Or the "AddPt" command with the "Make corner point" setting, which puts an opposite point on a closed curve by itself, dividing the curve into two parts.
Size: 158.8 KB, Downloaded: 162 times, Dimensions: 1365x924px
Show messages:  1-13  …  134-153  154-173  174-193  194-213  214-233  234-253  254-273  …  654-656
