V5 Wish List
 1-6  …  147-166  167-186  187-206  207-226  227-246  …  647-656
10114.187 In reply to 10114.185
Ok, Tanx.
I'll try to check it although I have to confess I am not good at programming at the moment! But I know how fun it would be if one could create his/her own scripts or plugins! :)
By the way is there a thread for it? (Scripting in MOI I mean)
10114.188 In reply to 10114.186
Sorry seems it was a glitch when many decimals are input...
the exact value in the diagonal that input was 9.7832259
normally when you input var min = 9.7832259, max = 9.7832259 that should work but here you must input
var min = 9.7832259, max = 9.7832260
Michael will explain what...it's out my old understanding!
Don't select anything
Press Tab or make a shortcut and write the following line
Press Enter
You must have your 2 diagonals selected!
script: /* Select by length */ var min = 9.7832259, max = 9.7832260; var crvs = moi.geometryDatabase.getObjects().getCurves(); for ( var i = 0; i < crvs.length; ++i ) { var crv = crvs.item(i); var len = crv.getLength(); if ( len>= min && len <= max ) { crv.selected = true; } }
I have just entered 2 diagonals....so only 2 diagonals will be selected!
with Vclone by maxSmirnov you can replace a "vector" by anything! :)
And each objects will take the same direction and size than the vector!
http://moi3d.com/forum/index.php?webtag=MOI&msg=6486.1
EDITED: 24 May 2021 by PILOU
10114.189 In reply to 10114.188
Hi PILOU,
Thank you for your explanations :)
But I don't get it! Why u keep talking about diagonals?
I need to put stitches along these edges. Why should I look for diagonals?
10114.190 In reply to 10114.189
Because a diagonal will be considered like a vector by the Max Smirnov Vclone
Like this you will can replace anything you want by anything you want! :)
If you take the yellow edges how you will distinguish black faces and white face they have same length :)
but what is exactly your target ? Points for make what ?
the file that you give me has different surfaces sizes!
if You want make like the "photo"
with my method you have just to draw only 2 faces ( one black, on white)
Draw the vectors and launch the vClone (twice one for each color) ;)
10114.191 In reply to 10114.190
Hi PILOU,
if you take a look at the attached photo you will see a soccer ball and close to it there is a curve and 7 ring like objects ( I call these stitches)
Do you know a method with which I could replace all the shared edges between pentagonal faces and hexagonal ones with those stitches?
Take a close look at the black pentagonal face I have already put some stitches along one of its edges as an example so you could see what I mean!
10114.192 In reply to 10114.191
so many possibilities, Array files circular, vclone, Oriente Line/line (none) etc...
one method
orange tubes are stiches between Black & White faces
green tubes are stiches between white faces !
1 Black face top and 1 black face bottom
1 array circular from Top for 5 black faces, 1 array circular from bottom for 5 black faces
and only one circular for the last white faces with green tubes :)
10114.193 In reply to 10114.192
Hi PILOU,
I did use array circular for creation of my soccer ball with stitches, but I would like to learn new (and possibly quicker methods) like vclone, Oriente Line/line (none) etc...
So, I'll check them and come back to you if i faced a problem.
10114.194
Hello all, I would like to know your opinion.
Would it be a good idea to have such a thing in MOI?
Edit: I think this way users could save short keys and they could have access to a wider range of commands/scripts/plugins.
10114.195 In reply to 10114.194
Hi Psygorn, I think that's probably something that I can set up as part of making multiple shortcut keys in sequence work in the future.
10114.196 In reply to 10114.195
Tanx Michael.
Edit Frame behavior request:
Clicking on an Edit Frame handle toggles the round marker to let me know if I'm about to scale from the object's center, or from one side.
To get accurate mouse movements and see the object close up, I often zoom in to a level where the marker is off screen. I know I should look first to see what mode I'm in, but forget most the time.
Is it possible to add some kind of handle indicator, or handle color change, or handle line thickness change to show if I'm about to scale from the side rather than the center when zoomed in?
10114.198 In reply to 10114.197
Hi Ed,
> when zoomed in?
Nothing really pops into mind for a color or thickness that would convey a meaning of "scale from center" vs "scale from corner".
Do you have any ideas on what that might look like?
10114.199 In reply to 10114.198
Maybe if it's set to center....
The rotation tool of the Edit Frame is not very visible in numerous situations!
10114.201 In reply to 10114.199
Dan & Michael - That's exactly what I was thinking. Just a little dot to indicated you're in Centered mode for those instances when you select an object, quickly zoom in, then think, "What mode am I in?"
10114.202 In reply to 10114.199
Hi Dan, I'm not sure about that, the dot doesn't really indicate "centering" very much. Maybe though.
10114.203 In reply to 10114.202
Something like this? But without the text.
10114.204 In reply to 10114.203
A take on Ed's suggestion
MindSet
EDITED: 29 May 2021 by IGNITER
10114.205 In reply to 10114.203
I've tried to let these sink in for a bit but they're still seeming kind of weird.
10114.206 In reply to 10114.205
EDITED: 2 Jun 2021 by SBEECH
Size: 53.8 KB, Downloaded: 130 times, Dimensions: 679x547px
Show messages:  1-6  …  127-146  147-166  167-186  187-206  207-226  227-246  247-266  …  647-656
