V5 Wish List
 1-17  …  98-117  118-137  138-157  158-177  178-197  …  638-656
10114.138 In reply to 10114.136
Hi mdesign,
> In the matter of ViaCad. I`ve asked on their forum. Only ViaCad Pro has got ACIS kernel modeling
> tools. ViaCad 2d/3d doesn`t. It changed lately. It`s not so cheap to buy it only for fillets.
Are you sure about this? Their feature comparison page here:
https://www.punchcad.com/product-line-comparison
Has "ACIS® Solid Modeling Kernel" and "Shelling, Blending" both marked for ViaCAD 2D/3D...
10114.139 In reply to 10114.138
On one chart they showed that ACIS is inside on other they showed there is no ACIS. That second was changed since I`ve read about it.
I`ve asked on their forum cause I`ve read few threads there about it and I want to make sure.
http://forum.punchcad.com/default.aspx?g=posts&t=10517#post39953
They sends only PRO version as trial so it`s impossible to check before buying.
If it`s true then it`s dirty move to write not truth on their site.
QUOTE: "PunchCAD, that is, ViaCAD and Shark and variants, was originally the 'retail' line that grew out of Concepts Unlimited. Punch! was bought up by Encore/Broderbund, Encore by IMSI in turn. Licensing arrangements have been subject to those realignments, ownership and management changes, the loss of Mesh-to-NURBS and even the removal of ACIS from base versions are an unfortunate outcome. It's useful to remember that Shark Pro V10 and PPPro have flexible license that enable installation on multiple PCs, even now. Installations can only be open one at a time, but V11 and V12 can't be multiple-installed, and to me, that's as great a loss as mesh-to-nurbs. Maybe time for dongles to make a comeback?"
this quote was from this site: http://forum.punchcad.com/default.aspx?g=posts&m=39920#post39920
EDITED: 8 May 2021 by MDESIGN
10114.140 In reply to 10114.139
Hmmm. well the responses on the forum do not seem to be from someone at the company itself.
That's a bummer if that's correct though.
10114.141 In reply to 10114.140
1) this was official forum
2) look on features in ViaCAD Pro they say something about ACIS in ViaCAD 2d/3d is nothing. Look also that ViaCad 2d/3d has no STEP translator which has been done with using ACIS.
Edit: For that price of ViaCAD Pro is possible to buy parametric Alibre Design (also ACIS).
Edit2: Is it very expensive to include ACIS kernel from MoI modeling tools into even if MoI would cost twice? Is it possible? I mean only those which are better. Or its bad idea to mix more than one kernel in CAD software? I deam loudly about MoI with some ACIS/parasolid filleting, offseting and shelling. I`m asking because in Rhino I use very nice Xnurbs patching plugin which has own kernel only for this single operation and it`s brilliant. I hope there will be more plugins like that.
10114.142 In reply to 10114.141
Hi mdesign, I guess it looks like that is true about ViaCAD 2D/3D "regular" version not having ACIS anymore. It's also discussed here:
http://forum.punchcad.com/default.aspx?g=posts&t=10462#post39765
That doesn't make a lot of sense to rip out so many functions from a program and then present it as a new version to upgrade to.
10114.143
Here is MOI to 123d and Back to MOI via STEP file format.
Using version 123D_Design_R2.2_WIN64_2.2.14
10114.144 In reply to 10114.142
that's a pity. I wanted to give them my money but after seeing that compare chart and for moves like this I won`t.
That purchase of ViaCAD PRO for more than 600$ is without sense.
10114.145 In reply to 10114.143
But no need to used (for avoid any problem) it if you turn the Generator curve of the sphere before the Union! ;)
It must don't touch the cube!
Then Fillets works like a charm! :)
Try with this one! https://moiscript.weebly.com/uploads/3/9/3/8/3938813/exo0905.3dm
Don't ask me why! :) you must turn it! (fillet 1 will be fine)
EDITED: 8 May 2021 by PILOU
10114.146 In reply to 10114.141
Hi mdesign,
It's possible to use more than one kernel but it can be difficult if one of them is finicky about what kind of geometry it accepts. Both ACIS and Parasolid are on the fairly finicky side of things.
10114.147
I don't know if anyone asked for this before!
Could we have something like C-selection in blender?
(in blender in wire frame mode one can press C and then a circle appears around the mouse radius of the circle is controllable by mouse wheel, with that circle the user is able to select certain edges, surfaces, points. and by pressing Shift user can deselect)
Could we have such thing? It would be useful for cases I have tried to show below:
10114.148 In reply to 10114.147
Hi Psygorn, what are you trying to select in the case you are showing, is it all the vertical edges or something else?
10114.149 In reply to 10114.145
"But no need to used (for avoid any problem) it if you turn the Generator curve of the sphere before the Union! ;)
Don't ask me why! :) you must turn it! (fillet 1 will be fine)"
This is an often valid solution indeed. Calculations like fillets are more prone to failure if the fillet crosses a surface seam.
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
10114.150
This has probably been mentioned before, but I'd like to add the wish for SVG export from MoI. That would be very welcome for working with Blender next to MoI.
Thanks in advance!
─ Metin
10114.151 In reply to 10114.148
It's just a show case imagine I would like to select bunch of those vertical lines! (Maybe the photo is not a good example)
Is lasso selection possible in MOI?
Also in blender there is an ability in which for example user selects middle face, edges or points and then by holding Ctrl & + together; Blender selects adjacent faces, edges, point according to the number of times user presses mentioned keys. Do we have such an ability in MOI? Could we have such an ability in MOI? (I have tried to show this ability in the attached photo imagine you select middle rectangle and then by pressing a desired short key Moi would select faces that are in contact with middle rectangle)
10114.152 In reply to 10114.151
Hi Psygorn,
You can do that in MoI by using a crossing window - that's where you drag a selection window starting on the right side and moving towards the left. That will show a selection rectangle with a dashed outline which means that anything that intersects with the window at all will be selected. Here is an example with vertical lines:
There isn't a lasso selection but there is a window selection. Window selection starting from left going towards the right shows a solid outline and will only target objects completely inside the window. Starting from the right going towards the left will show a dashed outline and target anything that has any part crossing the window.
Yes, you can set up a shortcut key to expand selection like that:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6988.4
10114.153 In reply to 10114.151
Maybe not exactly that you want but you have some selection commands
you can edit anything
script: /* Selection by length so similar */ var min = 1.0, max = 5.0; var crvs = moi.geometryDatabase.getObjects().getCurves(); for ( var i = 0; i < crvs.length; ++i ) { var crv = crvs.item(i); var len = crv.getLength(); if ( len>= min && len <= max ) { crv.selected = true; } }
script: /* Sélection < or > something given --> edit ">"*/ var size = 1.0; var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); var bbox = obj.getBoundingBox(); if ( bbox.diagonalLength < size ) obj.selected = true; }
script: /* Longest Curve */ var curves = moi.geometryDatabase.getObjects().getCurves(); var maxlen = -1; var maxcrv = null; for ( var i = 0; i < curves.length; ++i ) { var crv = curves.item(i); if ( crv.hidden || crv.locked ) { continue; } var thislen = crv.getLength(); if ( thislen> maxlen ) { maxlen = thislen; maxcrv = crv; } } if ( maxcrv != null ) maxcrv.selected = true;
script: /* Smallest Curve*/ var curves = moi.geometryDatabase.getObjects().getCurves(); var minlen = 1e100; var mincrv = null; for ( var i = 0; i < curves.length; ++i ) { var crv = curves.item(i); if ( crv.hidden || crv.locked ) { continue; } var thislen = crv.getLength(); if ( thislen < minlen ) { minlen = thislen; mincrv = crv; } } if ( mincrv != null ) mincrv.selected = true;
10114.154 In reply to 10114.152
That's great :)
10114.155 In reply to 10114.153
Tanx PILOU :)
10114.156 In reply to 10114.152
@Michael,
I have another question. In MOI hidden faces still interact? take a look at the attached photo I hid two faces. and I wanted to select only those circular faces using box selection but I was not able to do so!
10114.157 In reply to 10114.156
script: function es(edg){ var i,f; for (i=0; i<edg.length; i++) {f=edg.item(i).getFacesOfEdge(); f.setProperty('selected',1);}} var so = moi.geometryDatabase.getSelectedObjects(), sf=so.getFaces(), i; for ( i=0; i<sf.length;i++) es(sf.item(i).getEdges()); es(so.getEdges());
Just clic the center circular face then for example Alt + E if you have made a such ShortCUt...
Show messages:  1-17  …  78-97  98-117  118-137  138-157  158-177  178-197  198-217  …  638-656
