V5 Wish List
 1-11  …  92-111  112-131  132-151  152-171  172-191  …  652-656
10114.132 In reply to 10114.129
Hi Psygorn,
> Is it possible to use 123D as a companion to MOI for fillets?
Yes, I think you can transfer back and forth to it using STEP format.
> Does the below link have the latest version of it? is it version 2.2.14 ?
Sorry, don't know.
> What software (preferably free & light weight) you suggest to be used as a companion for fillets?
You might try ViaCAD, OnShape, or Fusion360.
10114.133 In reply to 10114.131
Hi Psygorn,
> For example imagine I want to use Boolean Merge, Could I press C -> B -> M (C for targeting Construct, B for Boolean & M for Merge)
> Is it possible to do so in MOI?
Sorry no currently there isn't anything set up to do keyboard shortcuts in that particular way.
10114.134 In reply to 10114.132
Tanx,
By the way the link I mentioned before seems not working! for me! It is as if it keeps downloading for ever!
Yes it's very difficult to download somewhere this 2.2.14....
Another free one is Design Spark Mechanical 5.0 but it's some tricky for use it with Moi! ;)
(it's a light version of SpaceClaim)
see here https://moi3d.com/forum/index.php?webtag=MOI&msg=6186.1
EDITED: 8 May 2021 by PILOU
10114.136
https://web.archive.org/web/20160218191658/http://www.123dapp.com/design - this link works I dont know which version is it. This site shows www from past dates (old www backups).
https://web.archive.org/web/20160401000000*/http://123dapp.com - you should click every date and look for valid site with download like above.
In the matter of ViaCad. I`ve asked on their forum. Only ViaCad Pro has got ACIS kernel modeling tools. ViaCad 2d/3d doesn`t. It changed lately. It`s not so cheap to buy it only for fillets.
There is some open source kernel OpenInventor (Coin3d framework). If Inventor has better fillets than MoI3d and Rhino then why someone won`t build paid plugin for both with using that kernel? I think many people would buy it. Only for fillets, offsets and shelling (if its better). I`ve heard that some of FreeCAD users want to implement that kernel in FreeCAD (I think I`ve heard it here about future plans of changing freecad: https://www.youtube.com/watch?v=7Z-GBpV97q8)
EDITED: 8 May 2021 by MDESIGN
10114.137 In reply to 10114.136
HI mdesign, OpenInventor is not a CAD geometry kernel, it is what is called a "scene graph". It's basically a library for managing the display of 3D objects.
There is also a CAD program called "Inventor" made by Autodesk but it does not have any relation to the OpenInventor scene graph library.
10114.138 In reply to 10114.136
Hi mdesign,
Are you sure about this? Their feature comparison page here:
https://www.punchcad.com/product-line-comparison
Has "ACIS® Solid Modeling Kernel" and "Shelling, Blending" both marked for ViaCAD 2D/3D...
10114.139 In reply to 10114.138
On one chart they showed that ACIS is inside on other they showed there is no ACIS. That second was changed since I`ve read about it.
I`ve asked on their forum cause I`ve read few threads there about it and I want to make sure.
http://forum.punchcad.com/default.aspx?g=posts&t=10517#post39953
They sends only PRO version as trial so it`s impossible to check before buying.
If it`s true then it`s dirty move to write not truth on their site.
QUOTE: "PunchCAD, that is, ViaCAD and Shark and variants, was originally the 'retail' line that grew out of Concepts Unlimited. Punch! was bought up by Encore/Broderbund, Encore by IMSI in turn. Licensing arrangements have been subject to those realignments, ownership and management changes, the loss of Mesh-to-NURBS and even the removal of ACIS from base versions are an unfortunate outcome. It's useful to remember that Shark Pro V10 and PPPro have flexible license that enable installation on multiple PCs, even now. Installations can only be open one at a time, but V11 and V12 can't be multiple-installed, and to me, that's as great a loss as mesh-to-nurbs. Maybe time for dongles to make a comeback?"
this quote was from this site: http://forum.punchcad.com/default.aspx?g=posts&m=39920#post39920
10114.140 In reply to 10114.139
Hmmm. well the responses on the forum do not seem to be from someone at the company itself.
That's a bummer if that's correct though.
10114.141 In reply to 10114.140
1) this was official forum
2) look on features in ViaCAD Pro they say something about ACIS in ViaCAD 2d/3d is nothing. Look also that ViaCad 2d/3d has no STEP translator which has been done with using ACIS.
Edit: For that price of ViaCAD Pro is possible to buy parametric Alibre Design (also ACIS).
Edit2: Is it very expensive to include ACIS kernel from MoI modeling tools into even if MoI would cost twice? Is it possible? I mean only those which are better. Or its bad idea to mix more than one kernel in CAD software? I deam loudly about MoI with some ACIS/parasolid filleting, offseting and shelling. I`m asking because in Rhino I use very nice Xnurbs patching plugin which has own kernel only for this single operation and it`s brilliant. I hope there will be more plugins like that.
10114.142 In reply to 10114.141
Hi mdesign, I guess it looks like that is true about ViaCAD 2D/3D "regular" version not having ACIS anymore. It's also discussed here:
http://forum.punchcad.com/default.aspx?g=posts&t=10462#post39765
That doesn't make a lot of sense to rip out so many functions from a program and then present it as a new version to upgrade to.
10114.143
Here is MOI to 123d and Back to MOI via STEP file format.
Using version 123D_Design_R2.2_WIN64_2.2.14
10114.144 In reply to 10114.142
that's a pity. I wanted to give them my money but after seeing that compare chart and for moves like this I won`t.
That purchase of ViaCAD PRO for more than 600$ is without sense.
10114.145 In reply to 10114.143
But no need to used (for avoid any problem) it if you turn the Generator curve of the sphere before the Union! ;)
It must don't touch the cube!
Then Fillets works like a charm! :)
Try with this one! https://moiscript.weebly.com/uploads/3/9/3/8/3938813/exo0905.3dm
Don't ask me why! :) you must turn it! (fillet 1 will be fine)
10114.146 In reply to 10114.141
Hi mdesign,
It's possible to use more than one kernel but it can be difficult if one of them is finicky about what kind of geometry it accepts. Both ACIS and Parasolid are on the fairly finicky side of things.
10114.147
I don't know if anyone asked for this before!
Could we have something like C-selection in blender?
(in blender in wire frame mode one can press C and then a circle appears around the mouse radius of the circle is controllable by mouse wheel, with that circle the user is able to select certain edges, surfaces, points. and by pressing Shift user can deselect)
Could we have such thing? It would be useful for cases I have tried to show below:
10114.148 In reply to 10114.147
Hi Psygorn, what are you trying to select in the case you are showing, is it all the vertical edges or something else?
10114.149 In reply to 10114.145
"But no need to used (for avoid any problem) it if you turn the Generator curve of the sphere before the Union! ;)
Don't ask me why! :) you must turn it! (fillet 1 will be fine)"
This is an often valid solution indeed. Calculations like fillets are more prone to failure if the fillet crosses a surface seam.
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
10114.150
This has probably been mentioned before, but I'd like to add the wish for SVG export from MoI. That would be very welcome for working with Blender next to MoI.
Thanks in advance!
─ Metin
10114.151 In reply to 10114.148
It's just a show case imagine I would like to select bunch of those vertical lines! (Maybe the photo is not a good example)
Is lasso selection possible in MOI?
Also in blender there is an ability in which for example user selects middle face, edges or points and then by holding Ctrl & + together; Blender selects adjacent faces, edges, point according to the number of times user presses mentioned keys. Do we have such an ability in MOI? Could we have such an ability in MOI? (I have tried to show this ability in the attached photo imagine you select middle rectangle and then by pressing a desired short key Moi would select faces that are in contact with middle rectangle)
Show messages:  1-11  …  72-91  92-111  112-131  132-151  152-171  172-191  192-211  …  652-656
