V5 Wish List
 1-10  …  71-90  91-110  111-130  131-150  151-170  …  651-656
10114.111 In reply to 10114.110
Thanks a lot. I haven`t known that too :)
10114.112
Good day.
1.I would like to see the ability to apply a materials to an object like its done in sketchup...not rendered as in keyshot etc but as a sketch would be more than usefull to me.
2.Parametric style editing if possible...sometime if I need to change something that is already done it is not easy.
Tnx.
10114.113 In reply to 10114.1
> // few number record
How about a setting for how many to keep and listing them in a drop list?
10114.114
Shortcut Keys; Options Tab
1. Import / Export
2. Search
3. Upon "Add", warn if key-combo is already in use.
Thanks Mike for all that you do!
EDITED: 2 Apr 2021 by IGNITER
10114.115
I would love to see the introduction of a simple clipping plane (section plane) for sectional analysis of a model, would be hugely beneficial as it is in SketchUp
- Rich
10114.116
I am very interest to see the following in the new update of V5.
1) The introduction of GUMBALL into 3Dmoi because is very effective and easy way to manipulating the NURBS curves to change the orientation of points that you need to create.
2) The introduction of Orient command in 3 points (ORIENT3Pt). This orient command is very effective of 3 points to align an object to another object more easy way.
3) The introduction of essential SubD geometry Tools commands. They are very amaze creations that you can do with them.
4) I like to see an introduction of plug-ins in the 3Dmoi environment to have more abilities in 3D.
These are what I am thinking to see for the next creation of V5.
10114.117 In reply to 10114.115
<< a simple clipping plane (section plane) for sectional analysis of a model
Maybe can be made by the Elephant nodal system
10114.118 In reply to 10114.116
Hi RayCAD,
Can you please post an example file?
10114.119 In reply to 10114.118
Dear Michael,
Thank you for answering my questions regarding V5 update.
This particular command is in 3D Rhino and I try it and very easy to be used.
This particular question you already gave me how to use the existing command in 3DMoi,
referring to Transform --- Orient but the Rhino command is very more easy to use and to align.
I am sending you an attachment explain to you what I am looking for to see it in your next
V5 update.
If it is possible to include the GUMBall into the 3DMoi, I am so happy to see it because the way you
manipulate the points is very easy. The one that 3DMoi have is good but it not like GumBall. Sometimes
I find it frustrated.
Thank you again. Your 3DMoi is fantastic. If you see the Gallery you can see my last project " Space 1999: Eagle Transporter"
all made it with 3DMoi V4 and rendering with Keyshot.
10114.120 In reply to 10114.119
Maybe not so easy but a simple Line-Line (none) + Rotate axis give a same result! :)
10114.121
Good day.
Maybe to add the ability to quickly cut while in 3d view to create interesting shapes
https://www.youtube.com/watch?v=8v76x-7vPEk at 1:42
Also the ability to create 2d drawings for shop use ready to print.
https://www.youtube.com/watch?v=TLkx16udGOA at 1:00
Tnx.
10114.122 In reply to 10114.121
The Cut that you show is Voxels not sure that arrives inside Moi ;)
Boolean Diff cut as weel... so make plane solid by 3 Pts
< < to create interesting shapes
you can make funny forms with Moi ;)
EDITED: 9 Apr 2021 by PILOU
10114.123
Really simple request:
To be able to switch between views with a shortcut key. In Cinema 4D, you can press the scroll wheel on a mouse to switch between all four views to individual views. Or like in Blender, the numeric keypad switches views. That would be smoother than having to press one of the keys at the bottom panel.
And one for the community – more tutorials, workflow tips etc.
Michael – great program, keep up the great work!
10114.124 In reply to 10114.123
Hi Chris, you can set up shortcut keys to switch between views currently, see here for what to put in for the "command" part of the shortcut key:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3808.2
10114.125
Not a barn burner, but maybe an opacity setting for the grid.
It only seemed an issue when using reference images as set from the view tab.
MindSet
10114.126 In reply to 10114.121
for 1 -> i've made a script for that - polycut
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.18
select object -> cut - great for sketching
- Tudor -
10114.127 In reply to 10114.126
Cemortan_Tudor
The script causes Moi3d v4 to hang and get stuck :(
Tnx
10114.128
works fine here
not finished - yes, missing conditions ~ like if u dont select an object exit command or if polyline is not closed close and cut
But at time i was scripting was enough to have at least such one
- Tudor -
10114.129 In reply to 10114.79
Is it possible to use 123D as a companion to MOI for fillets?
Does the below link have the latest version of it? is it version 2.2.14 ?
https://web.archive.org/web/20170202170834/http://www.123dapp.com/design
What software (preferably free & light weight) you suggest to be used as a companion for fillets?
EDITED: 7 May 2021 by DRILLBIT
10114.130 In reply to 10114.65
Hello AlexPolo,
Is it compatible with MOI? Could one export & import models from MOI to it back & forth?
Show messages:  1-10  …  51-70  71-90  91-110  111-130  131-150  151-170  171-190  …  651-656
