V5 Wish List
 1  …  62-81  82-101  102-121  122-141  142-161  …  642-656
10114.102 In reply to 10114.82
@Pilou >You have yet the solution to make a little text file list with any function
then Copy Past the function that you want after the Press TAB! ;)
Rustic but efficient :)
And no problem of memory headache :)
Touche(s) de raccourci :shortcut keys ???! hotkeys, Short!,
The goal is short and quick.
-Zooen
EDITED: 25 Mar 2021 by ZOOEN
10114.103 In reply to 10114.102
Yes shortcuts win some times but put all functions in a shortcut is not valid for old brain! ;)
Over 6 shortcuts is a limite for me! :)
10114.104
What is your count of shortcuts in Blender?
10114.105 In reply to 10114.104
I am not genetically modified for Blender! :)
10114.106
previs of boolean difference, amount of cut
- Tudor -
10114.107 In reply to 10114.91
In Rhino forum one guy posted script for mating: https://discourse.mcneel.com/t/how-to-align-two-objects/121132/32 You can see also how it works in video here.
It`s quite short and simple script. Your method is wonderful I`m only sharing it because it`s in same topic as we talked previously. Maybe it will help somebody to write similar script for MoI (if it will be needed of course).
Cheers!!!
10114.108 In reply to 10114.107
You have the same with native Transform / Orient / Orient or Line Line ! ;)
May fbeew clickc more but...
EDITED: 1 Apr 2021 by PILOU
10114.109 In reply to 10114.108
What is line-line? Have you meant line-line drag and drop constraint?
10114.110 In reply to 10114.109
Yes with only 2 Points as Start and 2 Points as Target + Helpers lines you can make anything you want with the fabulous Line-Line !
( + some parameters if you want Uniform, Stretch, None) , Copy or not )
10114.111 In reply to 10114.110
Thanks a lot. I haven`t known that too :)
10114.112
Good day.
1.I would like to see the ability to apply a materials to an object like its done in sketchup...not rendered as in keyshot etc but as a sketch would be more than usefull to me.
2.Parametric style editing if possible...sometime if I need to change something that is already done it is not easy.
Tnx.
10114.113 In reply to 10114.1
> // few number record
How about a setting for how many to keep and listing them in a drop list?
10114.114
Shortcut Keys; Options Tab
1. Import / Export
2. Search
3. Upon "Add", warn if key-combo is already in use.
Thanks Mike for all that you do!
EDITED: 2 Apr 2021 by IGNITER
10114.115
I would love to see the introduction of a simple clipping plane (section plane) for sectional analysis of a model, would be hugely beneficial as it is in SketchUp
- Rich
10114.116
I am very interest to see the following in the new update of V5.
1) The introduction of GUMBALL into 3Dmoi because is very effective and easy way to manipulating the NURBS curves to change the orientation of points that you need to create.
2) The introduction of Orient command in 3 points (ORIENT3Pt). This orient command is very effective of 3 points to align an object to another object more easy way.
3) The introduction of essential SubD geometry Tools commands. They are very amaze creations that you can do with them.
4) I like to see an introduction of plug-ins in the 3Dmoi environment to have more abilities in 3D.
These are what I am thinking to see for the next creation of V5.
10114.117 In reply to 10114.115
<< a simple clipping plane (section plane) for sectional analysis of a model
Maybe can be made by the Elephant nodal system
10114.118 In reply to 10114.116
Hi RayCAD,
Can you please post an example file?
10114.119 In reply to 10114.118
Dear Michael,
Thank you for answering my questions regarding V5 update.
This particular command is in 3D Rhino and I try it and very easy to be used.
This particular question you already gave me how to use the existing command in 3DMoi,
referring to Transform --- Orient but the Rhino command is very more easy to use and to align.
I am sending you an attachment explain to you what I am looking for to see it in your next
V5 update.
If it is possible to include the GUMBall into the 3DMoi, I am so happy to see it because the way you
manipulate the points is very easy. The one that 3DMoi have is good but it not like GumBall. Sometimes
I find it frustrated.
Thank you again. Your 3DMoi is fantastic. If you see the Gallery you can see my last project " Space 1999: Eagle Transporter"
all made it with 3DMoi V4 and rendering with Keyshot.
10114.120 In reply to 10114.119
Maybe not so easy but a simple Line-Line (none) + Rotate axis give a same result! :)
10114.121
Good day.
Maybe to add the ability to quickly cut while in 3d view to create interesting shapes
https://www.youtube.com/watch?v=8v76x-7vPEk at 1:42
Also the ability to create 2d drawings for shop use ready to print.
https://www.youtube.com/watch?v=TLkx16udGOA at 1:00
Tnx.
Show messages:  1  …  42-61  62-81  82-101  102-121  122-141  142-161  162-181  …  642-656
