Script to create leaders with coordinates
All  1-7  8-18
10013.8 In reply to 10013.7
Hi Larry,
My language is English. Nothing fancy.
The tickbox is there, there is just no text.
I opened the html file and added it to the line of code you show there. (Your line has the text empty also)
Your other tick marks have the text written in that spot of the code....
10013.9 In reply to 10013.8
Hi BurrMan,
Where possible I am making use of the internationalized strings already present in MoI. In the case of the "Project to cplane" CheckButton, the text is already provided by MoI and in use by the dimension/annotation commands so adding it to the CheckButton in this script should be redundant. The other two CheckButtons are unique to my script and thus I provided the text for them. Obviously it didn't work properly & I'm perplexed as to why it works for me but not for you. I'm running a fairly vanilla MoI v4 Oct 27 beta. My only UI tweak is Michael's SeparateSidePanePalettes.js which I've now removed and note that the "Project to cplane" text is still displayed.
Do you see the "Project to cplane" text after the check boxes in the other MoI dimension/annotation commands?
Do you use CustomUI or other startup scripts?
The only difference between the CheckButton's use in Leader vs. my script is that I omitted the style="persist:false" (which I didn't understand) and added default="false" which may be unnecessary:
Leader.htm:
<moi:CheckButton id="ProjectToCPlane" style="persist:false"><moi:Text textid="Dim project to cplane checkbox"/></moi:CheckButton>
Coordinates.htm:
<moi:CheckButton id="ProjectToCPlane" default="false"><moi:Text textid="Dim project to cplane checkbox"/></moi:CheckButton>
--Larry
10013.10 In reply to 10013.9
Hi Larry,
I see. Well, i dont understand much about moi's ui that way, so i would be a bad choice to help track something down, or confirm it that way....
So far, nobody else is having any issue with it. So if it's "just me", then there is no real need to lose hair....
If it turns out to affect others, maybe Michael will jump in to help...
10013.11 In reply to 10013.9
BTW: my guess would be it's a read/write issue on my end.
I run my MoI self contained, so my commands arent in my appdata folder...
I can do a test tommorow to see if the text "gets" if i run MoI as admin....
10013.12 In reply to 10013.11
So I just tested. My guess was wrong...
But this:
""""""""""""Do you see the "Project to cplane" text after the check boxes in the other MoI dimension/annotation commands?""""""""""""""""
No. I cant find anything related to cplane projection in any of the dimension commands...
Mine just automatically projects to the current cplane... But I have no checkboxes for it...
Can someone else show me a screenshot of these checkboxes in the normal dimension commands?
Maybe Michael can clarify.
10013.13 In reply to 10013.12
The coordinates script menu text "Project to cplane" does NOT appear in the Sept 10 2020 beta,
but DOES appear in the October 27 2020 beta. (Ditto for the dim dimensions menu's, for old beta.)
( A guess is that Apparently the text does not exist at all in the old beta.)
Larry's coordinates.js and .htm files can be copied to either %APPDATA% commands folder, or C:\program files\...Latest MoI Oct 2020 beta commands folder,
(Or Both folders, if one has the underline prefix for the .js and .htm file.) Accessable with customUI, (or I suppose by tab command entry box in MoI.)
(Not sure about BurrMan's "portable" setup...)
(Windows 10)
Larry, a very cool script!
EDITED: 30 Oct 2020 by BEMFARMER
Message 10013.14 deleted 29 Oct 2020 by BEMFARMER
10013.15 In reply to 10013.12
Hi Burr, yes that text is new in the just released Oct-27-2020 v4 beta. If you don't see it that probably means you're running the Sep-10 v4 beta instead of the new one:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10011.1
10013.16
Thanks Brian and Michael, I should have begun by asking what version BurrMan was running, but of course I made the problem more complicated than need be... ;-}
Planning for life beyond the v4 beta cycle, the code does check moi.majorVersionNumber, but that doesn't help to warn about a particular beta version.
Hopefully once BurrMan gets the Oct 27 beta all will be well!
--Larry
10013.17 In reply to 10013.16
Well, Crap.....
Please disregard my posts on that.. sorry.
10013.18 In reply to 10013.17
No worries! The new features in the Oct 27 beta are a real treat & will also make my script function as intended.
--Larry
Show messages: All  1-7  8-18
