2-21
22-41
42-54
Awesome, I will take a look on this. thanks.
Looks perfect.
Hi all,
I just wanted to point out that Blender import only works with V4 Beta because only the new version of MoI supports fbx 2016 version. So you need to set the FBX Export settings to 2016.
Hello Y'all,
I get only a vacant interface stub in Blender:
Somehow there doesn't seem to be much in the BMOI_Connector-master folder of the download.
Is there only one work file in the Blender addon: "__init__.py" ?
I did set the FXB option to 2016 in MOI.
Do I need to set a folder designation in Blender?
Your advice will be appreciated in the extreme.
- MindSet
Looks like you haven't renamed the folder.
2. Extract somewhere and rename extracted folder to "BMOI_Connector"
3. Copy "BMOI_Connector" folder to "C:\Users<username>\AppData\Roaming\Blender Foundation\Blender\2.8x(2.9x)\scripts\addons"
Fantastic!
This is SO GREAT!
Win7 system can also use this plug-in, I tried
What is the difference between that and ODCopyPasteExternal?
https://github.com/heimlich1024/OD_CopyPasteExternal
I tried but with Wine and Linux not works, for me the best way is via Nurbs surfaces, Blender has a solid nurbs code, that lacks only in the trimmed surfaces.
Below an ICEM surf model imported in Blender.
Wait, wait, wait. Are you saying that plugin moves patches and curves from Moi3d to Blender? That would be insane. This is not a problem to trim all surfaces. Wow! I`m amazed :) I`ve thought that convert nurbs to polygons and moves geometry as OBJ/FBX file. I haven`t known that FBX can handle nurbs patches.
seems like I'm getting an error from the 97 bmoi.js file. any suggestions? thanks Val
Hi val,
Are you running an older version of Moi or have you possibly copied an old version of the CommandBar.htm in place of the standard one in the current v4 beta?
That error looks like you are missing the
piece of CommandBar.htm that's in v4.
No this example is imported in blender with a special Blender's build, that import 3dm file. here more info about.
https://blenderartists.org/t/branch-soc-2014-nurbs-update-to-master/1207889/
But what I suggest is Blender can handle well Nurbs and maybe the best way is using it's own native Nurbs code to exchange file and not the OBJ format
Thanks. I`ve tried it yesterday but I had shading errors even on simple surfaces.
How to use that native NURBS. Are you saying about writing own code?
Yeah because as can see Blender's nurbs are almost ready, in fact with 3dm build you can ready now import 3dm file into blender Nurbs geometry without meshing them. If use only surface modelling with boundary without trimming you can have the same surface inside Blender.
>That error looks like you are missing the piece of CommandBar.htm that's in v4.
Im using the latest beta but I'm using a modified commandbar.htm (it's the one to use the dark scheme I think, I forgot exactly, as too much time has passed since I swapped it out)
Not that it matters that much as I was just curious if the BMOI was more convenient.
Hi Val,
The modified commandbar.htm is the reason for the error - it's because it's a modified older version and so it's missing something that was added later.
You can add in the missing piece by inserting this:
<span id="CommandBarCustomUI">
</span>
It goes just after the snap buttons.
Michael,
thanks, worked like a charm,
Val
This amazing connector worked v.4 only?
Hi krass,
I think so because the export to FBX needs a newer version of FBX which MoI v4 supports and which MoI v3 doesn't. The FBX import library was updated for v4 and can write newer versions of FBX.
2-21
22-41
42-54
