Show messages: All
1-14
15
Hi MindSet, you would need to modify the Update() function in the RotateArray.js script file to do that.
There is a line of code in there that calculates the parameter value from 0 to 1:
var t = i / ( Factories.length - 1 );
You would need to put in some more code after that to modify the parameter with your desired behavior.
Here's an example that will step up the rotation along the first third, hold it for the middle third, and then ramp back down the last third. Put this in place of the current Update function:
function Update( Factories, TotalRotationAngle )
for ( var i = 0; i < Factories.length; ++i )
////// Added section here
function SmoothStep( t )
// https://en.wikipedia.org/wiki/Smoothstep
if ( t <= 0 ) return 0;
if ( t >= 1 ) return 1;
return t * t * (3 - 2*t);
function GetParam( t, low, high )
t = (t - low) / (high - low);
return SmoothStep(t);
if ( t < 1/3 )
// Beginning third, ramp up smoothly from 0 to full rotation
t = GetParam( t, 0, 1/3 );
else if ( t > 2/3 )
// Ending third, ramp down smoothly from full rotation to 0
t = GetParam( t, 1, 2/3 );
else
// Middle range, hold at full rotation
t = 1;
////// End added section
// Set the angle on the factory
Factories[i].setInput( 2, t * TotalRotationAngle );
// Update the factory to make it recalculate the rotated result.
Factories[i].update();
Show messages: All
1-14
15
