Full Version: About SubDivide in nurbs :)
Show messages:  1-11  12-31  32-51  52-71  72-91  92-111
14 Oct 2020   [#72]
Some minutes of the days :)
17 Oct 2020   [#73]
Precision! :)
19 Oct 2020   [#74] In reply to [#73]
You need Max's plugins for this to work correct?
19 Oct 2020   [#75] In reply to [#74]
Yes of course: in this precise case _sBridge by Max Smirnov
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.254
who can be also used of course for other thing than Subdivision!
22 Jan 2021   [#76]
Seems last version of Rhino 7 uses intensively the SUbD Method! :)
21 Feb 2021   [#77]
Moi SUbdivided object + texture of the fabulous free Vervette SandBox online
http://www.taron.de/Vervette/sandbox/
21 Feb 2021   [#78]
Searching something for all kill the internal volume (faces, edges) for make some cool subdivided object...
it appears that is very difficult directly in Moi ! (for the moment (?) )...
Boolean union will remove the internal faces but also merge together some of the outer ones.
Edit Join don't remove internal faces!
So no success!
5 boxes for test your scripts or other tricks! https://moiscript.weebly.com/uploads/3/9/3/8/3938813/5boxes.3dm
the 3 little boxes have no internal faces because built with Max sSplit :)
the 2 other have mutual faces!
But i have found some little tricks! :)
- Export as OBJ / Ngon Without Without Weld vertices along Edges!
- Import OBJ from SUbDiv/ Create /From File
- Boolean Union
- Max Subdiv
That works fine...except for this case!
don't works when "cubes" are tangent by a commune vertical edges!
Works in other compact or alone positions!
the bad case (works in other cases! )
so no total success again!...
but i have found another trick for this particular case! :)
Up or down the top face of one of these 2 boxes by a very, very tiny distance!
et voilĂ ! :)
Have fun subD modeling before a script or command OR NODES who kill all internal volume! :)
(second box was made with sBridge by Max Smirnov
22 Feb 2021   [#79]
18 Jun 2021   [#80]
Relaxing in 10 seconds :)
Bonus :)
7 Jul 2021   [#81]
7 Jul 2021   [#82]
PolyLine
Offset
A segment between same vertex of the 2 PolyLines
Sweep
CopyMove Joined Surfaces
Separate
Extrude
Boolean Union
SubDive
7 Jul 2021   [#83] In reply to [#82]
Cool techniques, Pilou!
22 Sep 2021   [#84]
When some faces on a solid are not divided for general SubDivide so fails
Draw lines missing
Select All / Trim
Kill Curves (Browser curves selection)
SubDivide
10 Oct 2021   [#85]
Funny in few seconds...
Else how is not evident (here in Blender but will be the same in other) to make in the rules of art
a submodeling sculpting! :)
17 Oct 2021   [#86] In reply to [#1]
Dear Pilou,
Many thanks for all the tips on SubD modelling and especially for the introduction to SimLabs Composer. The possibilities are endless.
Kind regards,
Philip
21 Jan 2022   [#87]
LineWeb for help to make Box Modeling :)
Draw curves
Rebuild say 10 points
Line Web: Lines or polylines or curves: 10 points (order of selection is important! )
Kill curves
Loft "Lines"
Kill Lines
Select faces : Extrude with "Keep Separate"
Boolean Union
Subdivide
21 Jan 2022   [#88]
And if you save your object in OBJ
You can use the free funny Spline for some cool things in seconds without some efforts! :)
Click on the little object ;)
And of course Zoom, Rotate, Move...
22 Jan 2022   [#89] In reply to [#88]
Respect Pilou for your creative use of MOI !
You always amaze us with new surprises !
22 Jan 2022   [#90]
Not exactly Sudivide but...
General article bout "NGons" https://www.artstation.com/artwork/0n93EV
18 Apr 2022   [#91]
Hello all,
Where can I find Subdiv_classic (not Subdiv_Beta_9).
