14-33
34-53
54-73
74-93
94-111
As volume is now complex Subdivide can't work easilly on all the volume!
So volume must be trimed in some parts for have have some partial subdivisions
Use of the Bridge function for transition between a curvature perimeter and a straight perimeter
so a perfect solid at the end!
With some Insets & Shells
Is anyone doing real things with this tool or just abstract forms?
It's just a tool for make something very speedy who will difficult to make in other way !
Free to you to make real or imaginative things with it! :)
And all is 3D Printable because it's a solid!
It's slighty different than normal modelisation as result is "hypothetical" !
You have not the total control on the result in measure... else make some tests following that you wish...
I have something like that but not exactly the same...
ok i have the same by Copy/ Move & killing the internal Top Bottom faces...Join(front faces hidden/shown)
And for the Extrude without separate will be also fine in killing internal Top Bottom & Vertical faces...
All that is some tricky! :)
Hi QUARITEXA
sometimes i use it to create organic shape
here renders with subdivide
Very cool result !
Maybe you can try this free one for unjaggies your big format. even *4 size if needing...
https://deep-image.ai
Ps Your original image is too large for be loaded in the prog...so half it then size*2 or more in the prog... ;)
Speedy test with your bootle half size (then size *2 + strong unjagg both in the prog) result is done in PNG as given in png
Frenchy, it's a screen :)
the 3D model is very smooth
Little correction of the selection of faces of a complete volume!
When you select directly the All volume the SsPlit don't work!
so
I said Separate All then SSplit : that work!
But you can also make that! :)
Select one face then select All and then Ssplit that work also!
(because Moi memorize the nature of the selection made by the first selection: point, edge, face,...
Maybe more speedy in calculate than "Separate"! :)
(negative extrude dig up! :)
Export as OBJ Format (Ngones) No problem to import them inside the free TwinMotion !
That's super amazing. I wasn't aware that the initial selection can play a role even when you select all afterwards! Using sSplit and subdiv gives very interesting results and you stay within MoI to experiment and cut. I learn a lot by your mini tuts! <3
Of course subdivision can work on 2D !
In this case disable Preserve Corners if you select a simple square for example!
After you must make some little tricks if you want use only the subdivided curve(s) resulting!
A funny one is to use the Hide function associate to the nature of the Preselection of Moi!
Join curves at the end of selection ! Here a general fillet or anything you want at the end...
You can also use the Function Edit "Add Point" so very flexible!
Iso Curves + General Trim will give another result !Less Flexible!
Where can I get the subdivide script?
http://moi.maxsm.net/media/files/
All the plugins of Max Smirnov!
Subdiv 9
SBridge
Ssplit
Sscale
If you want them in French :
http://moiscript.weebly.com
Les Commandes / Section Scripts de Max Smirnov ;)
We can't have edit subdive on 2 "half parts" in the same time!
So Subdivide on an half part mirror it and make any thing you want on the original half Part!
It's a little tricky !
- Mirror Original
- Select Mirrored
- Call History - Enable History - Deselect
- Select Original
- Modify / Edit as you want --> that is refflected! ( subdivide is not reflected)
(you can subdivide at any time the Original for test the form)
- Re-group the 2 parts
-Join
You can Subdivide the all volume!
Remark that the start lateral general side is "Open" !
Extrude on middle faces is possible but not on the extremities!
Because faces are not all subdivided!
So Copy Move 1 faces & Bridge it on the faces's extremities!
For past something you must use Copy Snap then Join!
So kill the 2 minimum faces of "collage" from the 2 volumes!
Boolean Union don't work because some faces'edges ...
...will be welded in external "walls"and so create un-subdivided faces!
With the last function Sscale seems we can make some many things ;)
That's a very funny method of modelisation! Thx again to Max Smirnov for its crazzy plugin!
If i have forgotten something don't hesitate!
The only default of this method is that result is like a random result about measures...
so some tests...takebacks...it's an artistic method! :)
14-33
34-53
54-73
74-93
94-111
