Show messages: All
1-8
9-10
How does one accomplish a sectional view as exemplified here:
MindSet
Hi Mindset, probably the simplest way is to use boolean difference with a box as the cutting object. If you want some pieces not to be cut you could add them back later or also if you make a face selection on the base object for the boolean it will only cut faces that are selected and leave unselected ones alone.
Show messages: All
1-8
9-10
