Full Version: Volume calculator
Show messages:  1  2-21  22-41  42-61  62-76
9 Sep 2015   [#42]
Hi Max,
Is it possible to calculate surface area of selected faces only?
Thanks.
Mik
9 Sep 2015   [#43] In reply to [#42]
Hi Mik, good idea! I'll make it today or tomorrow.
9 Sep 2015   [#44]
Thanks again Max! This is fantastic!
Michael T.
9 Sep 2015   [#45]
Hi Max,
This is a great tool, thank you.
I think this is a big ask, but would it be possible for 2 or more solids of different densities to have its combined centre of Gravity worked out?
James E
9 Sep 2015   [#46] In reply to [#43]
Thank you very much , Max, it would be great.
Mik
9 Sep 2015   [#47] In reply to [#45]
The equation to find combined centre of Gravity, is explained very well here:
https://www.youtube.com/watch?v=KMDY-hexpZ8
mass1 = vol1 * density1 , centered at point mass m1.
mass2 = vol2 * density2 , centered at point mass m2.
d = distance between (center of mass of m1) and (center of mass of m2).
x = distance from (center of mass of m1) to the point on the line between m1 and m2, which is the combined centre of Gravity.
m1 * x = m2(d-x)
x = (m2 * d ) / (m1 + m2)
They say is the "same" for torque. (No inverse square law needed.)
(x is not necessarily the x-axis), so x,y,z coordinates of the points may be used, or a cplane making d along the x axis...)
11 Sep 2015   [#48]
CVolume v1.3
[added] enhanced surface mode. How you can use this script with faces and separate surfaces.
Marbleman
Hi James. Yes, this is possible, but I need to think about concept. Give me a week.
11 Sep 2015   [#49] In reply to [#48]
Excellent Max,
thank you very much, you are King of Scripts :-)
Regarding centre of gravity ... it will be fine to have set of styles which represents certain material = density.
Kind regards,
Mik
11 Sep 2015   [#50] In reply to [#49]
Mik
Yes, I have the same thoughts.
In fact the technical part don't bother me. There are pretty simple calculations. First I need to think about global internal structural changes. It is much more difficult task.
11 Sep 2015   [#51]
Yes, of course, choosing the best concept is always big task and calculation of CoG will be very useful feature for modelling of complex assemblies.
Kind regards,
Mik
11 Sep 2015   [#52]
Do you confirm or not that Center of Mass can be calculated between 2, 3, or more volumes in the same time inside the present plugin? (same density)
11 Sep 2015   [#53] In reply to [#52]
Yes, I confirm it. :-) 2, 3 and more.
11 Sep 2015   [#54] In reply to [#53]
Terrific!
11 Sep 2015   [#55]
Thanks Max,
I think you're the master!
James E
12 Sep 2015   [#56]
Thanks Dino and Max for this useful script.
I have a small improvement request: In the default MoI user interface some contents of the dialog window is too wide.
-Martin
12 Sep 2015   [#57] In reply to [#56]
Hi Martin,
I didn't noticed any problem with the script interface. But it seems like you are using Windows UI scaling feature. I'll make some chаnges in the script to fix it. Wait for the next version.
12 Sep 2015   [#58] In reply to [#57]
Hi Max,
it's on my Laptop and Desktop computer both running OS X. I'm not aware of any window scaling.
13 Sep 2015   [#59] In reply to [#58]
It's the same for me on OS X.
13 Sep 2015   [#60]
Hi Max,
Your script is amazing, I have wanted this feature since MoI's beta.
Concerning the display cutoff; I am experiencing this as well. I'm not scaling and my display is 1920 x 1080 in Windows 10.
Again though I am so happy to have the script, thanks for all your hard work in this area!
David W. (Aka: blend3d)
21 Sep 2015   [#61]
CVolume v2.0 beta 1
Completly rewritten :)
Added:
- Center of mass calculation for solids of different densities. ( style = material )
Fixed:
- Interface width
Hidden features:
- Double click on title to reset group volume
- Double click on group name to switch to the first group (All objects)
- You can use material name as style name (full or partial). The script will set density automatically. For example: "Copper", "Wooden box [Redwood]", "Golden ring"
To do:
- Interface tuning
- Volume/Mass changing for All objects group.
upd: bug fixed. reuploaded.
