19-38
39-58
59-78
79-98
99-118
119-138
Thanks a lot Max.
I've made a little test.
Finally now when I chose "Polygon" mode all the polygons generated are "single polygon" and not line segments.
Thank you very much!
You are a perfectionist! :)
This is great fun to play around with, thanks alot Max for taking the time!
I was wondering though, is there a way to remove point during while creating the voronoi?
Nick
Voronoi.v.0.9.2018.03.01 ;)
http://moi.maxsm.net/item/48
I know about an overlapping bug. I'll fix it tomorrow.
will this fix also keep a similar distance between curves?
...you want the "moon" :)
less than one half =)
The usual trick is to have a distance between the edges was that one draws
a control point curve around the corners of each cells and offset then a little
bit inwards.
That's how i have done it in the past with my Voronoi Eggs.
https://www.behance.net/gallery/34247989/Voronoi-Egg-CVT
Hi glmr,
yes.
between polygons
did you make these eggs in Moi3d??? I thought it is possible only with Paneling tools from Rhino
nice! looking forward for your update
i used various tools to create the voronoi structure and finally used MoI to model the eggs, so no paneling
with Rhino etc.
Voronoi.v.0.98
French version! ;)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
Thanks a lot Max !
Thanks Max
Always funny!
how???
Very very nice!
<< how???
_Voronoi
Extrude "Tapered"
Flow on a Sphere
Render in free Real Time SimLab Composer Lite (max 1920 * 1080)
Have fun!
Here Corners of Voronoi are >90 so rounded (put 0 if you want sharp forms)
19-38
39-58
59-78
79-98
99-118
119-138
