20-29
I used lines (opened curves) to build morphed curves. But now the script uses different method in situation when both curves are closed. It uses circles instead. :)
Thank you for advice.
Cool plugin but something curious! :)
Line Web:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.10
So it's you or Michael who have made an inversion! :)
I presume it's you for any secret reason! :)
(not a big deal as the Flip Command exists in Native in Moi : just select a curve(s) and Press Tab then type Flip! :)
I first use CMorph between the 2 yellow curves then LineWeb! Careful! Order of select curves is important for LineWeb!
It works, thanks Max! Only thing left now is the flipped curve direction as Pilou mentions.
Ops. Just forgot to check this :)
Found. Fixed. Uploaded.
This is really cool Max, thanks for posting it and updating it!
Cool! ;)
Hello Max
in Moi V4 on my Mac I get this error message when I run the script. In V3.1 it's working fine.
cheers
jopo
Hi Jopo
you need to download a latest version of the script:
http://moi.maxsm.net/files/scripts/cMorph.v.1.1.2014.01.19.zip
Hi Max,
thanks a lot! It's working now.
JoPo
I'm usually not very active here but I had to tell you: THANK YOU! This helped me save at least an hour of work!
20-29
