Show messages: All
1-3
4-16
Essentially, I want a macros to be executed that will perform the following sequence:
- Selected points on the polyline
- A circle is constructed from these points (customizable)
- Then the circle intersects with the polyline and creates two equidistant points
- The circle is removed
Thus we get the displacement of these points
Hi Moi3dFan, please try the attached script.
Instructions for installing scripts are here:
https://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
You can click 2 points in the view to dynamically change radius, or type it in and there is a mode for generating points or for making a control point curve through the points.
Hope that is what you were looking for,
AddCornerPoints.zip
very useful script, thank you.
Only one question...when I select points on polylines curve and run the script error message appear "No polylines or polylines points selected" although the polylines points were selected before run the script.
If I select polyline curve as a whole script run without problem and all points are rounded.
Is it bug or I should select the points in different way?
Mik
Hi Mik, it sounds like a bug but I'm not seeing it over here.
Could you please post the .3dm file with your polyline in it so I can test with it?
I'm also not sure what the behavior should be for making a curve when only some corners are selected. Currently it makes a control point curve out of the whole thing with tighter bends in the corners that are getting added points.
Thanks, - Michael
the behaviour of script as I mentioned above is appeared in MoI V4, in V5 the script runs as you described in previous post.
Mik
AddCornerPointsTestFile.3dm
Hi Mik, scripting access to object edit points is new in v5 so that's normal.
You'll need to run it in v5 for that part to work.
It works even better than intended! Thank you!
There are a couple things that could be improved:
- Points in "Make Point" mode are added to the polyline itself. You can made checkbox for this mode.
Of course, I can cut the curve by these points and then connect them, but I want a shortcut.
- Note that, in "Make curve" mode. If a polyline has only one point selected, then after applying the script the whole polyline turns into a curve. This is rather wrong, for I want to smooth out one point.
I have a solution though - I'll just detach the corner I want and apply the script.
Thank you for taking the time to do this, with scripts like this you make it very easy to work in your favorite program
Hi Moi3dFan, you're welcome I'm glad that is useful.
I've updated the script (attached in message above) to have an additional polyline mode where it generates a polyline with the new points in it.
I've also updated it so that it will only smooth selected points and leave unselected ones as sharp corners.
And seems working even Polylines are not planar!
And multiple! :)
French version!
https://moiscript.weebly.com/addcornerspoints-polylignes.html
Greetings!
I encountered a problem, when a polyline turns into a polycurve, the script doesn't work anymore
https://drive.google.com/file/d/1u2LwGowMSEeUYyLTR0SxRHH0jSVW0hO1/view?usp=sharing
Can this be solved?
MoI_Nr1YgXqf35.mp4
Hi Moi3dFan,
Yes, that's correct, the script is only designed to work on polylines which is what you requested.
Making it work on other types of input would need a pretty different process, it would not be a small change to the script.
I'm sorry I'm not able to do it at this time.
It's ok, I found a way out by just disconnecting the corners I want and applying the script to them.
I sorry for the distraction, I hope everything is going well with your work
Show messages: All
1-3
4-16
