Show messages: All
1-5
6-7
Hi Matadem, shortcuts are saved in the moi.ini file when MoI closes.
Do you possibly have multiple instances of MoI running when you set up the shortcut?
If so then close all but one instance, edit the keyboard shortcut and then close the last instance so that it can write out settings to the moi.ini file.
If that isn't it then have you possibly set the moi.ini file to be read only?
You may have to resave your open template file so it saves it
Show messages: All
1-5
6-7
