Show messages: All
1-2
3-9
10 x 10 is not a rectangle, it's a square! :)
Hm, I don't understand what Const Dist does, but when I enter 10 for my 10x10 "rectangle" :) it certainly does not fillet the whole corner.
My Bad. I wasnt paying close enough attention.
So workaround would have to suffice.
you can extrude your rectangle out a bit and solid fillet it, then extract the curves you need
Or use the arc center point tool to draw in the full arc.
Just a workaround. I'll listen for Michael to discuss any details
Sorry about the original mislead.
I had already made the first part, so I included it here to keep the warts!!!
VIDEO
Hi Andre, I've been looking at this and I think I can get it fixed up, know more tomorrow.
Squares are rectangles, but only some rectangles are squares.
Hi Andre,
> I know, fillets are a finicky thing, but this seems so simple that maybe it can be fixed?
> Create a rectangle with known dimensions, for example 10 x 10 mm. Try to fillet one
> corner completely, i.e. set the fillet radius to 10. -> Calculation failed
This is fixed for the next v5 beta.
Show messages: All
1-2
3-9
